path: root/board/engicam
2016-11-05engicam: icorem6: Fix config filesJagan Teki
Config file names on MAINTAINERS and README in board/engicam/icorem6 seems to be wrong, hence fixed the same. Cc: Stefano Babic <sbabic@denx.de> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26imx6: icorem6: Add NAND supportJagan Teki
Add NAND support for Engicam i.CoreM6 qdl board. Boot Log: -------- U-Boot SPL 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43) Trying to boot from NAND NAND : 512 MiB U-Boot 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43 +0530) CPU: Freescale i.MX6SOLO rev1.3 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 55C Reset cause: WDOG Model: Engicam i.CoreM6 DualLite/Solo Starter Kit DRAM: 256 MiB NAND: 512 MiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 icorem6qdl> Cc: Scott Wood <oss@buserror.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Peng Fan <peng.fan@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26arm: imx6q: Add devicetree support for Engicam i.CoreM6 Quad/DualJagan Teki
i.CoreM6 Quad/Dual modules are system on module solutions manufactured by Engicam with following characteristics: CPU NXP i.MX6 DQ, 800MHz RAM 1GB, 32, 64 bit, DDR3-800/1066 NAND SLC,512MB Power supply Single 5V MAX LCD RES FULLHD and more info at http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26engicam: icorem6: Add DM_GPIO, DM_MMC supportJagan Teki
Add DM_GPIO, DM_MMC support for u-boot and disable for SPL. Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26arm: imx6q: Add devicetree support for Engicam i.CoreM6 DualLite/SoloJagan Teki
i.CoreM6 DualLite/Solo modules are system on module solutions manufactured by Engicam with following characteristics: CPU NXP i.MX6 DL, 800MHz RAM 1GB, 32, 64 bit, DDR3-800/1066 NAND SLC,512MB Power supply Single 5V MAX LCD RES FULLHD and more info at http://www.engicam.com/en/products/embedded/som/sodimm/i-core-m6s-dl-d-q Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-26imx6: icorem6: Add ENET supportJagan Teki
Add enet support for engicam icorem6 qdl starter kit. - Add pinmux settings - Add board_eth_init TFTP log: -------- Net: FEC [PRIME] Hit any key to stop autoboot: 0 icorem6qdl> tftpboot {fdt_addr} imx6dl-icore.dtb Using FEC device TFTP from server 192.168.2.96; our IP address is 192.168.2.75 Filename 'imx6dl-icore.dtb'. Load address: 0x0 Loading: ###### 1.3 MiB/s done Bytes transferred = 28976 (7130 hex) CACHE: Misaligned operation at range [00000000, 00007130] icorem6qdl> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-26arm: imx: Add Engicam i.CoreM6 QDL Starter Kit initial supportJagan Teki
Boot Log for i.CoreM6 DualLite/Solo Starter Kit: ----------------------------------------------- U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46) Trying to boot from MMC1 U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530) CPU: Freescale i.MX6SOLO rev1.3 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 31C Reset cause: POR DRAM: 256 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device switch to partitions #0, OK mmc0 is current device reading boot.scr ** Unable to read file boot.scr ** reading zImage 6741808 bytes read in 341 ms (18.9 MiB/s) Booting from mmc ... reading imx6dl-icore.dtb 30600 bytes read in 19 ms (1.5 MiB/s) Booting using the fdt blob at 0x18000000 Using Device Tree in place at 18000000, end 1800a787 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 Boot Log for i.CoreM6 Quad/Dual Starter Kit: -------------------------------------------- U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46) Trying to boot from MMC1 U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530) CPU: Freescale i.MX6Q rev1.2 at 792MHz CPU: Industrial temperature grade (-40C to 105C) at 28C Reset cause: POR DRAM: 512 MiB MMC: FSL_SDHC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 icorem6qdl> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Matteo Lisi <matteo.lisi@engicam.com> Cc: Michael Trimarchi <michael@amarulasolutions.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
