Enable MUSB host and USB storage support for Microchip
PIC32MZ[DA] Starter Kit.
Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
The "R" constraint supplies the address of an variable in a register. Use
"r" instead and adjust asm to supply the content of addr in a register
instead.
Fixes: 2b8bcc5a ("MIPS: avoid .set ISA for cache operations")
Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
This adds ethernet, TFTP support for PIC32MZ[DA] Starter Kit. Also
custom environment variables/scripts are added to help boot from network.
Enable MMC, SDHCI, FAT_FS support for PIC32MZ[DA] StarterKit.
Also add custom scripts, rules to boot Linux from microSD card.
This adds support for Microchip PIC32MZ[DA] StarterKit board
based on a PIC32MZ[DA] family of microcontroller.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Add Microchip PIC32MZ[DA] SoC family support.
This driver initializes PIC32 DDR2 SDRAM controller and internal DDR2 Phy module.
DDR2 controller operates in half-rate mode (upto 533MHZ frequency).
Signed-off-by: Paul Thacker <paul.thacker@microchip.com>
Create initial directory, Kconfigs needed for PIC32 architecture
support. Also add PIC32 specific register definition required for drivers.
The existing mips_io_port_base variable isn't suitable for use early
during boot since it will be stored in the .data section which may not
be writable pre-relocation. Fix this by moving the I/O port base address
into struct arch_global_data. In order to avoid adding this field for
all targets, make this dependant upon a new Kconfig entry
CONFIG_DYNAMIC_IO_PORT_BASE. Malta is the only board which sets a
non-zero I/O port base, so select this option only for Malta.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
CONF_SLOWDOWN_IO is never set for any target, so remove the dead code in
the SLOW_DOWN_IO macro. This is done in preparation for changes to
mips_io_port_base which can be avoided in this path by removing it
entirely.
This patch makes sure that the flush/invalidate_dcache_range() functions
can handle corner-case calls like this -- invalidate_dcache_range(0, 0, 0);
This call is valid and is happily produced by USB EHCI code for example.
The expected behavior of the cache function(s) in this case is that they
will do no operation, since the size is zero.
The current implementation though has a problem where such invocation will
result in a hard CPU hang. This is because under such conditions, where the
start_addr = 0 and stop = 0, the addr = 0 and aend = 0xffffffe0 . The loop
will then try to iterate over the entire address space, which in itself is
wrong. But iterating over the entire address space might also hit some odd
address which will cause bus hang. The later happens on the Atheros MIPS.
Cc: Hans de Goede <hdegoede@redhat.com>
Fix 32 vs 64 bit load/store instructions. Access CP0_WATCHHI as
32 Bit register. Use 64 Bit register access for clearing gd_data
and copying U-Boot.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Argument boot_flags of board_init_f() should be set to 0 as
$a0 may be utilized in lowlevel_init() or mips_cache_reset()
or previous stage boot-loader.
As part of the bug.h / BUILD_BUG_* clean up, this file was missed.
Add support for functions clrbits_X(), setbits_X() and clrsetbits_X()
on MIPS.
Add a SPDX license identifier to MIPS header files where it is
still missing.
Update definitions for processor, registers as well as assemby
macros.
Mainly sync asm/io.h to get a working ioremap() implementation
as well as the full set of I/O accessors. Pull in additional
header files to make this work.
Furthermore port over the directory 'arch/mips/include/asm/mach-generic/'
with contains default definitions for I/O and memory spaces and default
implementations for mapping those spaces. All files in that directory
can be overwritten by a SoC/machine.
Add Kconfig symbol for L1 cache shift like the kernel does.
The value of CONFIG_SYS_CACHELINE_SIZE is not a reliable source
for ARCH_DMA_MINALIGN anymore, because it is optional on MIPS.
If CONFIG_SYS_CACHELINE_SIZE is not defined by a board, the
cache sizes are automatically detected and ARCH_DMA_MINALIGN
would be set to 128 Bytes.
The default value for CONFIG_MIPS_L1_CACHE_SHIFT is 5 which
corresponds to 32 Bytes. All current MIPS boards already used
that value. While on it, fix the Malta board to use a value of 6
like the kernel port does.
Move setup of -march to arch/mips/Makefile and follow the design on ARM.
Also add a possibility to chose specific CPU tune options.
Signed-off-by: Wills Wang <wills.wang@live.com>
Refactor machine setup like it is done on ARM. While on it,
also support "include <mach/file.h" for machine specific
header files.
Prepare sub-folder for device-tree files. Make support for
device-tree on MIPS available in Kbuild/Kconfig.
SPL binaries are usually linked to a fixed address in SRAM.
Furthermore SPL binaries do not need to relocate itself. Thus
do not build them as position-independent binaries which helps
to largely reduce the size of SPL binaries.
Put all functions coded in assembly in sub-sections of
section .text. This allows the linker to garbage collect
unused assembly functions too.
Correctly annotate _start and relocate_code as functions to
produce more readable disassembly code generated by objdump.
With CONFIG_CMD_GPIO compilation reports error.
common/cmd_gpio.c:13:22: fatal error: asm/gpio.h: No such file or directory
#include <asm/gpio.h>
Reviewed-by: Chin Liang See <clsee@altera.com>
With format-security errors turned on, GCC picks up the use of sprintf with
a format parameter not being a string literal.
Simple uses of sprintf are also converted to use strcpy.
Signed-off-by: Ben Whitten <ben.whitten@gmail.com>
Acked-by: Wolfgang Denk <wd@denx.de>
The move to 'generic board' as well as changes in the generic
bootm code broke the boot of FIT uImage's. Especially uImage's
with additional initramfs images or FDT's do not work anymore.
Refactor the bootm code to work again with the generic bootm code.
Always relocate ramdisk and FDT in step 'bootm prep' because the
generic bootm code does this only for legacy uImage's.
Move the step 'bootm cmdline' to 'bootm prep' because the Linux
kernel parameters rd_start and rd_size have to be initialized after
the relocation of the ramdisk.
Furthermore support the step 'bootm fake'.
The generic bitops headers are required when calling logarithmic
functions, such as ilog2().
The syntax for the fdt_chosen/initrd
functions seem to deprecated in usage
from MIPS bootm implementation.
Third parameter is no more used in these api's
Refer to : include/fdt_support.h
Signed-off-by: Govindraj Raja <govindraj.raja@imgtec.com>
In commit a18a477 (MIPS: use common code from lib/time.c) MIPS platforms
started using common the common timer functions which are based around
the fact that many platforms have a 32-bit free running counter register
that can be used see commit 8dfafdd (Introduce common timer functions).
Even MIPS64 has such a 32-bit register (some have an additional 64-bit free
running counter, but that's something for another time).
The problem is that in __read_32bit_c0_register() we read the value from
this register into an _signed_ int and as it's returned up the call
chain to timer_read_counter() it gets assigned to an unsigned long. On a
32-bit system there is no problem. On a 64-bit system odd things happen,
sign extension seems to kick in and all of a sudden if the counter
register happens to have the MSb (i.e. the sign bit) set the negative
int gets sign extended into a very large unsigned long value. This in
turn throws out things from get_ticks() up.
Update __read_32bit_c0_register() and __read_32bit_c0_ctrl_register() to
use "unsigned int res;" instead of "int res;". There seems to be little
reason to treat these register values as signed. They are either
counters (which by definition are unsigned) or are made up of various
bit fields to be interpreted as per the CPU datasheet.
Reported-by: Sachin Surendran <sachin.surendran@alliedtelesis.co.nz>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
The kernel changed it a long time ago. Also this is now broken
on gcc-5.x.
Reported-by: Andy Kennedy <andy.kennedy@adtran.com>
Fix missing semicolon in cacheops.h introduced in commit
2b8bcc5a2 (MIPS: avoid .set ISA for cache operations)
Signed-off-by: Tony Wu <tung7970@gmail.com>
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
By making the board selections optional, every defconfig will include
the board selection when running savedefconfig so if a new board is
added to the top of the list of choices the former top's defconfig will
still be correct.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Add device-tree handover to Linux kernel conforming with MIPS UHI [1].
Register $a0 will be set to the reserved value -2. The address of
the device-tree blob will be stored as KSEG0 address in $a1. $a2 and
$a3 are set to zero.
[1] http://prplfoundation.org/wiki/MIPS_documentation
Update the naming convention used in the network stack functions and
variables that Ethernet drivers use to interact with it.
This cleans up the temporary hacks that were added to this interface
along with the DM support.
This patch has a few remaining checkpatch.pl failures that would be out
of the scope of this patch to fix (drivers that are in gross violation
of checkpatch.pl).
The current implementation exposes the eth_device struct to code that
needs to access the MAC address. Add a wrapper function for this to
abstract away the pointer for this operation.
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD.
Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
Unify and move code in arch/mips/cpu/mips[32|64]/ to arch/mips/cpu/.
The CPU specific config.mk files need to remain until
CONFIG_STANDALONE_LOAD_ADDR is converted to a global Kconfig symbol.
Move all au1x00 code out of arch/mips/cpu/mips32 to allow
unification of CPU code in a later patch. The reorganization
of the SoC specific header files will be done in a later patch
series.
In preparation for sharing a single copy of start.S between mips32 &
mips64, handle setting the KX bit of the cop0 Status register when the
mips32 start.S is built for mips64.
mips64, handle mips64 relocations in the mips32 start.S when built for
mips64.
Where the mips32 & mips64 implementations of start.S differ in terms of
access sizes & offsets, use the appropriate macros from asm.h to
abstract those differences away. This is in preparation for sharing a
single copy of start.S between mips32 & mips64.
The exception to this is loads of immediates to be written to the cop0
Config register, which is a 32bit register on mips64 and therefore
constants written to it can be loaded as such.
This patch adds IDE support to the MIPS Malta board. The IDE controller
is enabled after probing the PCI bus and otherwise just makes use of
U-boot generic IDE support.
Current MIPS cores from Imagination Technologies use TagLo select 2 for
the data cache. The architecture requires that it is safe for software
to write to this register even if it isn't present, so take the trivial
option of clearing both selects 0 & 2.
