path: root/board/tbs
2016-03-02board: tbs2910: Fix eMMC BOOTCFG valueSoeren Moch
Fix the BOOTCFG value for eMMC in the same way as commit 214c3f0f9921250eb336c7effadcc16158ea9df5 [imx: MX6DQ{P}/DL:SABRESD Fix bmode eMMC failure] did for sabresd. Signed-off-by: Soeren Moch <smoch@web.de>
2016-02-21Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-02-21board: tbs2910: Autoselect environment device when booting from SDSoeren Moch
Implement board specific functions to select the environment device and partition when booting from SD/MMC. SD2: mmc 0 0 SD3: mmc 1 0 eMMC: mmc 2 1 Signed-off-by: Soeren Moch <smoch@web.de>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-09-02tbs2910: remove SYS_SOC from board specific KconfigSoeren Moch
SYS_SOC is already defined in arch/arm/cpu/armv7/mx6/Kconfig, no need to define it again Signed-off-by: Soeren Moch <smoch@web.de>
2015-09-02tbs2910: remove deprecated CONFIG_SYS_EXTRA_OPTIONSSoeren Moch
move options from CONFIG_SYS_EXTRA_OPTIONS to board specific Kconfig Signed-off-by: Soeren Moch <smoch@web.de>
2015-05-15tbs2910: support for usb otg host modeSoeren Moch
Add support for USB OTG host mode. Only high speed devices supported so far (e.g. usb 2.0 hub required to connect a keyboard). Signed-off-by: Soeren Moch <smoch@web.de>
2015-02-23board: tbs2910: Gate clock when switching async clock muxesSoeren Moch
According to the i.MX6Q Reference Manual, clocks must be gated when switching input clocks of async clock muxes. So use clock gates. Avoid ldb_di0_ipu clock, because there is no clock gate for this signal. There have never been any complaints about problems with the old code, but the new approach is in line with the recommendations in the manual. Signed-off-by: Soeren Moch <smoch@web.de>
2014-12-01tbs2910: fix KconfigSoeren Moch
fix Kconfig for tbs2910 board to prevent crash on relocation Signed-off-by: Soeren Moch <smoch@web.de>
2014-11-21tbs2910: Fix error handling in board_mmc_init()Soeren Moch
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Based on similar patches by Fabio Estevam for mx6sabresd, mx53loco, wandboard Signed-off-by: Soeren Moch <smoch@web.de> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-13arm: mx6: add support for TBS2910 Matrix ARM miniPCSoeren Moch
Add initial support for TBS2910 Matrix ARM miniPC. Support includes MMC, Ethernet, UARTs, HDMI, USB, SATA, PCI, I2C, RTC. Signed-off-by: Soeren Moch <smoch@web.de>
