path: root/board/mscc
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-05-03board: mscc: luton: Update MSCC Luton boardHoratiu Vultur
Implement method board_phy_config to configure the external phys on the pcb90. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-05-03board: mscc: ocelot: Update MSCC Ocelot board.Horatiu Vultur
Implement method board_phy_config to configure the phy for pcb120. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-05-03board: mscc: serval: Update MSCC Serval boardsHoratiu Vultur
In Serval SoC family there are 2 different pcb, both of them have the same phy, but with different version. Therefore implement board_phy_config and set all the phys in the same way. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-05-03board: mscc: serval: Fix board detectHoratiu Vultur
When detecting the board, it was reading a register in the GPIO page of the phy and based on that value it was making a decision. The bug was that after the GPIO page for the first phy was set it was not reseted back. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-04-12board: mscc: jr2: Update MSCC Jaguar2 boardsHoratiu Vultur
In Jaguar2 SoC family there are 3 different pcb. Each of this needs to configure the phys in different ways. Therefore implement the function board_phy_config and based on pcb configure them accordingly. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-02-01MSCC: Fix Jaguar2 board detection.Horatiu Vultur
When power cycle the Jaguar2 boards, it couldn't read the phys, therefore it always deduce that the board type is pcb111. Add a small delay after setting the gpio pins, fix the issue. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-02-01MSCC: Jaguar2 enable debug uartHoratiu Vultur
Enable debug uart for Jaguar2 SoC family. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-23MSCC: Add board support for Serval SoC family.Horatiu Vultur
Add board support and configuration for Jaguar2 SoC family. The detection of the board type is based on the phy ids. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2019-01-23MSCC: Add board support for Servalt SoC familyHoratiu Vultur
Add board support, configuration and DTS for Servalt SoC family. Currently there is one board in this family. Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-23MIPS: mscc: ocelot: add switch reset supportGregory CLEMENT
On some ocelots platform a workaround is needed in order to be able to reset the switch without resetting the DDR. Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2019-01-16MSCC: Add board support for Jaguar2 SOC familyHoratiu Vultur
Add board support and configuration for Jaguar2 SOC family. The detection of the board type in this family is based on the phy ids. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-16mips: ocelot: Enable use of serial gpio for LEDLars Povlsen
This enables the use of the MSCC serial GPIO driver to control the LEDs on the MSCC VCoreIII 'ocelot' pcb123 and pcb120. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2019-01-16mips: luton: Enable use of serial gpio for LEDLars Povlsen
This enables the use of the MSCC serial GPIO driver to control the LEDs on the MSCC VCoreIII 'luton' SoC. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2019-01-16mips: mscc: luton+ocelot: Remove board config options, do probingLars Povlsen
As we are moving to multi-dtb and board detection, remove static board config options, and introduce board probing instead. Luton: This add single-binary support for the two MSCC luton-based reference boards - pcb090 and pcb091. The SoC chip ID is used to determine the board type. Ocelot: This add single-binary support for the two MSCC ocelot-based reference boards - pcb120 and pcb123. The PHY ids on specific ports are used to determine the board type. Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
2018-12-19MSCC: add board support for the Luton based evaluation boardGregory CLEMENT
Adding the support for the Luton boards PCB91 which share common code with the Ocelots boards, including board code, device tree and configuration. Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
2018-12-19MSCC: add board support for the Ocelots based evaluation boardsGregory CLEMENT
Adding the support for 2 boards sharing common code for Ocelot chip: PCB120 and PCB123 Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
