path: root/board/ml2/flash.c
2012-10-15ppc4xx: Remove ML2 board supportStefan Roese
As the board seems to be unmaintained for some time, lets remove the support in mainline completely. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Peter De Schrijver <p2@mind.be> Acked-by: Marek Vasut <marex@denx.de>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2003-09-18* Patches by Anders Larsen, 17 Sep 2003:wdenk
- fix spelling errors - set GD_FLG_DEVINIT flag only after device function pointers are valid - Allow CFG_ALT_MEMTEST on systems where address zero isn't writeable - enable 3.rd UART (ST-UART) on PXA(XScale) CPUs - trigger watchdog while waiting in serial driver
