path: root/board/lantec/Makefile
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2001-05-01Initial revisionwdenk
