path: root/board/qca
2016-05-31mips: ath79: ap143: Reset ethernet on bootWills Wang
This patch reset the ethernet controller for ap143 board Signed-off-by: Wills Wang <wills.wang@live.com>
2016-05-31mips: ath79: ap121: Enable ethernetWills Wang
This patch enable network function for ap121 board. Signed-off-by: Wills Wang <wills.wang@live.com> Acked-by: Marek Vasut <marex@denx.de>
2016-05-31MIPS: Split I & D cache line size configPaul Burton
Allow L1 Icache & L1 Dcache line size to be specified separately, since there's no architectural mandate that they be the same. The [id]cache_line_size functions are tidied up to take advantage of the fact that the Kconfig entries are always present to simply check them for zero rather than needing to #ifdef on their presence. Signed-off-by: Paul Burton <paul.burton@imgtec.com> [removed CONFIG_SYS_CACHELINE_SIZE in include/configs/pic32mzdask.h] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-31MIPS: Move cache sizes to KconfigPaul Burton
Move details of the L1 cache line sizes & total sizes into Kconfig, defaulting to 0. A new CONFIG_SYS_CACHE_SIZE_AUTO Kconfig entry is introduced to allow platforms to select auto-detection of cache sizes, and it defaults to being enabled if none of the cache sizes are set by the configuration (ie. sizes are all the default 0), and code is adjusted to #ifdef on that rather than on the definition of the sizes (which will always be defined even if 0). Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-21mips: ath79: add AP143 reference boardWills Wang
This patch add board-level code and base DT for AP143. Signed-off-by: Wills Wang <wills.wang@live.com> [updated defconfig, enabled CONFIG_USE_PRIVATE_LIBGCC=y] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-21mips: ath79: add AP121 reference boardWills Wang
This patch add board-level code and base DT for AP121. Signed-off-by: Wills Wang <wills.wang@live.com> [updated defconfig, enabled CONFIG_USE_PRIVATE_LIBGCC=y] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
