path: root/board/ge
2020-02-11Merge tag 'dm-pull-6feb20' of https://gitlab.denx.de/u-boot/custodians/u-boot-dmTom Rini
sandbox conversion to SDL2 TPM TEE driver Various minor sandbox video enhancements New driver model core utility functions
2020-02-09board: ge: mx53ppd: use DM for uartIan Ray
Drop PPD_UART_PAD_CTRL since it matches defaults. Enable DM serial and MXC uart. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: bx50v3: use DM for uartRobert Beckett
Remove legacy uart pad and iomux code Enable DM serial and mxc uart Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: mx53ppd: Use DM for ethernetRobert Beckett
Remove legacy iomux setup for fec. Enable phylib and DM fec. Use Kconfig for enabling fec. Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: bx50v3: Enable DM PWM for backlightRobert Beckett
Add backlight and panel devicetree definitions Use UCLASS_PANEL to enable backlight via display enable handler Remove old explicit gpio code for handling backlight Use cls command to initiate display in HW agnostic manner Enable DM regulator and pwm Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: mx53ppd: enable DM_VIDEOIan Ray
Enable DM_VIDEO for mx53ppd. Enable DM_REGULATOR_FIXED and DM_PWM for the backlight. Remove unused MX53PPD_LCD_POWER. Remove old (incorrect) setup_iomux_lcd. Enable backlight via display enable handler. Use cls command to initiate display in HW agnostic manner. Modify `failbootcmd' to use lcdputs. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-02-09board: ge: bx50v3, imx53ppd: use DM I2CRobert Beckett
Remove old (pre-DM) i2c setup code. Enable DM i2c. Convert common code to use DM rtc. Convert common code to read VPD from eeprom partition. Convert the generic i2c PMIC init code to use the new da9063 driver. mx53ppd only: Correct RTC compatible in device tree. Enable MXC DM i2c driver. Define CONFIG_SYS_MALLOC_F_LEN so that DM is available in pre-reloc. Make GPIO banks available during preloc, since initialisation is done in board_early_init_f(). Add gpio_request() calls to satisfy the DM_GPIO compatibility API. Remove unused power configuration. Signed-off-by: Robert Beckett <bob.beckett@collabora.com> Signed-off-by: Ian Ray <ian.ray@ge.com>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-07board: ge: mx53ppd: use imx wdtRobert Beckett
Enable DM imx WDT Enable SYSRESET_WATCHDOG to maintain WDT based reset ability Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07board: ge: pass rtc_status via device treeIan Ray
Pass rtc_status via the device tree, instead of on kernel command line. Additionally, the 2038 mitigation is reported, if applied successfully. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07board: ge: bx50v3: Enable DM for PCI and ethernetDenis Zalevskiy
DM for PCI pulls DM for ethernet that also needs other changes described below to build u-boot and keep existing functionality - ability to update MAC addresses of FEC ethernet adapter and I210 adapter connected to the Marvell switch. - fec_mxc driver with DM needs PHYLIB; - configuration items are moved from ge_bx50v3.h to ge_bx50v3_defconfig; - FEC is marked as eth0 because it is always present, so indices changed: I210 are still probed in the same order; - board_eth_init() was used by legacy ethernet, setup for enet iomux and pcie is moved to the board_late_init(); - pci_init() is called from the board_late_init() to initiate PCI bus probing, so I210 devices are propagated to the device tree; Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> [Describe PHY reset in device tree] Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07board: ge: bx50v3: Fix message output to video consoleIan Ray
Use vidconsole for output to the LCD, now that DM_VIDEO is used. Write white text on a black background, like before migrating to DM_VIDEO. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07board: ge: bx50v3: Fix run-time warningIan Ray
Fix GPIO reservation warning on code paths that do not need LVDS power. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2020-01-07board: ge: bx50v3: sync devicetrees from LinuxRobert Beckett
Copy device trees from linux, keeping them as separate files for each board to ease future sync. Update board code to use generic bx50v3 dt initially, then select the specific dt based on board detection. Signed-off-by: Robert Beckett <bob.beckett@collabora.com>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-06-23Convert to use fsl_esdhc_imx for i.MX platformsYangbo Lu
Converted to use fsl_esdhc_imx for i.MX platforms. Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com> Reviewed-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Martyn Welch <martyn.welch@collabora.com> Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
2019-04-13mx53ppd: bring dock out of reset at bootIan Ray
Configure GPIO BUFFERED_HOST_CONTROLLED_RESET_TO_DOCKING_CONNECTOR_N to bring the dock out of reset at boot. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: store version information in fdtIan Ray
Add board-specific FDT function to store U-Boot version in device tree. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: ppd: Enable CONFIG_DM_MMCIan Ray
Use MMC device model, and remove USDHC pin configuration code since the pinctrl driver is used. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_SPI, CONFIG_DM_SPI_FLASHIan Ray
Use SPI flash device model, and remove SPI pin configuration code since the pinctrl driver is used. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_GPIOIan Ray
Enable CONFIG_DM_GPIO as a pre-requisite for enabling CONFIG_DM_SPI. Add explicit gpio_requests. Signed-off-by: Ian Ray <ian.ray@ge.com>
2019-04-13board: ge: bx50v3: Enable CONFIG_DM_MMCIan Ray
2019-01-01imx: mx53ppd: fix build errorPeng Fan
board/ge/mx53ppd/mx53ppd.c: In function 'board_late_init': board/ge/mx53ppd/mx53ppd.c:359:23: error: passing argument 2 of 'read_vpd' from incompatible pointer type [-Werror=incompatible-pointer-types] res = read_vpd(&vpd, vpd_callback); ^~~~~~~~~~~~ In file included from board/ge/mx53ppd/mx53ppd.c:37:0: board/ge/mx53ppd/../../ge/common/vpd_reader.h:19:5: note: expected 'int (*)(struct vpd_cache *, u8, u8, u8, size_t, const u8 *) {aka int (*)(struct vpd_cache *, unsigned char, unsigned char, unsigned char, unsigned int, const unsigned char *)}' but argument is of type 'int (*)(void *, u8, u8, u8, size_t, const u8 *) {aka int (*)(void *, unsigned char, unsigned char, unsigned char, unsigned int, const unsigned char *)}' int read_vpd(struct vpd_cache *cache, ^~~~~~~~ cc1: all warnings being treated as errors Signed-off-by: Peng Fan <peng.fan@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de>
2019-01-01board: ge: Move VPD reading to the vpd_readerDenis Zalevskiy
Merge functionality duplicated in bx50v3 and mx53ppd: the logic is the same except that process_vpd is called at different phases. Also read_vpd could end up in error, so there is no VPD data in this case - it shouldn't be processed. Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-12-17board: ge: Move VPD EEPROM configuration to the defconfigDenis Zalevskiy
Use standard configuration logic to define EEPROM constants. Names are based on VPD_EEPROM_ prefix because EEPROM_ is already used by i2c_eeprom driver. Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-12-17board: ge: Remove EEPROM bus param from read_vpd()Denis Zalevskiy
The bus is statically defined, so remove redundant parameters from read_vpd() for PPD and Bx50v3. Signed-off-by: Denis Zalevskiy <denis.zalevskiy@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22board: ge: bx50v3: fix initialization of i2c bus0Dan Cimpoca
I2C bus 0 was not initialized correctly. There is an offset between i2c index and the structure number of pad info. So i2c bus 0 can be in an inconsistent state. This problem become visible on B{4,6}50v3 with the CPUC HW watchdog enabled. Sometimes when the CPUC HW watchdog interrupted the boot process, U-Boot was not able to read VPD from I2C/EEPROM and the system failed to boot up again, because a device connected to that bus was stuck in data transfer state (from previous boot attempt) and there was no method to recover (struct mxc_i2c_bus::idle_bus_fn was not set) courtesy of incorrect initialization. Signed-off-by: Dan Cimpoca <dan.I.cimpoca@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22board: ge: bx50v3: b{4,6}50v3 modelineIan Ray
The b{4,6}50v3 kernel framebuffer console requires a modeline otherwise the LVDS panel shows garbage. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22board: ge: bx50v3: correct LDB clockIan Ray
Use Video PLL to provide 65MHz for all displays. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-10-22board: ge: bx50v3: Change maintainerFabien Lahoudere
While using ./scripts/get_maintainer.pl I detect that the Maintainer name and address for bx50v3 boards are not valid. The new maintainer for GE bx50v3 products must be Ian Ray. Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.com>
2018-06-27imx: bx50v3: fix MaintainersStefano Babic
This fixes the warnings: WARNING: no status info for 'ge_bx50v3' WARNING: no maintainers for 'ge_bx50v3 Signed-off-by: Stefano Babic <sbabic@denx.de>
2018-05-17board: ge: bx50v3: remove redundant targetsIan Ray
This replaces TARGET_GE_B{4,6,8}50V3 with common TARGET_GE_BX50V3. The boards are identified automatically at runtime. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: configure video arguments using VPDIan Ray
Configure video arguments at run-time instead of at compile-time. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: use VPD instead of compile-time checksIan Ray
B{46}50v3s have an internal LCD that needs to be configured, in comparison with B850v3 which has only external displays. Use VPD instead of `CONFIG_TARGET_GE_B{4,6,8}50V3' compile-time checks to correct initialize video based on the monitor type. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: detect the monitor type by reading VPD earlierNandor Han
Move the VPD reading earlier in order to establish the monitor type as soon as possible. The configuration of the specific environment variables needs to be done later after the environment is configured. Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: fix display support for b{46}50v3Ian Ray
Enable Video PLL to fix non-working display support for Bx50v3 internal displays. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: unify two switch statementsNandor Han
Simplify process_vpd() by unifying the switch statements handling product specific configurations. Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-05-17board: ge: bx50v3: rename detect_baseboard functionIan Ray
The detect_baseboard() function actually determines whether there is an internal LCD panel or not. Rename for clarity. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-15board: ge: bx50v3: enable backlight on demandIan Ray
Enable display backlight only if a message needs to be displayed. The kernel re-initializes the backlight, which results in some unwanted artifacts. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-04board,ge,bx50v3 - rtc time validationNandor Han
Validate the time at startup: - in case rtc error add to kernel command line RTC_ERROR - clamp date to 1-Jan-2036 Signed-off-by: Nandor Han <nandor.han@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: Support FIT and select configuration based on VPDIan Ray
Modify configuration to support FIT. Set variable `confidx' from VPD, in order to load the correct device tree. Modify/simplify U-Boot environment to support loading FIT image. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: Enable hardware watchdogMartyn Welch
Enable the hardware watchdog on bx50v3 to cause it to reset in the event the board hangs. Configure GPIO_9 pin as WDOG1_B so that a watchdog timeout results in a full system reset. The watchdog is used and reconfigured by systemd approximately 1.7 seconds into boot. Adding a few seconds for U-Boot and a few more seconds as a safety margin. Note that the PCIe controller is _not_ put back into a safe state prior to board reset. This is a problem if board reset is implemented as CPU reset. Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: program MAC address to I210Hannu Lounento
There are two I210s on the b850v3 and one on the b450v3 and b650v3. One is connected to Marvell 88e6240 which is already programmed. Follow the flow documented in doc/README.enetaddr: set the enet[0-9]*addr environment variable and let the driver program the hardware. The mapping from the driver's index to the environment variable's name is documented in README: Note for Redundant Ethernet Interfaces. It is assumed that eth_devices for the controllers on the board are always indexed in the same order. The environment variables are removed after programming the hardware because the variables seem to influence MAC addresses also after U-Boot. Specifically the MAC address of FEC (MC interface) would be incorrectly set: 'ethaddr', which maps to the first I210 chip and is set to I210's default address read from the driver by eth_write_hwaddr in eth_legacy.c because the variable is undefined (not set even by bx50v3.c), would result in the eth0 interface's MAC address to be set to I210's default address. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: bx50v3: move FEC MAC address programming to driverMartyn Welch
Instead of programming the hardware directly in the board implementation, follow the flow documented in doc/README.enetaddr: set the enet[0-9]*addr environment variable and let the driver program the hardware. This avoids duplicating the implementation as it already exists in the driver (drivers/net/fec_mxc.c: fec_set_hwaddr). The mapping from the driver's index to the environment variable's name is documented in README: Note for Redundant Ethernet Interfaces. It is assumed that eth_devices for the controllers on the board are always indexed in the same order, i.e. FEC always has the index 2. The FEC driver does *not* set the flag Set MAC Address on Transmit (bit set_eth0_mac_address used to do but this is unnecessary as the Linux networking stack fills in the MAC address. Signed-off-by: Hannu Lounento <hannu.lounento@ge.com> Signed-off-by: Ian Ray <ian.ray@ge.com> Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
2018-02-04board: ge: Enable access to i2c bus 1 and 2Martyn Welch
The change in i2c configuration added to support access to the VPD has inadvertantly caused access to i2c buses 1 & 2 to be lost. This has resulted in the configuration for the PMIC to be attempted on the wrong bus and thus isn't taking effect. Add the required configuration to return access to buses 1 & 2. In order to ensure that any users of the bus numbering prior to addition in VPD patches work, add buses before configuration related to mux on bus 0 and tweak VPD bus usage to fit new numbering scheme. Signed-off-by: Martyn Welch <martyn.welch@collabora.co.uk> Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
