update-to-5.15.52_2.1.0__toradex_imx_lf_v2022.04
At present, in cgc1_pll3_init we don't set the pll3pfd div values,
just use the default 0. But when MROM-3029 is applied, ROM will set
PLL3 pfd1div2 to 1 and pfd2div1 to 3.
This finally causes some clocks' rate decreased, for example USDHC.
So clear the PLL3DIV_PFD dividers to get correct rate.
Signed-off-by: Ye Li <ye.li@nxp.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit 91eb5a47b996b531c5fda5e421d35f54f486c548)
Some space in SRAM0 will be protected by S400 to allow RX SecPriv mode
access only for boot purpose. Since SW will reuse the SRAM0 as SCMI
buffer and SPL container loading buffer, need to reconfigure MRC3.
(cherry picked from commit ebfac7540de520b97724d3fd2d5918b4b56327b1)
CAAM is initialized in SPL, so relevant device tree nodes needs to be
updated.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221004110632.21045-2-andrejs.cainikovs@toradex.com/]
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Add downstream-specific USB properties.
Upstream-Status: Inappropriate [other]
- NXP downstream specific
Suppress warning by adding default RDC configuration.
This commit adds few USB related features:
- USB Gadget devices
- USB Mass Storage (aka UMS)
- Fastboot
* origin/imx_v2022.04:
LFU-386 imx: ele_ahab: Remove OEM Secure World Closed print
The OEM Secure World Closed is not a valid lifecycle on iMX8ULP/iMX9.
So remove it from lifecycle print.
LF-6846 imx8ulp: XRDC: configure DRAM access for S400
Need to add DRAM access permission for S400, as S400 needs to access
it When SPL calls image authentication
LF-6798 imx: ele_ahab: confirm lifecycle before closing the part
Before moving the lifecycle to OEM closed, confirm the lifecycle is
OEM open, otherwise cancel to move forward the lifecycle.
LF-6816 imx9: Print CPU frequency in u-boot log
Follow other iMX u-boot, print the CPU frequency in boot log
LFU-382 imx93: Change hard coded MAC to read from fuse
The MAC addresses are hard coded for bring up. Change it to support
reading from fuse.
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
LFU-376 imx93_evk: Change ethprime to eQOS port for default
LFU-378 imx8ulp: Hang the u-boot when M33 is not loaded
LFU-377-2 imx: spl_imx_romapi: Get and print boot stage
LFU-377-1 imx: container: Skip container set check for ROM API
When M33 handshake is necessary, current u-boot will panic to reset itself.
Change to not panic but hang the u-boot, so that M33 tests can use JTAG
to load M33 image.
Get and print boot stage through ROM API in SPL
Skip the container check for platforms using ROM API. It causes
always printing primary container set used
MA-20481-2 Enable round mipi-panel usmp-rm67162 for imx8ulp watch board
MA-20481-1 Add board files and defconfig for imx8ulp watch board
New imx8ulp_watch files are based on imx8ulp_evk and modified for watch board.
Change-Id: I0ad6130cd7df60cb453abb9adcf36242f3cc0fd5
Signed-off-by: Zhang Bo <bo.zhang@nxp.com>
* origin/imx_v2022.04: (6 commits)
LFU-369-4: Added configs required for dcp_rng driver
LFU-369-3: Added dcp_rng driver device binding code
LFU-369-2: Uboot RNG Driver using Data Co-processor
LFU-369-1: Adding rngb entry in imx6ull device tree
LFU-373 imx8ulp: upower: Do not send AFFB enable message for A1
This commit manually binds dcp_rng device driver and initalizes it inside
arch_misc_init() function.
Signed-off-by: Kshitiz Varshney <kshitiz.varshney@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
Added entry for rngb in imx6ull device tree which is required for
Random number generation in u-boot.
On A1 part, upower ROM will default enable AFFB for APD/AVD/RTD before
power on domains. We don't need to send the AFFB enable message
any more. Actually enabling the AFFB of APD should happen during power
mode switch which needs put APD to hold mode. It is hard to implement
for boot, so upower ROM's implementation is necessary and simple.
The div loop uses reassign and reuse parent_rate, which causes
the parent rate reference to be wrong after the first loop, the
resulting clock becomes incorrect for div != 1.
Fixes: 829e06bf4175 ("imx8ulp: clock: Add MIPI DSI clock and DCNano clock")
Signed-off-by: Loic Poulain <loic.poulain@linaro.org>
(cherry picked from commit 85d0580e684c74dcb0a90aa0c010006cda40af44)
LFU-372-3 imx8ulp: Enable SCMI thermal for temperature
LFU-372-2 DTS: imx8ulp: Add SCMI sensor node
LFU-372-1 thermal: Add SCMI Sensor based thermal driver
Change from PMC thermal driver to SCMI thermal to get temperature,
so that we can avoid TRDC access issue for PMC and ADC on RTD
Reviewed-by: Alice Guo <alice.guo@nxp.com>
Add SCMI sensor node and enable pre-relocation for SCMI, so that
we can use SCMI thermal driver at early phase of u-boot.
LF-6692-4 imx8ulp_evk: Disable the PMC thermal driver
LF-6692-3 imx8ulp: Adjust handshake to sync TRDC and XRDC completion
LF-6692-2 imx8ulp: Remove the TRDC configure from A35
LF-6692-1 imx8ulp: xrdc: Fix DID0 access DDR in MRC4
To fit the DBD_EN fused part, we re-design the TRDC and XRDC assignment.
M33 will be the TRDC owner and needs to configure TRDC. A35 is the
XRDC owner, ATF will configure XRDC.
The handshake between U-boot and M33 image is used to sync TRDC and
XRDC configuration completion. Once the handshake is done, A35 and M33
can access the allowed resources in others domain.
The handshake is needed when M33 is booted or DBD_EN fused, because both
cases will enable the TRDC. If handshake is timeout, the boot will panic.
We use SIM GPR0 to pass the info from SPL to u-boot, as before the
handshake, u-boot can't access SEC SIM and FSB.
As M33 is responsible for TRDC configuration, the settings for A35
nonsecure world access and DMA0 access are moved to M33 image.
So remove the codes to release TRDC and configure it. Just keep
the configurations for reference.
eDMA1 and USHDC0 access to DDR are controlled by MRC4, so must configure
the MRC4 for DID0
LFOPTEE-169 imx8ulp: s400: start the S400 RNG at boot
MA-20464 imx8mp: move enet1 to domain 1
On the imx8ulp A1 SoC, the S400 RNG needs to be manually started.
Signed-off-by: Clement Faure <clement.faure@nxp.com>
move the enet1 to mcu domain as mcu may use it.
Change-Id: I65d42d37c97139cf51b00f541e6688e2a97cc624
Signed-off-by: Ji Luo <ji.luo@nxp.com>
* origin/imx_v2022.04: (11 commits)
LFU-332-10: configs: imx8mm: ab2 target board config options
LFU-332-9: include: configs: imx8mm ab2: board configs
LFU-332-8: dts: arm: imx8mm ab2: target board support
LFU-332-7: arm: mach imx8m: imx8mm ab2 target board configs
LFU-332-6: board: freescale: imx8mm ab2: target board support
Add device tree configs for audio board 2.0 for
common imx8mm som modules
Signed-off-by: Adrian Alonso <adrian.alonso@nxp.com>
Add iMX8M Mini Audio board 2.0 target board configs
common imx8mn som modules
Add iMX8M Nano Audio board 2.0 target board configs
* origin/imx_v2022.04: (8 commits)
MLK-25979-3 imx8ulp: xrdc: Set MRC4/5 for access DDR from A35 and APD PER
MLK-25979-2 imx8ulp: soc: Limit the eMMC ROM API workaround to A0.1 part
MLK-25979-1 imx8ulp: soc: Get chip revision from Sentinel
LF-6576 serial: lpuart: Fix LPUART FIFO_RXFE for all platforms
MLK-25974 tcpc: check if i2c_dev is NULL before dm_i2c_read/write operation
iMX8ULP A1 S400 ROM will remove the setting for MRC4/5. So we have to set
them in SPL to allow access to DDR from A35 and APD PER masters
Since A1 ROM has fixed the ROM API eMMC issue, we should only use
the workaround for A0.1 part. Add a SOC revision check.
In both SPL and u-boot, after probing the S400 MU, get the chip revision,
lifecycle and UID from Sentinel.
Update get_cpu_rev to use the chip revision not hard coded it for A0
According to the board design change, move USB i2c devices to lpi2c3 bus.
Signed-off-by: Clark Wang <xiaoning.wang@nxp.com>
The root clock used in imx_get_i2cclk() is incorrect. Change it to
LPI2C1_CLK_ROOT.
