path: root/board/highbank
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12ARM: highbank: remove DRAM bank setupRob Herring
On the highbank platform the SoC's management controller firmware will probe the DRAM modules and populates the initial device tree with the correct values. Therefore the memory sizes in the DT are already correct, so remove U-Boot's DRAM bank setup so the memory node is not "fixed up" by u-boot. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Andre Przywara <osp@andrep.de>
2015-06-15highbank: add custom ahci_link_up functionMark Langsdorf
The Calxeda highbank SOC needs a custom sequence to bring up SATA links, so override ahci_link_up with custom function to handle combophy setup. Signed-off-by: Mark Langsdorf <mark.langsdorf@gmail.com> Signed-off-by: Richard Gibbs Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Andre Przywara <osp@andrep.de>
2015-06-12ARM: highbank: add reset support for Calxeda Midway machineMark Langsdorf
The Calxeda Midway part has A15 cores, which do not have the Highbank A9's SCU used there for resetting the chip. Add code to distinguish between the A9 and the A15 and invoke the appropriate register writes to support the newer part. Andre: rework detection of Highbank vs. Midway Rob: fix Andre's reworked detection Signed-off-by: Mark Langsdorf <mark.langsdorf@gmail.com> Signed-off-by: Andre Przywara <osp@andrep.de> Signed-off-by: Rob Herring <robh@kernel.org>
2015-06-12ARM: highbank: add missing SCU register setup for resetRob Herring
Andre: assign names to the magic values Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Andre Przywara <osp@andrep.de>
2015-04-18ahci: mmio_base is a virtual addressScott Wood
Don't store it in a u32. Don't dereference the bus address as if it were a virtual address (fixes 284231e49a2b4 ("ahci: Support splitting of read transactions into multiple chunks")). Fixes crash on boot in MPC8641HPCN_36BIT target. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Vadim Bendebury <vbendeb@chromium.org> Acked-by: York Sun <yorksun@freescale.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-08-30highbank: kconfig: move common settingsMasahiro Yamada
Move Highbank-specific settings to highbank/Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <robh@kernel.org>
2014-03-10highbank: use scsi_init hookIan Campbell
Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Rob Herring <robh@kernel.org>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-25Merge branch 'u-boot/master' into u-boot-arm/masterAlbert ARIBAUD
2013-07-25ARM: highbank: compile misc_init_r only if CONFIG_MISC_INIT_RRob Herring
Compile misc_init_r only if CONFIG_MISC_INIT_R is enabled. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-25ARM: highbank: setup peripherals based on power domain statusRob Herring
Accessing powered down peripherals will hang the bus, so check power domain status before initializing SATA and fixup the FDT to disable unused peripherals. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-02-03ARM: highbank: use wfi macro instead of inline asmRob Herring
Older compilers don't recognize v7 wfi instruction, so use wfi macro to fix builds on old compilers. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: setup env from boot source registerRob Herring
Add support to read the boot src register and set bootcmd env from the selected bootcmdX env setting. Based on Linkstation boot choice selection. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: add reset supportRob Herring
Implement reset for highbank platform. Reset is triggered via a wfi instruction, so enabling armv7 for the compiler is necessary. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: Add boot counter supportRob Herring
Add boot counter support using an sysreg which is persistent across reset. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: fix warning for calxedaxgmac_initializeRob Herring
Add include of netdev.h to pick-up declaration of calxedaxgmac_initialize. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-01-05ARM: highbank: enable networking and pxeRob Herring
This enables the XGMAC ethernet driver and networking related config options. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2011-10-27ARM: Add Calxeda Highbank platformRob Herring
Add basic support for Calxeda Highbank platform. Only minimal support with serial and SATA are included. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
