Add the required changes for compiling with DM_ETH on the PPC
DPAA platforms.
Signed-off-by: Madalin Bucur <madalin.bucur@oss.nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Move this uncommon header out of the common header.
These functions relate to setting up the device tree for booting the OS.
The fdt_support.h header file supports similar functions, so move these
there.
A number of board function belong in init.h with the others. Move them.
Move env_get() over to the new header file.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We are now using an env_ prefix for environment functions. Rename these
other functions as well, for consistency:
getenv_vlan()
getenv_bootm_size()
getenv_bootm_low()
getenv_bootm_mapsize()
env_get_default()
Suggested-by: Wolfgang Denk <wd@denx.de>
The function fdt_fixup_dr_usb is specific to fsl/nxp. So,
make the function name explicit and rename fdt_fixup_dr_usb
into fsl_fdt_fixup_dr_usb.
Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
The fuse status register provides the values from on-chip
voltage ID efuses programmed at the factory. These values
define the voltage requirements for the chip. u-boot reads
FUSESR and translates the values into the appropriate
commands to set the voltage output value of an external
voltage regulator.
Signed-off-by: Ying Zhang <b40530@freescale.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Users migrating Freescale's PowerPC SoC U-Boot code to their custom
board, often overlook the need to execute set_liodns() and
setup_portals() being called by platform files.
So Move set_liodns() and setup_portals() to common u-boot boot
sequence
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
This function can fail if the device tree runs out of space. Rather than
silently booting with an incomplete device tree, allow the failure to be
detected.
Unfortunately this involves changing a lot of places in the code. I have
not changed behvaiour to return an error where one is not currently
returned, to avoid unexpected breakage.
Eventually it would be nice to allow boards to register functions to be
called to update the device tree. This would avoid all the many functions
to do this. However it's not clear yet if this should be done using driver
model or with a linker list. This work is left for later.
Acked-by: Anatolij Gustschin <agust@denx.de>
This support of CPLD includes
- Files and register definitions
- Command to switch alternate bank
- Command to switch default bank
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
find_tlb_idx() is called in board_early_init_r() on multiple boards.
The return value is not checked before being used to disable a TLB.
In normal case the return value wouldn't be -1. In case of a mis-
configuration during porting to a new board, checking the return value
may be helpful to reveal some user errors.
Signed-off-by: York Sun <yorksun@freescale.com>
T4240RDB board Specification
Memory subsystem:
6GB DDR3
128MB NOR flash
2GB NAND flash
Ethernet:
Eight 1G SGMII ports
Four 10Gbps SFP+ ports
PCIe:
Two PCIe slots
USB:
Two USB2.0 Type A ports
SDHC:
One SD-card port
SATA:
One SATA port
UART:
Dual RJ45 ports
[York Sun: fix CONFIG_SYS_QE_FMAN_FW_ADDR in T4240RDB.h]
