path: root/board/canmb
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-19canmb board: Fix compiler warningsWolfgang Denk
Recent changes caused thatthe aev board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: canmb.c: In function 'initdram': canmb.c:109: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:111: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:137: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness canmb.c:140: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness Fix these. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2007-07-04Remove obsolete mpc5xxx linker scripts (2 of 3)Grant Likely
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-04-21Fix bug in the SDRAM initialization code for canmb, IceCube andwdenk
PM520 boards. Fix PHY address for canmb board.
2005-04-20Cleanup serial console baudrate calculation on AT91RM9200wdenk
2005-04-20Auto-size RAM on canmb board.wdenk
Cleanup.
2005-04-13Add support for canmb boardLABEL_2005_04_14_0115wdenk
