path: root/board/CZ.NIC
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set_ulong() to env.hSimon Glass
Move env_set_ulong() over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-07-11arm: mvebu: turris_omnia: fix rescue mode bootcmd bootargs settingMarek Behún
Rescue mode bootcmd currently only appends the "omniarescue" parameter to the bootargs variable. We do not want the user to be able to change rescue mode bootargs. Therefore change this so that bootcmd sets the bootargs variable in an absolute way (adding console device information and the omniarescue paramterer). Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-07-11arm: mvebu: turris_omnia: call pci_init from board init codeMarek Behún
We always want to enumerate PCIe devices, because withouth this they won't work in Linux. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-07-11arm: mvebu: turris_omnia: fix adapters MAC addressesMarek Behún
The board code reads MAC addresses from the ATSHA204A cryptochip. For compatibility reasons the ethernet adapters on this SOC are not enumerated in register address order. But when Omnia was first manufactured this was done differently. Change setting of MAC addresses to conform to the description on the stickers sticked on actual Omnias. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: add RESET button handlingMarek Behún
There is a Factory RESET button on the back side of the Turris Omnia router. When user presses this button before powering the device up and keeps it pressed, the microcontroller prevents the main CPU from booting and counts how long the RESET button is being pressed (and indicates this by lighting up front LEDs). The idea behind this is that the user can boot the device into several Factory RESET modes. This patch adds support for U-Boot to read into which Factory RESET mode the user booted the device. The value is an integer stored into the omnia_reset environment variable. It is 0 if the button was not pressed at all during power up, otherwise it is the number identifying the Factory RESET mode. This patch also changes bootcmd to a special hardcoded value if Factory RESET button was pressed during device powerup. This special bootcmd value sets the colors of all the LEDs on the front panel to green and then tries to load the rescue image from the SPI flash memory and boot it. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: fix regdomain env var settingMarek Behún
The regdomain environment variable is set according to value read from EEPROM. This has to be done in board_late_init, after the environment variables are read from SPI. Select CONFIG_BOARD_LATE_INIT in Kconfig for the Turris Omnia target. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_*: remove watchdog includeMarek Behún
Since board watchdog is now unified and not handled in board files, remove the unnecessary includes. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: print board info as Turris MoxMarek Behún
Unify the way how Omnia and Mox print board information (RAM size and serial number). Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: refactor more codeMarek Behún
Refactor RAM size reading from EEPROM in preparation for next patch. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: move ATSHA204A from defconfig to KconfigMarek Behún
This driver is required for Turris Omnia to read ethernet addresses. Move the dependency from turris_omnia_defconfig to Kconfig. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: fix checkpatch warningsMarek Behún
2019-05-03arm: mvebu: turris_omnia: refactor I2C accessing codeMarek Behún
Refactor code which accesses the microcontroller and EEPROM via I2C. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-03arm: mvebu: turris_omnia: remove redundant codeMarek Behún
The i2c slave disabling is done by mvtwsi driver and is not needed here. Signed-off-by: Marek Behún <marek.behun@nic.cz> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-26watchdog: Implement generic watchdog_reset() versionStefan Roese
This patch tries to implement a generic watchdog_reset() function that can be used by all boards that want to service the watchdog device in U-Boot. This watchdog servicing is enabled via CONFIG_WATCHDOG. Without this approach, new boards or platforms needed to implement a board specific version of this functionality, mostly copy'ing the same code over and over again into their board or platforms code base. With this new generic function, the scattered other functions are now removed to be replaced by the generic one. The new version also enables the configuration of the watchdog timeout via the DT "timeout-sec" property (if enabled via CONFIG_OF_CONTROL). This patch also adds a new flag to the GD flags, to flag that the watchdog is ready to use and adds the pointer to the watchdog device to the GD. This enables us to remove the global "watchdog_dev" variable, which was prone to cause problems because of its potentially very early use in watchdog_reset(), even before the BSS is cleared. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: "Marek Behún" <marek.behun@nic.cz> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Maxim Sloyko <maxims@google.com> Cc: Erik van Luijk <evanluijk@interact.nl> Cc: Ryder Lee <ryder.lee@mediatek.com> Cc: Weijie Gao <weijie.gao@mediatek.com> Cc: Simon Glass <sjg@chromium.org> Cc: "Álvaro Fernández Rojas" <noltari@gmail.com> Cc: Philippe Reynes <philippe.reynes@softathome.com> Cc: Christophe Leroy <christophe.leroy@c-s.fr> Reviewed-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Michal Simek <michal.simek@xilinx.com> (on zcu100)
2019-04-26arm: mvebu: turris_omnia: fix eeprom/mcu device namesPierre Bourdon
Commit c4bd12a7dad4 ("i2c: mux: Generate longer i2c mux name") changed the naming scheme of i2c devices within a mux. This broke references to i2c@0 in the Turris Omnia board initialization code. Signed-off-by: Pierre Bourdon <delroth@gmail.com> Cc: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Marek Behún <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-12watchdog: orion_wdt: take timeout value in msChris Packham
The generic wdt_start API expects to be called with the timeout in milliseconds. Update the orion_wdt driver to accept a timeout in milliseconds and use the clock rate specified in the dts to convert the timeout to an appropriate value for the timer reload register. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-04-08watchdog: Move watchdog_dev to data section (BSS may not be cleared)Stefan Roese
This patch moves all instances of static "watchdog_dev" declarations to the "data" section. This may be needed, as the BSS may not be cleared in the early U-Boot phase, where watchdog_reset() is already beeing called. This may result in incorrect pointer access, as the check to "!watchdog_dev" in watchdog_reset() may not be true and the function may continue to run. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: "Marek Behún" <marek.behun@nic.cz> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-by: Michal Simek <michal.simek@xilinx.com> (on zcu100) Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2019-01-21arm: mvebu: turris_mox: Support 1 GB version of Turris MoxMarek Behún
Use get_ram_size to determine if the RAM size on Turris Mox is 512 MiB or 1 GiB. Signed-off-by: Marek Behún <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2019-01-21arm: mvebu: turris_mox: Read info (and ethaddrs) from OTPMarek Behún
Add support for reading One-Time Programmable memory via mailbox, which communicates with CZ.NIC's firmware on the Secure Processor (Cortex-M3) of Armada 3720. Display product serial number and additional info, and also set MAC addresses. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-01-21arm: mvebu: turris_mox: Check and configure modulesMarek Behún
Check if Mox modules are connected in supported mode, then configure the MDIO addresses of switch modules. Signed-off-by: Marek Behún <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2019-01-21arm: mvebu: turris_mox: Change SERDES map depending on module topologyMarek Behún
When SFP module is connected directly to CPU module we want the SGMII lane speed at 1.25 Gbps. This is a temporary solution till there is a comphy driver in the kernel capable of changing SGMII speed at runtime. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-01-21arm: mvebu: turris_mox: Cosmetic restructurizationMarek Behún
Restructure the board initialization source. Remove the module_topology environment variable since it won't be needed. Signed-off-by: Marek Behún <marek.behun@nic.cz> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-12-08ARM: mvebu: a38x: sync ddr training code with mv_ddr-armada-18.09.02Chris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-18.09 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. Specifically this syncs with commit 99d772547314 ("Bump mv_ddr to release armada-18.09.2"). The complete log of changes is best obtained from the mv-ddr-marvell.git repository but some relevant highlights are: ddr3: add missing txsdll parameter ddr3: fix tfaw timimg parameter ddr3: fix trrd timimg parameter merge ddr3 topology header file with mv_ddr_topology one mv_ddr: a38x: fix zero memory size scrubbing issue The upstream code is incorporated omitting the portions not relevant to Armada-38x and DDR3. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT -UCONFIG_A3700 -UA3900 -UA80X0 \ -UA70X0 Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-09-19board: turris_mox: Fixup U-Boot's device tree if PCIe connectedMarek Behún
If PCIe Mox module is connected we want to have PCIe node enabled in U-Boot's device tree. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2018-09-19board: turris_mox: Fix watchdog macro nameMarek Behún
The macro name CONFIG_WDT_ARMADA_3720 is called CONFIG_WDT_ARMADA_37XX instead. Fix this so that watchdog really is enabled in board_init. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-06mvebu: select boot device at SoC levelBaruch Siach
Move the gdsys Controlcenter DC specific build time kwbimage.cfg generation code into the mach-mvebu/ directory to be shared by all 32bit mvebu platforms. Remove board specific kwbimage.cfg files, and use the generated one instead. These files are all identical, with two exceptions. Clearfog and Helios4 use the sdio boot device, whereas all others use spi. Update the defconfigs for the exceptional boards to generate the same kwbimage.cfg as before. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-06mvebu: turris_omnia: use u-boot-spl-dtb.binBaruch Siach
u-boot-spl.bin and u-boot-spl-dtb.bin are identical when building the turris_omnia_defconfig. This commit makes Turris Omnia consistent with all other mvebu boards. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-07mvebu: turris_omnia: add note about i2c slave disableBaruch Siach
Code that disables the i2c slave is now in the mvtwsi i2c driver. Platform must enable DM_I2C to use that code. Add a comment in the code as a reminder for the planned DM_I2C migration of Turris Omnia. Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Baruch Siach <baruch@tkos.co.il>
2018-05-14ARM: mvebu: a38x: restore support for setting timingChris Packham
This restores support for configuring the timing mode based on the ddr_topology. This was originally implemented in commit 90bcc3d38d2b ("driver/ddr: Add support for setting timing in hws_topology_map") but was removed as part of the upstream sync. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14ARM: mvebu: a38x: sync ddr training code with upstreamChris Packham
This syncs drivers/ddr/marvell/a38x/ with the mv_ddr-armada-17.10 branch of https://github.com/MarvellEmbeddedProcessors/mv-ddr-marvell.git. The upstream code is incorporated omitting the ddr4 and apn806 and folding the nested a38x directory up one level. After that a semi-automated step is used to drop unused features with unifdef find drivers/ddr/marvell/a38x/ -name '*.[ch]' | \ xargs unifdef -m -UMV_DDR -UMV_DDR_ATF -UCONFIG_DDR4 \ -UCONFIG_APN806 -UCONFIG_MC_STATIC \ -UCONFIG_MC_STATIC_PRINT -UCONFIG_PHY_STATIC \ -UCONFIG_64BIT INTER_REGS_BASE is updated to be defined as SOC_REGS_PHY_BASE. Some now empty files are removed and the ternary license is replaced with a SPDX GPL-2.0+ identifier. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-05-14arm64: mvebu: Add basic support for the Turris Mox boardMarek Behún
This adds basic support for the Turris Mox board from CZ.NIC, which is currently being crowdfunded on Indiegogo. Turris Mox is as modular router based on the Armada 3720 SOC (same as EspressoBin). The basic module can be extended by different modules. The device tree binary for the kernel can be dependent on which modules are connected, and in what order. Because of this, the board specific code creates in U-Boot a variable called module_topology, which carries this information. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2017-11-30arm: mvebu: correct comments around cas_wl/cas_lChris Packham
The order of members in struct hws_topology_map is cas_wl, cas_l. The comments in the original db-88f6820-gp.c had this wrong and have been copied to other Armada-385 based boards. Practically this hasn't made a difference since all these boards set both cas_wl and cas_l to 0 (autodetect) but if there were ever a board that did need to set these explicitly they would run into unexpected issued. Update the comments to reflect the correct order of structure members. Reported-by: Tobi Wulff <tobi.wulff@alliedtelesis.co.nz> Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2017-11-06MAINTAINERS: Add missing boards and config entriesTom Rini
As part of my usual round of build testing, output about missing MAINTAINERS information was not logged, and thus often overlooked. Correct that mistake by ensuring that I log the output of genboardscfg.py every time. As part of that, address a number of missing MAINTAINERS entires. In the case of a missing file, I have put the original submitter down. In the rest of the cases I have added the config (and sometimes relevant header file) to the existing set of file globs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-08mvebu: turris_omnia: Fix PEX vs SATA detection for board topologyMarek Behún
The I2C reading in the PEX vs SATA detection code often fails on the first try. Try three times, as the code for EEPROM reading does. Signed-off-by: Marek Behun <marek.behun@nic.cz> Signed-off-by: Stefan Roese <sr@denx.de>
2017-07-12marvell: armada385: Add the Turris Omnia boardMarek Behún
The Turris Omnia is a open-source router created by CZ.NIC. The code is based on the Marvell/db-88f6820-gp by Stefan Roese with modifications from Tomas Hlavacek in the CZ.NIC turris-omnia-uboot repository, which can be found at https://gitlab.labs.nic.cz/turris/turris-omnia-uboot By default, the Turris Omnia uses btrfs as the main and only filesystem, and also loads kernel and device tree from this filesystem. Since U-Boot does not yet support btrfs, you should not flash your Turris Omnia board with this unless you know what you are doing. Signed-off-by: Tomas Hlavacek <tomas.hlavacek@nic.cz> Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 board/CZ.NIC/turris_omnia/Makefile create mode 100644 board/CZ.NIC/turris_omnia/kwbimage.cfg create mode 100644 board/CZ.NIC/turris_omnia/turris_omnia.c create mode 100644 configs/turris_omnia_defconfig create mode 100644 include/configs/turris_omnia.h Signed-off-by: Stefan Roese <sr@denx.de>
