Add different defconfigs.
Enable Trustzone.
Update env to runtime boot OP-TEE.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
(cherry picked from commit af4e26c34e091994615ec721bc357b45e43c89e9)
(cherry picked from commit cd8397e9c973ac31766adf9565b2af18db9f9606)
(cherry picked from commit 79e2e2fbe7ddf376619efb43c4b4e6c4285a6f5c)
(cherry picked from commit 65fd479c23fa3d36d54c1853e3e2645ebcc56e96)
(cherry picked from commit df85fa7f7517b61852a9441db361015e4bf86cb6)
(cherry picked from commit 7b33b260cf77d37a906dcf1ca974c2f9ac7077fb)
(cherry picked from commit 838c7b9cc12c05e2f96bea5cda3cf775ba6c8fcb)
(cherry picked from commit 99452f78d8485d2d2baccf21ce04190e44a123d6)
Enable the configurations CONFIG_MODULE_FUSE and CONFIG_OF_SYSTEM_SETUP for
module fuse check. And modify board level codes for SD, FEC and EIM.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 9232e9f7637afa3b71b43ab2d1361582ec5a080a)
(cherry picked from commit 687b586bf7d3b0d2f796c8ea768e4fb450079adb)
(cherry picked from commit f1cdd3b004b15d950b35f3ef625af23c2f106f5a)
(cherry picked from commit e5ac66df336a1ce45f315ada5d8f1a73e8f22632)
(cherry picked from commit f43662fa184193d165973f0c50708f818b120708)
(cherry picked from commit 5a635cad834def6d5a624311e6db2666c6617276)
(cherry picked from commit bdf0029e0facf763dd1f9555231caf7da48860fb)
(cherry picked from commit 0bdd89bccd3a0c71a7e687a73fb440a43be99556)
Add functions below to align with v2020.04
1. Switch from SPL to Non-SPL
2. Add plugin and DCD for DDR initialization
3. Update two ethernet controllers support at runtime
4. Add GPMI NAND support
5. Add LDO bypass settings
(cherry picked from commit 5daeae6f49fefdf6eb54f5a9ae37f21483883f83)
(cherry picked from commit 755fb5c111a3aeb55d16790336af14fa2678c4bf)
(cherry picked from commit 2071ae10025d45f617210bf4b867bd2fd650a7c6)
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Convert plain text documentation to reStructuredText format and add
it to Sphinx TOC tree. No essential content change.
When using cygwin64 "dd (coreutils) 8.26 Packaged by Cygwin (8.26-2)",
the last not 512bytes aligned data wat cut off and not burned into SD
card.
Saying the flash.bin size is 1085608 bytes, not 512bytes aligned. It only
burned 1085440 bytes, the leaving 168 bytes were not burnned and cause
boot issue.
So update README dd command to add "conv=notrunc"
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this uncommon header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
mx6ul_evk uses DM_ETH, so there is no need to have board code
to setup the FEC IOMUX and to register the network ports via the
old board_eth_init() method.
Remove these FEC related pieces of code.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
This should help keeping the screen black when booting the kernel.
Reported-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Fabio Estevam <festevam@gmail.com>
Currently the following SPL hang is observed:
U-Boot SPL 2020.01-rc5-00079-g797eee36a1 (Jan 06 2020 - 11:24:09 -0300)
Trying to boot from MMC1
Card did not respond to voltage select!
spl: mmc init failed with error: -95
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
Fix it by moving the eSDHC2 initialization to SPL.
While at it, since this board uses DM_MMC all the esdhc board
code can be removed to make the code simpler.
A number of board function belong in init.h with the others. Move them.
Add instructions on how to boot mx6ul_14x14_evk_defconfig target
using the Serial Download Protocol.
Add examples from uuu and imx_usb_loader tools.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Since recent splash changes common code for splashscreen logo
should be used instead of adding duplicated code under board
directories. mx6ul_9x9_evk and mx6ul_14x14_evk configurations
used old board specific logo code and do not link, fix them.
Acked-by: Peng Fan <peng.fan@nxp.com>
To support DM_VIDEO,
Add display node for lcdif
Drop board iomuxc settings.
Enable DM_VIDEO
Reviewed-by: Anatolij Gustschin <agust@denx.de>
When booting SPL on the board, met boot failure:
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device 1. error: -19
Let's register the two mmc controllers in SPL stage to
avoid boot failure.
Move env_set() over to the new header file.
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
There is no need to store the values written to the PMIC inside the
'reg' variable. Make it simpler by writing the values directly.
Convert the codes and configurations to enable DM drivers in u-boot for
modules: i2c, PMIC, regulator, USB, Ethernet, SD/MMC, GPIO and QSPI
This patch does not change SPL, so it still uses non-DM driver for
UART, GPIO and SD/MMC.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Thomas reported U-Boot failed to build host tools if libfdt-devel
package is installed because tools include libfdt headers from
/usr/include/ instead of using internal ones.
This commit moves the header code:
include/libfdt.h -> include/linux/libfdt.h
include/libfdt_env.h -> include/linux/libfdt_env.h
and replaces include directives:
#include <libfdt.h> -> #include <linux/libfdt.h>
#include <libfdt_env.h> -> #include <linux/libfdt_env.h>
Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
We are now using an env_ prefix for environment functions. Rename setenv()
for consistency. Also add function comments in common.h.
Suggested-by: Wolfgang Denk <wd@denx.de>
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
The variable usdhc1_pads is only referenced during SPL builds, add a guard.
Cc: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
The LCDIF Pixel clock mux is not glitchless, so need
to gate before changing mux.
Also change enable_lcdif_clock prototype with a new input
parameter to indicate disable or enable.
To be in the safe side we need to enable the CCGR clocks prior
to calling arch_cpu_init().
Inspired by Tim Harvey's commit d783c2744f9 ("imx: ventana: fix boot to SD").
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Eric Nelson <eric@nelint.com>
Tested-by: Eric Nelson <eric@nelint.com>
Adjust DDR3 initialization done in SPL by comparing them against
the NXP DCD table.
When running a NXP 4.1 kernel with U-Boot mainline on a mx6ul-evk,
we observe a hang when going into the lowest operational point of cpufreq.
This hang issue does not happen on the NXP U-Boot version.
After comparing the SPL DDR initialization against the DCD table
from NXP U-Boot, the key difference that causes the hang is the
MDREF register setting:
DATA 4 0x021B0020 0x00000800
,which means:
REF_SEL = 0 --> Periodic refresh cycle: 64kHz
REFR = 1 ---> Refresh Rate - 2 refreshes
So adjust the MDREF initialization for mx6ul_evk accordingly
to fix the kernel hang issue at low bus frequency.
Reported-by: Eric Nelson <eric@nelint.com>
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and
REFR fields of the MDREF register as 1 and 7, respectively for
DDR3 and 0 and 3 for LPDDR2.
Looking at the MDREF initialization done via DCD we see that
boards do need to initialize these fields differently:
$ git grep 0x021b0020 board/
board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800
board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */
board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800
board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800
board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800
board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800
board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800
So introduce a mechanism for users to be able to configure
REFSEL and REFR fields as needed.
Keep all the mx6 SPL users in their current REF_SEL and REFR values,
so no functional changes for the existing users.
Register LDOGCTL contains only bit 0 as a valid bit, so there is no need
to do a read-modify-write operation.
Simplify the code by writing directly to this register.
Only a single pad is changed to change sdhc2_dat3 from an
SDIO pin to and from GPIO4:5, so remove the array and use
the imx_iomux_v3_setup_pad() routine.
Signed-off-by: Eric Nelson <eric@nelint.com>
Remove unused define constant.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
The current pad DSE for QSPI is 60ohm. This setting cause
too strong drive to clock and data signals. Need to change
the DSE to 120ohm for better signal quality.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Q901 is PMOS, LCD_nPWREN should be at low voltage then output is 3V3.
If LCD_nPWREN is high, output is 2.4V which is not correct.
Fix 74LV OE gpio index. gpio index is wrong,
so gpio output will not have effect, since we
use wrong GPIO5_IO18, but not correct GPIO5_IO8.
And at the end of the initialization of 74lv init, should
keep OE voltage level at LOW to make 74lv output the correct
voltage.
Most of ehci-fsl header describe USB controller
designed by Chipidea and used by various SoC vendors.
This patch renames it to a generic header: ehci-ci.h
Contents of file are not changed (so it contains several
references to freescale SoCs).
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Use Peng Fan's new NXP email address in MAINTAINERS files.
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
Support lcdif display:
1. Add pinmux and pad settings for LCDIF
2. Introduce setup_lcd to do the settings for LCDIF
3. Enable VIDEO related macros in board header files
4. Add a new env videomode which is needed by mxsfb.c. The
settings for videomode in this patch is for TFT43AB.
5. Tested on mx6ul 14x14/9x9 evk.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
There is really no need to provide an empty reset_cpu() implementation,
so just remove it.
Add MAINTAINERS info for mx6slevk_spl, mx6ul_9x9_evk and mx6qpsabreauto.
get_board_rev() is not actually providing the board revision.
It just returns the CPU revision instead.
As the CPU revision is already printed on boot, there is no
reason to have get_board_rev(), so let's remove it.
Make the internal symbols static when possible.
This prevents sparse build warnings.
iox74lv_set() is not used anywhere, so let's remove it.
Add a README file to help users getting started with the board.
Remove duplicated SYS_SOC Kconfig entry from board Kconfig,
because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig.
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Acked-by: Markus Niebel <Markus.Niebel@tq-group.com>
Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
This patch is to support mx6ul_9x9_evk board based on mx6ul_14x14_evk,
the difference between mx6ul 9x9 evk and mx6ul 14x14 evk are:
1. mx6ul 9x9 evk use pfuze3000, while mx6ul 14x14 evk use DCDC.
2. mx6ul 9x9 evk supports 256MB LPDDR2, while mx6ul 14x14 evk
supports 512MB DDR3
3. mx6ul_9x9_evk use 9x9 package, while mx6ul_14x14_evk use 14x14 package.
This patch add the following:
1. Discard PHYS_SDRAM_SIZE from header file, use imx_ddr_size()
2. Introduce a macro is_mx6ul_9x9_evk using
CONFIG_IS_ENABLED(TARGET_MX6UL_9X9_EVK) to avoid "#ifdef xxx" in non-SPL
part. To SPL part, CONFIG_IS_ENABLED(TARGET_MX6UL_9X9_EVK) can not work,
so still use "#ifdef CONFIG_TARGET_MX6UL_9X9_EVK" to differentiate with
mx6ul_14x14_evk. And we have no way to dymaically checking this chip
is 9x9 or 14x14.
3. mx6ul_9x9_evk use pfuze3000, so enabled POWER related configurations.
POWER related configurations also effect for mx6ul_14x14_evk. But
power_init_board implementation using 'if (is_mx6ul_9x9_evk())' to
do initialization for mx6ul_9x9_evk, and do nothing for mx6ul_14x14_evk.
4. mx6ul_9x9_evk use lpddr2 with size 256MB, so add related SPL DRAM
configurations.
5. Enable CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG and setting dtb file
according to board_rev and board_name.
6. Add TARGET_MX6UL_9X9_EVK Kconfig entry
Boot Log:
U-Boot SPL 2015.10-rc2-00356-g536ce34 (Sep 06 2015 - 12:22:53)
reading u-boot.img
reading u-boot.img
U-Boot 2015.10-rc2-00356-g536ce34 (Sep 06 2015 - 12:22:53 +0800)
CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C) at 41C
Reset cause: POR
Board: MX6UL 9x9 EVK
I2C: ready
DRAM: 256 MiB
PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Net: FEC1
Hit any key to stop autoboot: 0
To i.MX6, DDR3 and LPDDR2 is supported, so rename function mx6_dram_cfg
to mx6_ddr3_cfg and the original mx6_dram_cfg function only is a wrapper.
The new reimplemented function mx6_dram_cfg only invokes mx6_ddr3_cfg
when ddr_type is for DDR3. Later we can use ddr_type to initialize
MMDC for LPDDR2.
Initialize ddr_type for different boards which enable SPL.
