path: root/board/raidsonic
2020-05-18common: Drop init.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-25cosmetic: kirkwood: style fixes in kwbimage.cfg filesLuka Perkov
When diffing through the changes only the relevant changes should be displayed. Signed-off-by: Luka Perkov <luka@openwrt.org> Acked-by: Stefan Roese <sr@denx.de>
2014-10-23arm: kirkwood: Change naming of dram functions from km_foo() to mvebu_foo()Stefan Roese
Additionally the SDRAM address decoding register address is not hard coded in the C code any more. A define is introduced for this base address. This makes is possible to use those gpio functions from other MVEBU SoC's as well. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-10-23arm: marvell: Extract kirkwood gpio functions into new common file gpio.cStefan Roese
2014-10-23arm: marvell: Move arch/kirkwood.h to arch/soc.hStefan Roese
This move makes is possible to use this header not only from kirkwood platforms but from all Marvell mvebu platforms. Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-01-09kirkwood: make MPP arrays static constAlbert ARIBAUD
This saves stack and code memory for local copy, and consumes initialized data memory. For 22 of the 29 kirkwood-based boards, this results in a global saving of about 30 bytes. For 7 of them, it results in an increase of 6 to 14 bytes. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-12-07Change e-mail address of Luka PerkovLuka Perkov
Change e-mail address of Luka Perkov. Signed-off-by: Luka Perkov <luka@openwrt.org> CC: Luka Perkov <uboot@lukaperkov.net>
2012-10-03kirkwood: ib62x0: Invert SATA activity LEDsSimon Baatz
The hardware design of the IB-NAS62x0 causes the SATA activity LEDs to be on when idle by default. Reverse the polarity of the activity LEDs in early init. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Cc: Luka Perkov <uboot@lukaperkov.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Luka Perkov <uboot@lukaperkov.net>
2012-07-07kirkwood: fix calls to kirkwood_mpp_confValentin Longchamp
With the new second save argument introduced by the previous patch, all the calls to the function had to be fixed. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-05-15kirkwood: add NAS62x0 board supportLuka Perkov
Add support for new boards RaidSonic ICY BOX NAS6210 and NAS6220. NAS6210 has 1 SATA and 1 eSATA port while NAS6220 has 2 SATA ports. More information about the boards can be found here: http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7036 http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7515 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Signed-off-by: Gerald Kerma <dreagle@doukki.net> Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
