path: root/board/cavium
2016-07-15armv8: mmu: Add support of non-identical mappingYork Sun
Introduce virtual and physical addresses in the mapping table. This change have no impact on existing boards because they all use idential mapping. Signed-off-by: York Sun <york.sun@nxp.com>
2016-03-15thunderx: Move mmu table into board fileAlexander Graf
The MMU range table can vary depending on things we may only find out at runtime. While the very simple ThunderX variant does not change, other boards will, so move the definition from a static entry in a header file to the board file. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-01-19armv8: cavium: Get DRAM size from ATFSergey Temerkhanov
Change the dram_init() function on ThunderX to query ATF services for the real installed DRAM size Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
2016-01-19armv8: cavium: Add an implementation of ATF calling functionsSergey Temerkhanov
This commit adds functions issuing calls to the product-specific ATF services Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
2016-01-19armv8: cavium: Add ThunderX 88xx board definitionSergey Temerkhanov
This commit adds basic Cavium ThunderX 88xx board definitions and support. Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> [trini: Drop CONFIG_SYS_GENERIC_BOARD define] Signed-off-by: Tom Rini <trini@konsulko.com>
