path: root/board/canmb/canmb.c
2010-09-19canmb board: Fix compiler warningsWolfgang Denk
Recent changes caused thatthe aev board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: canmb.c: In function 'initdram': canmb.c:109: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:111: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:137: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:140: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness Fix these. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-04-21Fix bug in the SDRAM initialization code for canmb, IceCube andwdenk
PM520 boards. Fix PHY address for canmb board.
2005-04-20Auto-size RAM on canmb board.wdenk
Cleanup.
2005-04-13Add support for canmb boardLABEL_2005_04_14_0115wdenk
