path: root/board/gumstix
2016-07-22armv7: make gpmc_cfg constLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> [trini: Adapt am33xx, duovero, omap_zoom1] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-15omap-common: Rename set_muxconf_regs_essential to set_muxconf_regsPaul Kocialkowski
There is no distinction between essential and non-essential mux configuration, so it doesn't make sense to have an "essential" prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap_hsmmc: Board-specific TWL6030 MMC power initializationPaul Kocialkowski
Boards using the TWL6030 regulator may not all use the LDOs the same way. Some might also not use MMC1 at all, so VMMC would't have to be enabled. This delegates TWL6030 MMC power initializations to board-specific functions, that may still call twl6030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-06-08pepper: Implement Board Detection mechanismAdam YH Lee
AM335x-based 'Gumstix Pepper' SBCs and variants use different types of RAM (DDR2 vs DDR3 with DDR3 being the default). Detect the board type by reading the factory-programmed EEPROM [1] and use this to select any runtime boot options such as RAM type. [1] http://elinux.org/BeagleBoardPinMux#List_of_Vendor_and_Device_IDs Signed-off-by: Adam YH Lee <adam.yh.lee@gmail.com> Signed-off-by: Ash Charles <ashcharles@gmail.com>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: select CONFIG_DM* optionsMasahiro Yamada
As mentioned in the previous commit, adding default values in each Kconfig causes problems because it does not co-exist with the "depends on" syntax. (Please note this is not a bug of Kconfig.) We should not do so unless we have a special reason. Actually, for CONFIG_DM*, we have no good reason to do so. Generally, CONFIG_DM is not a user-configurable option. Once we convert a driver into Driver Model, the board only works with Driver Model, i.e. CONFIG_DM must be always enabled for that board. So, using "select DM" is more suitable rather than allowing users to modify it. Another good thing is, Kconfig warns unmet dependencies for "select" syntax, so we easily notice bugs. Actually, CONFIG_DM and other related options have been added without consistency: some into arch/*/Kconfig, some into board/*/Kconfig, and some into configs/*_defconfig. This commit prefers "select" and cleans up the following issues. [1] Never use "CONFIG_DM=n" in defconfig files It is really rare to add "CONFIG_FOO=n" to disable CONFIG options. It is more common to use "# CONFIG_FOO is not set". But here, we do not even have to do it. Less than half of OMAP3 boards have been converted to Driver Model. Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is weird. Instead, add "select DM" only to appropriate boards, which eventually eliminates "CONFIG_DM=n", etc. [2] Delete redundant CONFIGs Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again in configs/sandbox_defconfig. Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and defines it also in omap3_beagle_defconfig and devkit8000_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-30omap4: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP4 board select menu to omap4/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap4"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com> Cc: Lokesh Vutla <lokeshvutla@ti.com>
2014-07-25am335x_evm / gumstix pepper: Correct DDR settingsTom Rini
As noted by clang, we have been shifting certain values out of 32bit range when setting some DDR registers. Upon further inspection these had been touching reserved fields (and having no impact). These came in from historical bring-up code and can be discarded. Similarly, we had been declaring some fields as 0 when they will be initialized that way. Tested on Beaglebone White. Reported-by: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Ash Charles <ash@gumstix.com> Signed-off-by: Tom Rini <trini@ti.com> Tested-By: Ash Charles <ashcharles@gmail.com>
2014-05-23omap4: duovero: Add Gumstix DuoVero machine.Ash Charles
This adds the Gumstix DuoVero machine [1]. This is a OMAP4430-based computer-on-module (COM aka SOM) that can be mounted on various expansion boards with different peripherals. [1] https://store.gumstix.com/index.php/category/43/ Signed-off-by: Ash Charles <ash@gumstix.com> [trini: Rename gpmc_enable_gpmc_cs_config to gpmc_enable_gpmc_net_config] Signed-off-by: Tom Rini <trini@ti.com>
2014-05-13am335x: pepper: Add Gumstix Pepper AM335x-based machineAsh Charles
This adds the Gumstix Pepper[1] single-board computer based on the TI AM335x processor. Schematics are available [2]. [1] https://store.gumstix.com/index.php/products/344/ [2] https://pubs.gumstix.com/boards/PEPPER/ Signed-off-by: Ash Charles <ash@gumstix.com> [trini: Move 'cdev' in board.c down to under #ifdef's where it's used] Signed-off-by: Tom Rini <trini@ti.com>
