path: root/board/gdsys
2016-09-27usb: fsl: Rename fdt_fixup_dr_usbSriram Dash
The function fdt_fixup_dr_usb is specific to fsl/nxp. So, make the function name explicit and rename fdt_fixup_dr_usb into fsl_fdt_fixup_dr_usb. Signed-off-by: Sriram Dash <sriram.dash@nxp.com>
2016-08-15net: mii: Fix changes made by spatchJoe Hershberger
Some of the changes were a bit too complex. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-15net: mii: Use spatch to update miiphy_registerJoe Hershberger
Run scripts/coccinelle/net/mdio_register.cocci on the U-Boot code base. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-22gdsys: Drop print_fpga_state functionTom Rini
On most platforms the print_fpga_state function is never called. Only on dlvision-10g do we, so in that case inline it. Drop it from everywhere else to avoid extra strings. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Acked-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2016-06-06strider: Support con-dp flavorDirk Eibach
There is a new strider console flavor with DisplayPort video. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-06gdsys: osd: Allow osdsize on valid screens onlyDirk Eibach
Limit "osdsize"-command to access valid screens only. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-06-06ioep-fpga: Support intempo compressionDirk Eibach
There is a new "intempo" compression type that can be reported on startup. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27Delete tests of CONFIG_OF_LIBFDT when testing CONFIG_OF_BOARD_SETUPRobert P. J. Day
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT: config OF_BOARD_SETUP bool "Set up board-specific details in device tree before boot" depends on OF_LIBFDT ... remove superfluous tests of CONFIG_OF_LIBFDT when testing for CONFIG_OF_BOARD_SETUP. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> [trini: Typo fix: s/ifdefi/ifdef/] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-21strider: Add DP501 support for cpu modelDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-14Fix GCC format-security errors and convert sprintfs.Ben Whitten
With format-security errors turned on, GCC picks up the use of sprintf with a format parameter not being a string literal. Simple uses of sprintf are also converted to use strcpy. Signed-off-by: Ben Whitten <ben.whitten@gmail.com> Acked-by: Wolfgang Denk <wd@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-12board: gdsys: Enable osd on output onlyDirk Eibach
2015-11-12board: gdsys: Add osdsize commandDirk Eibach
osdsize adjusts the gdsys IHS osd dimensions in characters. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12hrcon: Add fan controllersDirk Eibach
2015-11-12hrcon: Add support for the DH variantDirk Eibach
hrcon DH(dual head) has two video outputs per FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12hrcon: Fix videoboard i2c setupDirk Eibach
- i2c addresses for the videoboard port expanders were wrong. - the fpga reset signal was not initialized. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12hrcon: Use generic ioep-fpga supportDirk Eibach
The strider platform moved some generic code into ioep-fpga.c. Make use of that on hrcon platform. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12mpc83xx: Add strider boardDirk Eibach
The gdsys strider board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x 10/100 Mbit/s Ethernet (optional) - Lattice ECP3 FPGA connected via eLBC Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> [trini: Drop setting CONFIG_SYS_GENERIC_BOARD, this is always true now] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12iocon: reset FPGAs in last_stage_init()Reinhard Pfau
- Reset FPGAs in last_stage_init() Signed-off-by: Reinhard Pfau <pfau@gdsys.de> Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12controlcenterd: Disable sideband clocksDirk Eibach
2015-11-12dlvision-10g: Support displayportDirk Eibach
Support dlvision-10g hardware with displayport output. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12board: gdsys: Consider DP501 limits on link trainingDirk Eibach
DP501 only supports DP 1.1a. Limit settings for link bandwidth and lane count to values allowed by DP 1.1a. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12board: gdsys: Increase DP501 I2C retry intervalDirk Eibach
With Club 3D dual link adapter there are AUX-channel timeouts when EDID is read. Increasing retry interval time to max (400us) fixes this. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-12board: gdsys: Configure DP501 SPDIF inputDirk Eibach
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2014-11-26Merge git://git.denx.de/u-boot-fdtTom Rini
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-11-19mpc83xx: Add gdsys hrcon boardDirk Eibach
The gdsys hrcon board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x GbE (optional) - Lattice ECP3 FPGA connected via eLBC and PCIe Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-11-19board: iocon: Fix uninitialized accessDirk Eibach
Wolfgang Denk found this issue using cppcheck: (error) Uninitialized variable: fpga_features Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-11-19board: iocon: Fix fpga index in print_fpga_info()Dirk Eibach
2014-11-19board: dlvision-10g: Compile fixDirk Eibach
2014-07-07board: iocon: Modify iocon hardware startupDirk Eibach
To avoid peer "ChReceivePathStatus"-messages on iocon startup, initialize PHYs as soon as possible. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Enable scrambling on DP501Dirk Eibach
For proper displayport performance, scrambling has to be enabled, but is turned off on DP501 by default. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Make gdsys osd hardware detection more robustDirk Eibach
2014-07-07board: gdsys: Configure bridge on DP501 to support DDC onlyDirk Eibach
The I2C bridge on DP501 supports EDID, MCCS and HDCP by default. Allow EDID only to avoid I2C address conflicts. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: iocon: Support DisplayPort hardwareDirk Eibach
There is a new iocon hardware flavor, supporting DisplayPort finally. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: controlcenterd: Use new API for setting i2c busDirk Eibach
2014-07-07board: gdsys: Adapt sdhc_boot.c to mmc_get_env_addr API changeDirk Eibach
2014-07-07board: controlcenterd: Fix pci accessDirk Eibach
readl was called with values instead of pointers to these values. Why this ever did work is a mystery... Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-06-19includes: move openssl headers to include/u-bootJeroen Hofstee
commit 18b06652cd "tools: include u-boot version of sha256.h" unconditionally forced the sha256.h from u-boot to be used for tools instead of the host version. This is fragile though as it will also include the host version. Therefore move it to include/u-boot to join u-boot/md5.h etc which were renamed for the same reason. cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-19Fix bug in io64 target (introduced by commit aba27ac)Vasili Galka
From comparison of current logic and the logic that was prior to commit aba27ac, we see that first parameter of FPGA_GET_REG() shall be the FPGA index and not channel number. The re-factoring in commit aba27ac accidentally changed that. Cc: Stefan Roese <sr@denx.de> Acked-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-06-11Check run_command() return code properlyThomas Betker
run_command() returns 0 for success, 1 for failure. Fix places which assume that failure is indicated by a negative return code. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de>
