path: root/board/maxbcm
2016-01-14arm: mvebu: Consolidate board Kconfig options into one fileStefan Roese
Merging all the board specific Kconfig options into the main Kconfig file for mach-mvebu makes things easier to maintain. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14net: mvneta: Convert to driver modelStefan Roese
Update this driver to support driver model. As all MVEBU boards using this driver are converted with this patch, the non-driver-model code can be removed completely. This is also the reason why this patch is quite big and includes a) the driver change and b) the platform change. As its not git-bisect save otherwise. With this conversion, some parameters are now extracted from the DT instread of using the config header defines. The supported properties right now are: PHY-mode ("phy-mode") and PHY-address ("reg"). The base addresses for the ethernet controllers can be removed from the header files as well. Please note that this patch also removes the E1000 network driver from some MVEBU config headers. This is necessary, as with DM_ETH configured and the e1000 driver enabled, the PCI driver also needs to support DM. But the MVEBU PCI(e) driver still needs to get ported to DM. When this is done, the E1000 driver can be enabled again. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: Add DM and OF_CONTROL support to SPLStefan Roese
This patch adds full DM support to the SPL on MVEBU. Currently only serial is supported. Other drivers will follow. This patch also adds the necessary config values for the DEBUG UART to the MVEBU defconfig files. This came in handy while implementing this DM support. Additionally, the mvebu specific SPL linker script is removed and this common one is used instead: arch/arm/cpu/u-boot-spl.lds This common linker script already handles all special cases. No need to reinvent the wheel for MVEBU here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2015-10-20arm: mvebu: Move Armada XP/38x Kconfig to mach specific Kconfig fileStefan Roese
Introduce a mach-mvebu/Kconfig for all Armada based SoC's. Signed-off-by: Stefan Roese <sr@denx.de>
2015-07-23arm: mvebu: serdes: Move Armada XP SERDES / PHY init code into new directoryStefan Roese
With the upcoming addition of the Armada 38x SPL support, which is not compatible to the Armada XP SERDES init code, we need to introduce a new directory infrastructure. So lets move the AXP serdes init code into a new directory. This way the A38x code can be added in a clean way. Signed-off-by: Stefan Roese <sr@denx.de>
2015-05-05arm: mvebu: Move mvebu-common into mach-mvebuStefan Roese
Now that the mach-mvebu directory exists and is used by Armada XP we can move the mvebu-common files into this directory as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-05-05arm: armada-xp: Move SoC headers to mach-mvebu/include/machStefan Roese
Move arch/arm/include/asm/arch-armada-xp/* -> arch/arm/mach-mvebu/include/mach/* Additionally the SYS_SOC is renamed from "armada-xp" to "mvebu". With this change all these files can better be shared with other, newer Mavell MVEBU SoC's. Like the upcoming Armada 38x support. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com> Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-02-06arm: mvebu: maxbcm: Fix compilation warning and add Spansion SPI NOR supportStefan Roese
This patch fixes the following compilation warning for maxbcm: Building maxbcm board... text data bss dec hex filename 160075 6596 38240 204911 3206f ./u-boot board/maxbcm/maxbcm.c: In function 'reset_phy': board/maxbcm/maxbcm.c:68:6: warning: unused variable 'reg' [-Wunused-variable] u16 reg; ^ board/maxbcm/maxbcm.c:66:6: warning: unused variable 'devadr' [-Wunused-variable] u16 devadr = CONFIG_PHY_BASE_ADDR; ^ Additionally support Spansion SPI NOR flash is added. With larger SPI device support via the CONFIG_SPI_FLASH_BAR define. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-06arm: maxbcm: Enable SPL to include DDR training code into U-BootStefan Roese
This patch adds SPL support to the maxbcm MV78460 based board. Including the fixed DDR configuratrion needed for the DDR training code. And the the serdes PHY init code. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2015-02-06arm: mvebu: Placeholder bin_hdr file can now be removedStefan Roese
With this patchset the Marvell bin_hdr (DDR training) code is intergrated into mainline U-Boot. We can remove the placeholder file again, which was only introduced to make U-Boot compile and link again. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
2014-11-13kconfig: arm: select CPU_V7 for some new boardsMasahiro Yamada
This commit adds "select CPU_V7" for some new boards that were not covered by commit 2e07c249a67e (kconfig: arm: introduce symbol for ARM CPUs). Redundant "SYS_CPU" defines and "string" directives should be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Georges Savoundararadj <savoundg@gmail.com>
2014-10-27arm: db-mv784mp-gp/maxbcm Add placeholder bin_hdr file so that linking worksStefan Roese
This file should contain the bin_hdr generated by the original Marvell U-Boot implementation. As this is currently not included in this U-Boot version, we have added this placeholder, so that the U-Boot image can be generated without errors. If you have a known to be working bin_hdr for your board, then you just need to replace this text file here with the binary header and recompile U-Boot. In a few weeks, mainline U-Boot will get support to generate the bin_hdr with the DDR training code itself. By implementing this code as SPL U-Boot. Then this file will not be needed any more and will get removed. Signed-off-by: Stefan Roese <sr@denx.de>
2014-10-23arm: armada-xp: Add basic support for the maxBCM boardStefan Roese
The maxBCM board is equipped with the Marvell Armada-XP MV78460 SoC. It integrates an SPI NOR flash and an Marvell 88E6185 switch. Signed-off-by: Stefan Roese <sr@denx.de>
