path: root/board/socrates/tlb.c
2008-12-0385xx: socrates: fix DDR SDRAM tlb entry configurationAnatolij Gustschin
since commit be0bd8234b9777ecd63c4c686f72af070d886517 tlb entry for socrates DDR SDRAM will be reconfigured by setup_ddr_tlbs() from initdram() causing an inconsistency with previously configured DDR SDRAM tlb entry from tlb_table: socrates>l2cam 7 9 IDX PID EPN SIZE V TS RPN U0-U3 WIMGE UUUSSS 7 : 00 00000000 256MB V 0 -> 0_00000000 0000 -I-G- ---RWX 8 : 00 00000000 256MB V 0 -> 0_00000000 0000 ----- ---RWX 9 : 00 10000000 256MB V 0 -> 0_10000000 0000 ----- ---RWX This patch makes the presence of the DDR SDRAM tlb entry in the tlb_table dependent on CONFIG_SPD_EEPROM to avoid this inconsistency. Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Andy Fleming <afleming@freescale.com>
2008-09-0985xx: socrates: Enable Lime support.Anatolij Gustschin
This patch adds Lime GDC support together with support for the PWM backlight control through the w83782d chip. The reset pin of the latter is attached to GPIO, so we need to reset it in early_board_init_r. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-06-11Socrates: Added FPGA mapping. LAWs and TLBs cleanup.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2008-05-20Initial support for "Socrates" boardSergei Poselenov
