path: root/board/Arcturus
2020-01-17common: Move clock functions into a new fileSimon Glass
These three clock functions don't use driver model and should be migrated. In the meantime, create a new file to hold them. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move relocate_code() to init.hSimon Glass
This is an init function so move it out of the common header. Avoid using the typedef so that we don't have to include the global_data header file. Also tidy up the function style in comments while we are here. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move ARM cache operations out of common.hSimon Glass
These functions are CPU-related and do not use driver model. Move them to cpu_func.h Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02Move strtomhz() to vsprintf.hSimon Glass
At present this function sits in its own file but it does not really justify it. There are similar string functions in vsprintf.h, so move it there. Also add the missing function comment. Use the vsprintf.h include file explicitly where needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_init() to env.hSimon Glass
Move env_init() over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-06-21board: Arcturus: DM: Disable drivers without DM support.Oleksandr Zhadan
Extra "not DM" controllers support is disabled. u-boot BSP still good enough to upgrade and run images. Signed-off-by: Oleksandr Zhadan <oleks@arcturusnetworks.com> Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
2018-05-07SPDX: Convert all of our multiple license tags to Linux Kernel styleTom Rini
When U-Boot started using SPDX tags we were among the early adopters and there weren't a lot of other examples to borrow from. So we picked the area of the file that usually had a full license text and replaced it with an appropriate SPDX-License-Identifier: entry. Since then, the Linux Kernel has adopted SPDX tags and they place it as the very first line in a file (except where shebangs are used, then it's second line) and with slightly different comment styles than us. In part due to community overlap, in part due to better tag visibility and in part for other minor reasons, switch over to that style. This commit changes all instances where we have multiple licenses (in these cases, dual license) declared in the SPDX-License-Identifier tag. In this case we change from listing "LICENSE-A LICENSE-B" or "LICENSE-A or LICENSE-B" or "(LICENSE-A OR LICENSE-B)" to "LICENSE-A OR LICENSE-B" as per the Linux Kernel style document. Note that parenthesis are allowed so when they were used before we continue to use them. Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-12-06powerpc: mpc85xx: Fix static TLB table for SDRAMYork Sun
Most predefined TLB tables don't have memory coherence bit set for SDRAM. This wasn't an issue before invalidate_dcache_range() function was enabled. Without the coherence bit, dcache invalidation doesn't automatically flush the cache. The coherence bit is already set when dynamic TLB table is used. For some boards with different SPL boot method, or with legacy fixed setting, this bit needs to be set in TLB files. Signed-off-by: York Sun <york.sun@nxp.com>
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-15env: Add an enum for environment stateSimon Glass
At present we have three states for the environment, numbered 0, 1 and 2. Add an enum to record this to avoid open-coded values. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-01-25powerpc: Drop probecpu() in favour of arch_cpu_init()Simon Glass
To avoid an unnecessary arch-specific call in board_init_f(), rename this function. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-06spi: Move freescale-specific code into a private headerSimon Glass
At present there are two SPI functions only used by freescale which are defined in the spi_flash.h header. One function name matches an existing generic SPL function. Move these into a private header to avoid confusion. Arcturus looks like it does not actually support SPI, so drop the SPI code from that board. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-04powerpc/mpc85xx: Add board support for ucp1020Oleksandr G Zhadan
New QorIQ p1020 based board support from Arcturus Networks Inc. http://www.arcturusnetworks.com/products/ucp1020/ Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com> Signed-off-by: Oleksandr G Zhadan <oleks@arcturusnetworks.com> [York Sun: remove patman tags from commit message] Reviewed-by: York Sun <yorksun@freescale.com>
