path: root/board/advantech
2016-09-06arm: imx: Add support for Advantech DMS-BA16 boardAkshay Bhat
Add support for Advantech DMS-BA16 board. The board is based on Advantech BA16 module which has a i.MX6D processor. The board supports: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: u-boot@lists.denx.de Cc: sbabic@denx.de
2016-07-12x86: Add Advantech SOM-DB5800/SOM-6867 supportGeorge McCollister
Add support for Advantech SOM-DB5800 with the SOM-6867 installed. This is very similar to conga-qeval20-qa3-e3845 in that there is a reference carrier board (SOM-DB5800) with a Baytrail based SoM (SOM-6867) installed. Currently supported: - 2x UART (From ITE EC on SOM-6867) routed to COM3/4 connectors on SOM-DB5800. - 4x USB 2.0 (EHCI) - Video - SATA - Ethernet - PCIe - Realtek ALC892 HD Audio Pad configuration for HDA_RSTB, HDA_SYNC, HDA_CLK, HDA_SDO HDA_SDI0 is set in DT to enable HD Audio codec. Pin defaults for codec pin complexs are not changed. Not supported: - Winbond Super I/O (Must be disabled with jumpers on SOM-DB8500) - USB 3.0 (XHCI) - TPM Signed-off-by: George McCollister <george.mccollister@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
