No one expects to end up in a delayed environment if
CONFIG_DELAY_ENVIRONMENT isn't defined.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Acked-by: Allen Martin <amartin@nvidia.com>
When u-boot is compiled for PXA25x processor, pxa/start.S is calling
cpu_init_crit by BL instruction. BL is overwriting lr register so
relocate_code is going into infinite loop. This patch preservs lr
register in r12 before calling cpu_init_crit and after function returns
restores it.
Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
Use a common watchdog driver for all these cpus.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Fix coldfire serial driver bindings no more relocated to ram after last
changes to drivers/serial/serial.c (regression).
Serial initialization in ram has to be called after that gd->reloc_off is
calculated.
Signed-off-by: Angelo Dureghello <sysamfw@gmail.com>
Cc: Jason Jin <jason.jin@freescale.com>
Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
Mobile storage is used the CLK_DIV_FSYS3 value.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: kyungmin Park <kyungmin.park@samsung.com>
To get exactly clock value for mmc, support the get_mmc_clk() like
set_mmc_clk().
The two modified lines were indented with spaces.
They are now indented with tabs.
Signed-off-by: Taylor Hutt <thutt@chromium.org>
The timer may be inited in arch_cpu_init() so it is not safe to make a
bootstage mark before this is called. Arrange the code to fix this.
Note: The question was raised as to why we don't keep all archs in sync.
PowerPC doesn't have specific bootstage markers at present (although it
does use boot progress). I hope that the generic board series will solve
this problem in general, but in the meantime this is a real problem, and
only in ARM.
We now get a correct time for board_init_f:
Timer summary in microseconds:
Mark Elapsed Stage
0 0 reset
100,000 100,000 spl_start
848,530 748,530 board_init_f
907,301 58,771 board_init_r
910,478 3,177 board_init
SPL u-boot may call do_reset() which depends on interrupts.o and reset.o.
So make them also appear in SPL.
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
This option displays board info after stdio is running, so that it will
appear on the LCD. If it is displayed earlier, the board info will appear
on the serial console but not on the LCD.
Here follows a blow-by-blow description.
1a. Without CONFIG_DISPLAY_BOARDINFO_LATE, on serial:
U-Boot 2011.12-02550-g037e1c5-dirty (Nov 15 2012 - 14:29:42) for SMDK5250
CPU: S5PC520 @ 1700MHz
Board: Google Snow, rev 0
I2C: ready
DRAM: 2 GiB Elpida DDR3 @ 800MHz
MMC: S5P MSHC0: 0, S5P MSHC1: 1
SF: Detected W25Q32 with page size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: mkbp-keyb
Out: lcd
Err: lcd
Net: No ethernet found.
Hit any key to stop autoboot: 0
SMDK5250 #
1b. Without CONFIG_DISPLAY_BOARDINFO_LATE, on LCD (note machine info
is missing):
In: mkbp-keyb
Out: lcd
Err: lcd
SMDK5250 #
2a. With CONFIG_DISPLAY_BOARDINFO_LATE, on serial:
U-Boot 2011.12-02550-g037e1c5 (Nov 15 2012 - 14:27:40) for SMDK5250
I2C: ready
Model: Google Snow
In: mkbp-keyb
Out: lcd
Err: lcd
SMDK5250 #
2b. With CONFIG_DISPLAY_BOARDINFO_LATE, on LCD (note machine info is present):
Model: Google Snow
In: mkbp-keyb
Out: lcd
Err: lcd
SMDK5250 #
Since the LCD is all that a typical user sees, it is useful to display
the model there.
We may be able to rearrange things some other way one day, but at
present this seems like a convenient way of getting the required
behaviour.
This option delays loading of the environment until later, so that only the
default environment will be available to U-Boot.
This can address the security risk of untrusted data being used during boot.
Any time you load untrusted data you expose yourself to a bug in the
code. The attacker gets to choose the data so can sometimes carefully
craft it to exploit a bug. We try to avoid touching user-controlled
data during a verified boot unless strictly necessary. Since the
default environment is good enough in this case (or you would just
change it), this gets around the problem by just not loading the
environment.
When CONFIG_DELAY_ENVIRONMENT is defined, it is convenient to have a
run-time way of enabling loading of the environment. Add this to the
fdt as /config/delay-environment.
Note: This patch depends on http://patchwork.ozlabs.org/patch/194342/
Signed-off-by: Doug Anderson <dianders@chromium.org>
Reviewed-by: Doug Anderson <dianders@chromium.org>
We want to use the fdt inside board_early_init_f(), so check for its
presence earlier in the pre-reloc init sequence.
So far ARM and microblaze are the only only ones that use
CONFIG_OF_CONTROL. Microblaze does not have the same init loop, and in
particular does not have the board_early_init_f() call. So a patch for
microblaze would have no meaning.
It may be necessary to know where the TLB area ends as well as where it
starts. This allows board code to complete a secure memory erase without
destroying the page tables.
Signed-off-by: Gabe Black <gabeblack@google.com>
In Cortex-A15 architecture, when we run cache invalidate
the cache clean operation executes automatically.
So if there are any dirty cache lines before disabling the L2 cache
these will be synchronized with the main memory when
invalidate_dcache_all() runs in the last part of U-boot
The two functions after flush_dcache_all is using the stack. So this
data will be on the cache. After disable when invalidate is called the
data will be flushed from cache to memory. This corrupts the stack in
invalida_dcache_all. So this change is required to avoid the u-boot
hang.
So flush has to be done just before clearing CR_C bit
Signed-off-by: Arun Mankuzhi <arun.m@samsung.com>
CONFIG_EXYNOS_MIPI_DSIM
When only DP is used, we need not enable CONFIG_EXYNOS_MIPI_DSIM.
But if we do not select CONFIG_EXYNOS_MIPI_DSIM, exynos_fb.c throws
error saying exynos_mipi_dsi_init() not defined. So, we add
dummy definition for exynos_mipi_dsi_init when CONFIG_EXYNOS_MIPI_DSIM
is not defined.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Acked-by: Donghwa Lee <dh09.lee@samsung.com>
With VPLL as source clock to FIMD,
Exynos DP Initializaton was failing sometimes with unstable clock.
Changing FIMD source to MPLL resolves this issue.
Add panel_info structure required by LCD driver
and DP panel platdata for SMDK5250.
Add GPIO configuration for LCD.
Enable FIMD and DP support on SMDK5250.
DP Panel size: 2560x1600.
We use 16BPP resolution to get LCD console.
Acked-by: Simon Glass <sjg@chomium.org>
Add workaround for the following ARM errata: 743622 and 751472.
The motivation for this change is the following kernel commit 62e4d357a
(ARM: 7609/1: disable errata work-arounds which access
secure registers), which removes the errata from multiplatform kernel.
Since imx has been converted to multiplatform in the kernel, we need to apply
such workarounds into the bootloader.
Workaround code has been taken from arch/arm/mm/proc-v7.S from 3.7.1 kernel.
Explanation of each erratum is provided at "Chip Errata for the i.MX 6Dual/6Quad"
document available at: cache.freescale.com/files/32bit/doc/errata/IMX6DQCE.pdf
Modified the arch-kirkwood header so KWGBE_PORT_SERIAL_CONTROL1_REG(x)
returns the correct address.
Originally calling KWGBE_PORT_SERIAL_CONTROL1_REG(1) returned the
address for port 0 and vice versa.
Doesn't have any knock on effects to the u-boot code as the only
time they're used is to do the same function to both addresses
Signed-off-by: Luke Lowrey <luke@chamsys.co.uk>
Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
Acked-by: Heiko Schocher <hs@denx.de>
This saves stack and code memory for local copy, and
consumes initialized data memory. For 22 of the 29
kirkwood-based boards, this results in a global saving
of about 30 bytes. For 7 of them, it results in an
increase of 6 to 14 bytes.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Remove code such as unneeded includes or labels.
These removals have no functional effect.
Move all the C runtime setup code from every start.S
in arch/arm into arch/arm/lib/crt0.S. This covers
the code sequence from setting up the initial stack
to calling into board_init_r().
Also, rewrite the C runtime setup and make functions
board_init_*() and relocate_code() behave according to
normal C semantics (no jumping across the C stack any
more, etc).
Some SPL targets had to be touched because they use
start.S explicitly or for some reason; the relevant
maintainers and custodians are cc:ed.
This required manual merging drivers/mtd/nand/Makefile
and adding am335x_evm support for CONFIG_SPL_NAND_DRIVERS
This patch adds the device node required for USB
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Add SPI device node data for exynos.
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Add sound device node data for exynos
Api is added to decode peripheral id based on the interrupt number
of the peripheral.
Add I2C device node data for exynos
This patch add pinmux settings for Exynos4 for mmc0 and mmc2
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
CC: Albert ARIBAUD <albert.u.boot@aribaud.net>
Adds functions to extract clock frequency of Exynos4x12 IPs.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
Add device tree based ethernet driver for SMC911X controller on
SMDK5250 boards.
Signed-off-by: Hatim Ali <hatim.rv@samsung.com>
This patch adds initial dts file for EXYNOS5250 SoC. This dts
file currently include only ethernet devices and properties. More
devices to be added in subsequent patches.
Also add the dts file for SMDK5250 board which uses the EXYNOS5250
dts file.
This patch adds gpio structure for Exynos4x12.
This patch adds clock structure for Exynos4x12.
This patch populates base addresses of Exynos4x12 registers.
This commit merges branches from samsung, imx and tegra
meant to fix merge issues between u-boot/master and
u-boot-arm/master, as well as a few manual merge fixes.
The R0P7752C00000RZ board has SH7752, 512MB DDR3-SDRAM, SPI ROM,
Gigabit Ethernet, and eMMC.
This patch supports the following functions:
- 512MB DDR3-SDRAM, SCIF4, SPI ROM, Gigabit Ethernet, eMMC
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
README
arch/arm/cpu/armv7/exynos/clock.c
board/samsung/universal_c210/universal.c
drivers/misc/Makefile
drivers/power/power_fsl.c
include/configs/mx35pdk.h
include/configs/mx53loco.h
include/configs/seaboard.h
Move the getenv_yesno() to env_common.c and change most checks for
'y' or 'n' to use this helper.
serial_initialize() must be called after relocation to adjust the
pointers to putc(), getc(), etc. This is busted ever since the
serial driver-model-ification series.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
mips_io_port_base is exported as 'extern const unsigned long mips_io_port_base;'
in arch/mips/include/asm/io.h. Thus make the variable const too.
