path: root/board/LaCie
2015-10-19Revert "arm: Remove d2net_v2 defconfig file"Tom Rini
Upon further review when populating README.scrapyard, d2net_v2 is a variant on net2big_v2 and not just an orphan config. To help in the future also add this to board/LaCie/net2big_v2/MAINTAINERS which needed a little consolidation anyhow. This reverts commit 1363740e7948a8e4bee8d5adcdf0f63f7782879d. Cc: Simon Guinot <simon.guinot@sequanux.org> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-28arm: Remove wireless_space boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-25edminiv2: drop CONFIG_CFI_LEGACYAlbert ARIBAUD
Nowadays generic CFI code properly detects the ED Mini V2's Macronix MC29LV400CB flash chip, therefore we can drop the CONFIG_FLASH_CFI_LEGACY option and associated settings and code. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-02-25edminiv2: switch to SPLAlbert ARIBAUD
ED Mini V2 is based on Orion 5x which boots at fixed address 0xFFFF0000 in NOR Flash. Place SPL there, and switch U-Boot from .bin to .img format, stored in NOR Flash at 0xFFF90000. Note: this patch was tested on HW and works, i.e. it boots U-Boot properly, but SPL console output currently does not appear, due to GD being trashed by arch/arm/lib/spl.c. This trashing is soon to be removed, and then ED Mini V2 SPL console output will become visible. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-02-25edminiv2: switch to generic board supportAlbert ARIBAUD
2014-10-27wireless_space: set myself as maintainerAlbert ARIBAUD
LaCie Wireless Space has no defined maintainer. Set myself as maintainer, since I own one of these. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-10-23arm: kirkwood: Change naming of dram functions from km_foo() to mvebu_foo()Stefan Roese
Additionally the SDRAM address decoding register address is not hard coded in the C code any more. A define is introduced for this base address. This makes is possible to use those gpio functions from other MVEBU SoC's as well. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-23arm: marvell: Extract kirkwood gpio functions into new common file gpio.cStefan Roese
2014-10-23arm: marvell: Move arch/kirkwood.h to arch/soc.hStefan Roese
This move makes is possible to use this header not only from kirkwood platforms but from all Marvell mvebu platforms. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30orion5x: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Orion5x board select menu to orion5x/Kconfig. Move also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="orion5x"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-06-20net2big_v2: initialize LEDs at startupSimon Guinot
This patch allows to configure the net2big_v2 LEDs at startup (through the GPIO extension bus). The front blue LED is enabled and the SATA rear LEDs are configured to blink in relation with the SATA activity. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2013-06-20LaCie/common: add support for the CPLD GPIO busSimon Guinot
This patch adds support for the CPLD GPIO bus found on some LaCie boards (as the 2Big/5Big Network v2 and the 2Big NAS). This parallel GPIO bus exposes two registers (address and data). Each of this register is made up of several dedicated GPIOs. An extra GPIO is used to notify the CPLD that the registers have been updated. Mostly this bus is used to configure the LEDs on LaCie boards. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2013-06-20net2big_v2: initialize I2C fan at startupSimon Guinot
This patch ensures minimal cooling for the net2big_v2 by automatically starting the I2C fan (GMT G762) at low speed (2800 RPM). Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-01-09ARM: lacie_kw: add support for WIRELESS_SPACEAlbert ARIBAUD
2013-01-09kirkwood: make MPP arrays static constAlbert ARIBAUD
This saves stack and code memory for local copy, and consumes initialized data memory. For 22 of the 29 kirkwood-based boards, this results in a global saving of about 30 bytes. For 7 of them, it results in an increase of 6 to 14 bytes. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-03ARM: add support for Network Space v2 Lite and MiniSimon Guinot
This patch adds support for the LaCie boards Network Space v2 (Lite and Mini). This two boards are derived from the Network Space v2 and a lot of hardware caracteristics are shared. - CPU: Marvell 88F6192 800Mhz - SDRAM memory: 128MB DDR2 200Mhz - 1 SATA port: internal - Gigabit ethernet: PHY Marvell 88E1318 - Flash memory: SPI NOR 512KB (Macronix MX25L4005A) - i2c EEPROM: 512 bytes (24C04 type) - 2 USB2 ports (Lite only): host and host/device - 1 push button - 1 SATA LED (bi-color, blue and red) Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-07-07ARM: don't probe PHY address for LaCie boardsSimon Guinot
The command miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr) always returns 8 for the PHY address. It is the reset value for the PHY Address Register. Obviously, this default value could be incorrect. Moreover, as the PHY address is well known, there is no need to auto-detect it. Now, the PHY address must given as a parameter to the PHY initialization function. Additionally this patch also fixes some aesthetic issues. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-07-07kirkwood: fix calls to kirkwood_mpp_confValentin Longchamp
With the new second save argument introduced by the previous patch, all the calls to the function had to be fixed. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-12-10board/LaCie/edminiv2/edminiv2.c: Fix build warningWolfgang Denk
Fix: edminiv2.c: In function 'reset_phy': edminiv2.c:98:2: warning: implicit declaration of function 'mv_phy_88e1116_init' [-Wimplicit-function-declaration] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Guinot <simon.guinot@sequanux.org>
2011-12-06ARM: remove duplicated code for LaCie boardsSimon Guinot
This patch groups together all the common functions for LaCie boards: Ethernet PHY and MAC address initializations. Moreover the configurations for LaCie Kirkwood boards are merged into a single file: include/configs/lacie_kw.h Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2011-12-06ARM: add support for LaCie 2Big Network v2Simon Guinot
This patch adds support for the LaCie 2Big Network v2 board, based on the Marvell Kirkwood 6281 SoC. Additional information is available at: http://lacie-nas.org/doku.php?id=2big_network_v2 Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2011-12-06netspace_v2: Read Ethernet MAC address from EEPROMSimon Guinot
2011-11-03netspace_v2: fix SDRAM configurationSimon Guinot
Network Space (Max) v2 and Internet Space v2 boards have different SDRAM configuration and size: respectively 256MB (DDR2 1Gb, 128Mbx8 organisation) and 128MB (DDR2 512Mb, 64Mbx8 organisation). To handle the differences, this patch add a dedicated kwimage.cfg file for Internet Space v2. Additionnaly the number of SDRAM banks is fixed. Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2011-11-03ARM: netspace_v2: fix warningsAnatolij Gustschin
Fix compiler warnings when compiling for netspace_v2, netspace_max_v2 and inetspace_v2: netspace_v2.c: In function 'board_early_init_f': netspace_v2.c:37: warning: implicit declaration of function 'kw_config_gpio' netspace_v2.c: In function 'board_init': netspace_v2.c:86: warning: implicit declaration of function 'kw_sdram_bar' Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Simon Guinot <simon.guinot@sequanux.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-07-04Add support for Network Space v2 and parentsSimon Guinot
This patch add support for the Network Space v2 board and parents, based on the Marvell Kirkwood 6281 SoC. This include Network Space (Max) v2 and Internet Space v2. Additional information is available at: http://lacie-nas.org/doku.php?id=network_space_v2 Signed-off-by: Simon Guinot <sguinot@lacie.com>
2011-04-27Replace obsolete e-mail addressAlbert ARIBAUD
2010-10-19Merge branch 'elf_reloc'Wolfgang Denk
Conflicts: arch/arm/include/asm/config.h board/LaCie/edminiv2/config.mk board/karo/tx25/config.mk board/logicpd/imx27lite/config.mk doc/README.arm-relocation Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-13edminiv2: add support for ELF relocationsAlbert Aribaud
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-07-12edminiv2: add ethernet supportAlbert Aribaud
Add edminiv2 board support for mv_egiga. Add edminiv2 config to enable mv_egiga. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-17Add support for the LaCie ED Mini V2 boardAlbert Aribaud
This patch adds support for the LaCie ED Mini V2 product which is based on the Marvell Orion5x SoC. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
