path: root/board/mpc8540ads/Makefile
2007-12-11Move the MPC8540 ADS board under board/freescale.Kumar Gala
Minor path corrections needed to ensure buildability. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2004-10-10* Patch by Jon Loeliger, 24 Aug 2004:wdenk
- Fix PCI window on MPC85xx; remove unneeded PCI initialization from board_early_init_f() - Provide SW workaround for PCI initialization on 85xx CDS - Convert MPC85xxADS to use common CFI flash driver * Cleanup: avoid compiler warnings * Add CMC PU2 board to MAKEALL script
