path: root/board/kosagi
2018-09-20mx6: ddr: pass mx6_ddr_sysinfo to calibration routinesEric Nelson
The DDR calibration routines have scattered support for bus widths other than 64-bits: -- The mmdc_do_write_level_calibration() routine assumes the presence of PHY1, and -- The mmdc_do_dqs_calibration() routine tries to determine whether one or two DDR PHYs are active by reading MDCTL. Since a caller of these routines must have a valid struct mx6_ddr_sysinfo for use in calling mx6_dram_cfg(), and the bus width is available in the "dsize" field, use this structure to inform the calibration routines which PHYs are active. This allows the use of the DDR calibration routines on CPU variants like i.MX6SL that only have a single MMDC port. Signed-off-by: Eric Nelson <eric@nelint.com> Reviewed-by: Marek Vasut <marex@denx.de> (cherry picked from commit 7f17fb7400ff091dd48f86977655c6a57d06b17c)
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-02-02arm: imx6: Enable DDR calibration on NovenaMarek Vasut
Enable the DDR calibration functionality on Novena to deal with the memory SoDIMM on this board. Moreover, tweak the initial DDR DRAM parameters so the calibration works properly. Signed-off-by: Marek Vasut <marex@denx.de>
2015-12-01arm: imx6: novena, gw_ventana: Fix use of pfuze100 bit definitionsMarek Vasut
The following patch changed the PFUZE100 swbst register bit definitions and broke PMIC configuration on multiple boards, at least on the novena and gw_ventana. This patch fixes it. commit 8fa46350a4c7dca7710362f6c871098557b934ad Author: Peng Fan <Peng.Fan@freescale.com> Date: Fri Aug 7 16:43:45 2015 +0800 power: regulator: add pfuze100 support Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Peng Fan <Peng.Fan@freescale.com> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Tim Harvey <tharvey@gateworks.com>
2015-11-19input: Support the German keymapSimon Glass
Add support for the German keymap, taken from i8042.c. This can be selected when the input library it initialised. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19input: Add the keycode translation tables separatelySimon Glass
Require the caller to add the keycode translation tables separately so that it can select which ones to use. In a later patch we will add the option to add German tables. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-12novena: Remove empty reset_cpu()Fabio Estevam
There is really no need to provide an empty reset_cpu() implementation, so just remove it. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2015-11-05video: Drop DEV_FLAGS_SYSTEM flagBin Meng
DEV_FLAGS_SYSTEM does not have any actual meaning, hence drop it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric BĂ©nard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2014-12-30arm: mx6: novena: Add proper LVDS display supportMarek Vasut
Repair the register configuration and add proper support for the display attached to both LVDS channels. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Pull video handling into separate fileMarek Vasut
Pull all of the video handling into a separate file, since a lot more code will be added and such code would polute the board file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Pull GPIO definitions into headerMarek Vasut
Pull the definitions of GPIOs into a separate header file, so that they can be used across all source files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-12-30arm: mx6: novena: Minor coding style fixMarek Vasut
Just zap multiple spaces and replace them with tabs properly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Sean Cross <xobs@kosagi.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com>
2014-11-20mx6: Use a common SPL configuration fileFabio Estevam
Many boards use a minimal .cfg file in the SPL case. Introduce spl_sd.cfg so that we can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-20novena: Move the DCD settings to spl codeFabio Estevam
mx6sabresd_spl.cfg configures CCM registers, GPR registers and CCM_CCOSR. Move the configuration to the spl code. CCM_CCOSR setting is no longer required to get audio functionality in the kernel, so remove such setting. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Marek Vasut <marex@denx.de>
2014-11-13kconfig: arm: select CPU_V7 for some new boardsMasahiro Yamada
This commit adds "select CPU_V7" for some new boards that were not covered by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). Redundant "SYS_CPU" defines and "string" directives should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Georges Savoundararadj <savoundg@gmail.com>
2014-11-03novena: Add MAINTAINERS fileFabio Estevam
Commit f91c09acf5c58c ("ARM: mx6: Add support for Kosagi Novena") missed to add a MAINTAINERS file, so add Marek as the maintainer. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-30novena: Fix ethernet PHY reset sequenceNikolay Dimitrov
This patch fixes conflict between PHY pins becoming outputs after reset and imx6 still driving the pins. It also fixes the reset timing as recommended by the PHY datasheet. Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Marek Vasut <marex@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-30ARM: mx6: Add support for Kosagi NovenaMarek Vasut
Add support for the Kosagi Novena board. Currently supported are: - I2C busses - FEC Ethernet - MMC0, MMC1, Booting from MMC - SATA - USB ports - USB Ethernet Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Nikolay Dimitrov <picmaster@mail.bg> Reviewed-by: Nikolay Dimitrov <picmaster@mail.bg>
