path: root/arch
2014-12-29bcm281xx: add support for "USB OTG clock"Steve Rae
enable this clock with the following: clk_usb_otg_enable((void *)HSOTG_BASE_ADDR) Signed-off-by: Steve Rae <srae@broadcom.com> Reviewed-by: Felipe Balbi <balbi@ti.com>
2014-12-29ARM: rpi: support model A+Stephen Warren
Add a board rev entry for the new model A+, and augment the board rev error handling code to be a bit more verbose. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-12-29arm: semihosting: get rid of forward declarationsLinus Walleij
By rearranging the functions in the semihosting code we can avoid forward-declaration of the internal static functions. This puts the stuff in a logical order: read/open/close/len and then higher-order functions follow at the end. Cc: Darwin Rambo <drambo@broadcom.com> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Mark Hambleton <mark.hambleton@arm.com> Cc: Tom Rini <trini@ti.com> Acked-by: Steve Rae <srae@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-29arm: semihosting: fix up compile bugsLinus Walleij
There is currently a regression when using newer ARM64 compilers for semihosting: the way long types are inferred from context is no longer the same. The semihosting runtime uses long and size_t, so use this explicitly in the semihosting code and interface, and voila: the code now works again. Tested with aarch64-linux-gnu-gcc: Linaro GCC 4.9-2014.09. Cc: Darwin Rambo <drambo@broadcom.com> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Mark Hambleton <mark.hambleton@arm.com> Cc: Tom Rini <trini@ti.com> Acked-by: Steve Rae <srae@broadcom.com> Suggested-by: Mark Hambleton <mark.hambleton@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-29arm: semihosting: staticize internal functionsLinus Walleij
The semihosting code exposes internal file handle handling functions to read(), open(), close() and get the length of a certain file handle. However the code using it is only interested in either reading and entire named file into memory or getting the file length of a file referred by name. No file handles are used. Thus make the file handle code internal to this file by removing these functions from the semihosting header file and staticize them. This gives us some freedom to rearrange the semihosting code without affecting the external interface. Cc: Darwin Rambo <drambo@broadcom.com> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Cc: Mark Hambleton <mark.hambleton@arm.com> Cc: Tom Rini <trini@ti.com> Acked-by: Steve Rae <srae@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-18x86: Clean up the FSP support codesBin Meng
This is the follow-on patch to clean up the FSP support codes: - Remove the _t suffix on the structures defines - Use __packed for structure defines - Use U-Boot's assert() - Use standard bool true/false - Remove read_unaligned64() - Use memcmp() in the compare_guid() - Remove the cast in the memset() call - Replace some magic numbers with macros - Use panic() when no valid FSP image header is found - Change some FSP utility routines to use an fsp_ prefix - Add comment blocks for asm_continuation and fsp_init_done - Remove some casts in find_fsp_header() - Change HOB access macros to static inline routines - Add comments to mention find_fsp_header() may be called in a stackless environment - Add comments to mention init(&params) in fsp_init() cannot be removed Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Rename coreboot-serial to x86-serialBin Meng
2014-12-18x86: crownbay: Add SDHCI supportBin Meng
There are two standard SD card slots on the Crown Bay board, which are connected to the Topcliff PCH SDIO controllers. Enable the SDHC support so that we can use them. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: crownbay: Add SPI flash supportBin Meng
The Crown Bay board has an SST25VF016B flash connected to the Tunnel Creek processor SPI controller used as the BIOS media where U-Boot is stored. Enable this flash support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Use consistent name XXX_ADDR for binary blob flash addressBin Meng
2014-12-18x86: Add queensbay and crownbay Kconfig filesBin Meng
2014-12-18x86: Enable the queensbay cpu directory buildBin Meng
2014-12-18x86: ich6-gpio: Add Intel Tunnel Creek GPIO supportBin Meng
Intel Tunnel Creek GPIO register block is compatible with current ich6-gpio driver, except the offset and content of GPIO block base address register in the LPC PCI configuration space are different. Use u16 instead of u32 to store the 16-bit I/O address of the GPIO registers so that it could support both Ivybridge and Tunnel Creek. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Convert microcode format to device-tree-onlySimon Glass
To avoid having two microcode formats, adjust the build system to support obtaining the microcode from the device tree, even in the case where it must be made available before the device tree can be accessed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-18x86: Add basic support to queensbay platform and crownbay boardBin Meng
Implement minimum required functions for the basic support to queensbay platform and crownbay board. Currently the implementation is to call fsp_init() in the car_init(). We may move that call to cpu_init_f() in the future. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Integrate Tunnel Creek processor microcodeBin Meng
Integrate the processor microcode version 1.05 for Tunnel Creek, CPUID device 20661h. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Correct problems in the microcode loadingSimon Glass
There are several problems in the code. The device tree decode is incorrect in ways that are masked due to a matching bug. Both are fixed. Also microcode_read_rev() should be inline and called before the microcode is written. Note: microcode writing does not work correctly on ivybridge for me. Further work is needed to resolve this. But this patch tidies up the existing code so that will be easier. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: ivybridge: Update the microcodeSimon Glass
There are new microcode revisions available. Update them. Also change the format so that the first 48 bytes are not omitted from the device tree data. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-18x86: Move microcode updates into a separate directorySimon Glass
We might end up with a few of these, so put them in their own directory. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-18ARM: UniPhier: select CONFIG_SPLMasahiro Yamada
Now UniPhier platform is only supported with SPL. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-18ARM: UniPhier: remove unnecessary ifdef conditionalMasahiro Yamada
init_page_table is only set on SPL. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-18ARM: UniPhier: fix property names of aliases nodes of device treesMasahiro Yamada
The property name of the "aliases" node should be "serial*" to assign a desired number for the device sequence number. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-16Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-12-16Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2014-12-15p5040ds: changed liodn offsetsTudor Laurentiu
Offsets were overlaping, causing pamu access violations in hypervised scenarios. Signed-off-by: Cristian Sovaiala <cristian.sovaiala@freescale.com> Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-15mpc85xx: inhibit qman and bman portals by defaultJeffrey Ladouceur
Not all portals might be managed and therefore visible. Set the isdr register so that the corresponding isr register won't be set. This is required when supporting power management. Signed-off-by: Jeffrey Ladouceur <Jeffrey.Ladouceur@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-15powerpc/mpc85xx: Fix DDR TLB mapping leftoverYork Sun
Commit f29f804a93e87c17670607641d120f431a3b0633 generalized the TLB mapping function, but made the DDR mapping leftover size to zero, causing the message not printed. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alexander Graf <agraf@suse.de> CC: Scott Wood <scottwood@freescale.com>
2014-12-15x86: move arch-specific asmlinkage to <asm/linkage.h>Masahiro Yamada
Commit 65dd74a674d6 (x86: ivybridge: Implement SDRAM init) introduced x86-specific asmlinkage into arch/x86/include/asm/config.h. Commit ed0a2fbf14f7 (x86: Add a definition of asmlinkage) added the same macro define again, this time, into include/common.h. (Please do not add arch-specific stuff to include/common.h any more; it is already too cluttered.) The generic asmlinkage is defined in <linux/linkage.h>. If you want to override it with an arch-specific one, the best way is to add it to <asm/linkage.h> like Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Add a simple command to show FSP HOB informationBin Meng
FSP builds a series of data structures called the Hand-Off-Blocks (HOBs) as it progresses through initializing the silicon. These data structures conform to the HOB format as described in the Platform Initialization (PI) specification Volume 3 Shared Architectual Elements specification, which is part of the UEFI specification. Create a simple command to parse the HOB list to display the HOB address, type and length in bytes. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Support Intel FSP initialization path in start.SBin Meng
Per Intel FSP architecture specification, FSP provides 3 routines for bootloader to call. The first one is the TempRamInit (aka Cache-As-Ram initialization) and the second one is the FspInit which does the memory bring up (like MRC for other x86 targets) and chipset initialization. Those two routines have to be called before U-Boot jumping to board_init_f in start.S. The FspInit() will return several memory blocks called Hand Off Blocks (HOBs) whose format is described in Platform Initialization (PI) specification (part of the UEFI specication) to the bootloader. Save this HOB address to the U-Boot global data for later use. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Add post failure codes for bist and carBin Meng
2014-12-13x86: queensbay: Adapt FSP support codesBin Meng
Use inline assembly codes to call FspNotify() to make sure parameters are passed on the stack as required by the FSP calling convention. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-13x86: Initial import from Intel FSP release for Queensbay platformBin Meng
This is the initial import from Intel FSP release for Queensbay platform (Tunnel Creek processor and Topcliff Platform Controller Hub), which can be downloaded from Intel website. For more details, check http://www.intel.com/fsp. Note: U-Boot coding convention was applied to these codes, so it looks completely different from the original Intel release. Also update FSP support codes license header to use SPDX ID. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2014-12-13x86: Add a simple superio driver for SMSC LPC47MBin Meng
On most x86 boards, the legacy serial ports (io address 0x3f8/0x2f8) are provided by a superio chip connected to the LPC bus. We must program the superio chip so that serial ports are available for us. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Add Intel Crown Bay board dts fileBin Meng
2014-12-13x86: ich6-gpio: Move setup_pch_gpios() to board support codesBin Meng
Movie setup_pch_gpios() in the ich6-gpio driver to the board support codes, so that the driver does not need to know any platform specific stuff (ie: include the platform specifc chipset header file). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Clean up asm-offsetsBin Meng
Move GD_BIST from lib/asm-offsets.c to arch/x86/lib/asm-offsets.c as it is x86 arch specific stuff. Also remove GENERATED_GD_RELOC_OFF which is not referenced anymore. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-13x86: Make ROM_SIZE configurable in KconfigBin Meng
Currently the ROM_SIZE is hardcoded to 8MB in arch/x86/Kconfig. This will not be the case when adding additional board support. Hence we make ROM_SIZE configurable (512KB/1MB/2MB/4MB/8MB/16MB) and have the board Kconfig file select the default ROM_SIZE. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-11Merge git://git.denx.de/u-boot-dmTom Rini
2014-12-11Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Conflicts: board/freescale/mx6sxsabresd/mx6sxsabresd.c Signed-off-by: Tom Rini <trini@ti.com>
2014-12-11Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11ARM: tegra: Add support for nyan-big boardAllen Martin
Nyan-big is a Tegra124 clamshell board that is very similar to venice2, but it has a different panel, the sdcard cd and wp sense are flipped, and it has a different revision of the AS3722 PMIC. This is the Acer Chromebook 13 CB5-311-T7NN (13.3-inch HD, NVIDIA Tegra K1, 2GB). The display is not currently supported, so it should boot on other nyan-based Chromebooks also, but only the device tree for nyan-big is provided here. The device tree file is from Linux but with features removed which are unlikely to be supported in U-Boot soon (regulators, pinmux). Also the addresses are updated to 32-bit. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> (rebase, change to 'nyan-big', fix pinmux that resets nyan-big)
2014-12-11tegra: dts: Sync tegra124.dtsi with linux kernelSimon Glass
Sync this up with Linux v3.18-rc5. Exclude features that are unlikely to supported in U-Boot soon (regulators, pinmux). Also the addresses are updated to 32-bit. Otherwise it is the same. Also bring in the dt-bindings for pinctrl. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-12-11dts: Bring in Chrome OS keyboard device tree definitionSimon Glass
This will be used by nyan-big, but bring it in in a separate patch since it will be common to other boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11dm: i2c: dts: Add an I2C bus for sandboxSimon Glass
Add an I2C bus to the device tree, with an EEPROM emulator attached to one of the addresses. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-11dm: i2c: Add an I2C EEPROM simulatorSimon Glass
To enable testing of I2C, add a simple I2C EEPROM simulator for sandbox. It supports reading and writing from a small data store. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-11kconfig: ls102xa: Change the prompt messagesAlison Wang
As NOR/NAND/SD boot are all supported on LS1021AQDS/TWR boards, the prompt message "Support ls1021aqds_nor" in Kconfig is not clear. This patch changes it to "Support ls1021aqds". Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ARM: ls102xa: Setting device's stream id for SMMUs.Xiubo Li
LS1 has 4 SMMUs for address translation of the masters. All the SMMUs' stream IDs are 8-bit. The address translation depends on the stream ID of the incoming transaction. Each master has unique stream ID assigned to it and is configurable through SCFG registers. The stream ID for the masters is identical and share the same register field of STREAM ID registers. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11ARM: ls102xa: allow all the peripheral access permission as R/W.Xiubo Li
The Central Security Unit (CSU) allows secure world software to change the default access control policies of peripherals/bus slaves, determining which bus masters may access them. This allows peripherals to be separated into distinct security domains. Combined with SMMU configuration of the system masters privileges, these features provide protection against indirect unauthorized access to data. For now we configure all the peripheral access permissions as R/W. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
