path: root/board/denx
2016-10-29Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2016-10-27arm: socfpga: mcvevk: Adding handoff for SDRAM ctrlcfg.extratime1Chin Liang See
Adding new handoff for SDRAM ctrcfg.extratime1 which is required for stable LPDDR2 operation. Since the board is using DDR3, the handoff is set to default value 0. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2016-10-26imx: s/docs\/README.imximage/doc\/README.imximage/gJagan Teki
Fixed typo for doc/README.imximage on respective imximage.cfg files. Cc: Tom Rini <trini@konsulko.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-04-01usb: Rename ehci-fsl.h to ehci-ci.hMateusz Kulikowski
Most of ehci-fsl header describe USB controller designed by Chipidea and used by various SoC vendors. This patch renames it to a generic header: ehci-ci.h Contents of file are not changed (so it contains several references to freescale SoCs). Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Simon Glass <sjg@chromium.org>
2016-02-18arm: at91: Add support for DENX MA5D4 SoM and EVKMarek Vasut
Add support for DENX MA5D4 SoM and MA5D4EVK board, based on the Atmel SAMA5D4 SoC. The SoM contains the SoC, eMMC, SPI NOR, SPI CAN controllers and DRAM, the baseboard contains UART connectors, ethernet port, microSD slot, LCD header, 2x CAN connector and a lot of expansion headers. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-12-20arm: socfpga: Drop the board boilerplateMarek Vasut
Drop all the common board code, since it is not completely useless. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-12-20arm: socfpga: mcvevk: Probe DWC2 UDC from OF instead of hard-coded dataMarek Vasut
This patch adds the necessary OF alias for the UDC node, which let's the code locate the DWC2 UDC base address in OF instead of hard-coding it into the U-Boot binary. The code is adjusted to use the address from OF instead of the hard-coded one. Finally, the hard-coded address is removed and USB DM support is enabled. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Lukasz Majewski <l.majewski@majess.pl> Cc: Lukasz Majewski <l.majewski@samsung.com>
2015-12-17usb: s3c-otg: Rename usb/s3c_udc.h to usb/dwc2_udc.hMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch renames the global s3c_udc.h header to dwc2_udc.h. The rename is done automatically: $ sed -i "s/s3c_udc\.h/dwc2_udc.h/g" \ `git grep "s3c_udc\.h" | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-17usb: s3c-otg: Rename s3c_udc_probe() functionMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch is the second and final to rename global symbol, the s3c_udc_probe() function. The rename is done automatically: $ sed -i "s/s3c_udc_probe/dwc2_udc_probe/g" \ `git grep s3c_udc_probe | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-17usb: s3c-otg: Rename struct s3c_plat_otg_dataMarek Vasut
The driver is actually for the Designware DWC2 controller. This patch is the first to rename global symbol, the struct s3c_plat_otg_data. The rename is done automatically: $ sed -i "s/s3c_plat_otg_data/dwc2_plat_otg_data/g" \ `git grep s3c_plat_otg_data | cut -d : -f 1` Signed-off-by: Marek Vasut <marex@denx.de>
2015-09-12arm: socfpga: mcvevk: Update DRAM clock to 400MHzMarek Vasut
The MCV SoM has DDR3-1600 DRAMs on it, update the DRAM speed to 400MHz to make use of these DRAMs completely. Signed-off-by: Marek Vasut <marex@denx.de>
2015-09-04arm: socfpga: Add support for DENX MCV SoM and MCVEVK boardMarek Vasut
Add support for DENX MCV SoM, which is CycloneV based and the associated DENX MCVEVK baseboard. The board can boot from eMMC. Ethernet and USB is supported. Signed-off-by: Marek Vasut <marex@denx.de>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-06spl: consolidate arch/arm/include/asm/arch-*/spl.hMasahiro Yamada
arch/arm/include/asm/spl.h requires all SoCs to have arch/arm/include/asm/arch-*/spl.h. But many of them just define BOOT_DEVICE_* macros. Those macros are used in the "switch (boot_device) { ... }" statement in common/spl/spl.c. So they should not be archtecture specific, but be described as a simpile enumeration. This commit merges most of arch/arm/include/asm/arch-*/spl.h into arch/arm/include/asm/spl.h. With a little more effort, arch-zynq/spl.h and arch-socfpga/spl.h will be merged, while I am not sure about OMAP and Exynos. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> CC: Stefano Babic <sbabic@denx.de> CC: Minkyu Kang <mk7.kang@samsung.com> Cc: Dinh Nguyen <dinguyen@altera.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tim Harvey <tharvey@gateworks.com> Tested-by: Bo Shen <voice.shen@atmel.com> [on sama5d3xek board for at91 part] Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stefano Babic <sbabic@denx.de> [applying Tim's i.MX6 patches] Acked-by: Tom Rini <trini@ti.com>
2014-03-31arm: mx5: Avoid hardcoding memory sizes on M53EVKMarek Vasut
The DRAM size can be easily detected at runtime on i.MX53. Implement such detection on M53EVK and adjust the rest of the macros accordingly to use the detected values. An important thing to note here is that we had to override the function for trimming the effective DRAM address, get_effective_memsize(). That is because the function uses CONFIG_MAX_MEM_MAPPED as the upper bound of the available DRAM and we don't have gd->bd->bi_dram[0].size set up at the time the function is called, thus we cannot put this into the macro CONFIG_MAX_MEM_MAPPED . Instead, we use custom override where we use the size of the first DRAM block which we just detected. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2013-12-17ARM: mx53: video: Add IPUv3 LCD support for M53EVKMarek Vasut
This patch adds support for the AMPIRE 800x480 LCD panel that is available for M53EVK. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2013-09-27mx28evk: Propagate the error if cpu_eth_init() failsFabio Estevam
If cpu_eth_init() fails we should return the error immediately. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2013-09-10ARM: mxs: Receive r0 and r1 passed from BootROMMarek Vasut
Make sure value in register r0 and r1 is preserved and passed to the board_init_ll() and mxs_common_spl_init() where it can be processed further. The value in r0 can be configured during the BootStream generation to arbitary value, r1 contains pointer to return value from CALL'd function. This patch also clears the value in r0 before returning to BootROM to make sure the BootROM is not confused by this value. Finally, this patch cleans up some comments in the start.S file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-06-26m28evk: Move README file inside board directoryFabio Estevam
Board specific READMEs should be located inside the respective board directory. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-05-05imx: m53evk: Convert to iomux-v3Benoît Thébaudeau
There is no change of behavior, except for the folloing line that has been removed because the iomux mode was not set accordingly and the pad used for OTG OC is not this one: mxc_iomux_set_input(MX53_USBOH3_IPP_IND_OTG_OC_SELECT_INPUT, 1); Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-05-05arm: mx5: Add support for DENX M53EVKMarek Vasut
Add basic support for the DENX M53EVK board. Currently supported is: MMC (incl. booting) NAND (incl. booting) Ethernet, I2C, USB, SATA, RTC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de>
2013-03-07mxs: m28: Enable power to USB port 0Marek Vasut
The USB port 0 can now be used alongside the USB port 1, thus enable power to it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2013-01-28mxs: mmc: Allow overriding default card detect implementationMarek Vasut
Some MXS based boards do not implement the card-detect signal. Allow user to specify alternate card-detect implementation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2013-01-21mxs: clock: Use 'mxs' prefix for methodsOtavio Salvador
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01MX28: m28evk: Align SSP clock speedMarek Vasut
Align the SSP clock speed with oscilator to achieve higher transfer stability. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Rename 'mx28_dram_init' to 'mxs_dram_init'Otavio Salvador
The DRAM initialization, after SPL has complete, is exactly the same for all mxs SoCs so we should name it accordinly. The following boards has been changed: * apx4devkit * m28evk * mx28evk * sc_sps_1 Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
2012-09-01MX28: Move the u-boot.bd info CPUDIR/SOCDIRMarek Vasut
This gets us rid of duplication of the same file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01mxs: Reowork SPL to use 'mxs' prefix for methodsOtavio Salvador
2012-09-01mxs: prefix register structs with 'mxs' prefixOtavio Salvador
2012-05-15M28EVK: Implement support for new board V2.0Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-03-26M28: Support for the old M28 SoM v1.0Marek Vasut
This prototype version SoM is unused and not available to public. Support this only for internal debugging purposes. Signed-off-by: Marek Vasut <marex@denx.de>
2012-03-26M28: Fix LCD PINMUXMarek Vasut
The LCD pins configuration was wrong in U-Boot, configure pins properly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com>
2012-01-16m28evk: Remove 'all' target from MakefileFabio Estevam
Remove 'all' target from Makefile, as this is unused code. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16mx28: Let dram_init be common for mx28Fabio Estevam
Let dram_init function be a common function, so that other mx28 boards can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16mx28: Let imx_get_mac_from_fuse be common for mx28Fabio Estevam
Let imx_get_mac_from_fuse function be a common function, so that other mx28 boards can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16net: imx: Add multi-FEC support for imx_get_mac_from_fuseFabio Estevam
Add multi-FEC support for imx_get_mac_from_fuse by passing dev_id as a parameter. This feature is important on mx28 SoC for example that has two FEC ports. Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-12-19M28: Fix tab indent in u-boot.bdMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-09i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28Marek Vasut
This moves SPL to common location so it can be reused by multiple boards. Also, this commit adjusts M28 SoM to avoid breakage due to the move. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-09M28: Fix typoMarek Vasut
2011-11-11M28EVK: Enable USB HOST supportMarek Vasut
This enables the second port, aka. the port with the USB connector on the M28EVK. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Remy Bohmer <linux@bohmer.net>
2011-11-11M28: Add memory detection into SPLMarek Vasut
This code allows the DDR DRAM size to be detected at runtime. The RAM size is stored into two scratch registers, from which it is then fetched in U-Boot. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11iMX28: Fix ARM vector handlingMarek Vasut
This patch introduces proper ARM vector handling for i.MX28 CPU. This issue wasn't addressed because the interrupts weren't enabled on any ARMv5 core, therefore the issue wasn't noticed earlier. In previous implementation, the vectoring code used by i.MX28 CPU when an exception happened was that of the SPL. With this change, the branch target when an exception happens can be reconfigured by U-Boot. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11M28: Add MMC SPLMarek Vasut
This patch adds SPL code for the M28 board. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11iMX28: Add support for DENX M28EVK boardMarek Vasut
This contains support for the following components: - DUART - MMC - Both FEC interfaces - NAND - I2C (RTC, EEPROM) - SPI (FLASH) Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
