path: root/board/mpc8560ads/init.S
2007-12-11Move the MPC8560 ADS board under board/freescale.Kumar Gala
Minor path corrections needed to ensure buildability. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-04-23Fix PCI I/O space mapping on Freescale MPC85x0ADSSergei Shtylyov
The PCI I/O space mapping for Freescale MPC8540ADS board was broken by commit 52c7a68b8d587ebcf5a6b051b58b3d3ffa377ddc which failed to update the #define's describing the local address window used for the PCI I/O space accesses -- fix this and carry over the necessary changes into the MPC8560ADS code since the PCI I/O space mapping was also broken for this board (by the earlier commit 087454609e47295443af793a282cddcd91a5f49c). Add the comments clarifying how the PCI I/O space must be mapped to all the MPC85xx board config. headers. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> board/mpc8540ads/init.S | 4 ++-- board/mpc8560ads/init.S | 4 ++-- include/configs/MPC8540ADS.h | 5 ++--- include/configs/MPC8541CDS.h | 2 +- include/configs/MPC8548CDS.h | 2 +- include/configs/MPC8560ADS.h | 8 ++++---- 6 files changed, 12 insertions(+), 13 deletions(-)
2004-08-01Patch by Jon Loeliger, 16 Jul 2004:wdenk
- support larger DDR memories up to 2G on the PC8540/8560ADS and STXGP3 boards - Made MPC8540/8560ADS be 33Mhz PCI by default. - Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16 and CONFIG_L2_INIT_RAM options. - Refactor Local Bus initialization out of SDRAM setup. - Re-implement new version of LBC11/DDR11 errata workarounds. - Moved board specific PCI init parts out of CPU directory. - Added TLB entry for PCI-1 IO Memory - Updated README.mpc85xxads
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
2004-06-09Patches Part 1 by Jon Loeliger, 11 May 2004:wdenk
Dynamically handle REV1 and REV2 MPC85xx parts. (Jon Loeliger, 10-May-2004). New consistent memory map and Local Access Window across MPC85xx line. New CCSRBAR at 0xE000_0000 now. Add RAPID I/O memory map. New memory map in README.MPC85xxads (Kumar Gala, 10-May-2004) Better board and CPU identification on MPC85xx boards at boot. (Jon Loeliger, 10-May-2004) SDRAM clock control fixes on MPC8540ADS & MPC8560 boards. Some configuration options for MPC8540ADS & MPC8560ADS cleaned up. (Jim Robertson, 10-May-2004) Rewrite of the MPC85xx Three Speed Ethernet Controller (TSEC) driver. Supports multiple PHYs. (Andy Fleming, 10-May-2004) Some README.MPC85xxads updates. (Kumar Gala, 10-May-2004) Copyright updates for "Freescale" (Andy Fleming, 10-May-2004)
