Remove duplicate MX6_PAD_LCD_CLK__LCDIF_CLK, provide pad configuration
MX6_PAD_LCD_VSYNC__LCDIF_VSYNC.
Relates-to: ELB-2725
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Provide proper configuration for USBC_DET pin.
Disable output driver of PAD CCM_PMIC_STBY_REQ. This prevents the
SOC to request for a lower voltage during sleep. This is necessary
because the voltage is changing too slow for the SOC to wake up
properly.
Just give the new Ethernet PHY power save mode circuitry time to settle.
U-Boot typically tears down the display controller before handing
control over to Linux. On LCD displays disabling pixel clock leads to a
fading out effect with vertical/horizontal lines. Make sure to disable
back light before booting Linux.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Using CPU temperature grading as a discriminator if the Wi-Fi /
Bluetooth chip is populated is no longer possible due to upcoming
SKUs. Set variant to -wifi only if a valid config block is present
and the product id mentions a SKU with Wi-Fi / Bluetooth.
Use GPIO 0 of instance GPIO5 which is used as card detect on
Colibri iMX6ULL. This fixes SD card detection.
Set the ASR bit to enable auto self refresh for RAM in mode register 2.
In ASR the refresh rate is dynamically adjusted to temperature
which is more power efficient in suspend to RAM.
Signed-off-by: Sven Guggisberg <sven.guggisberg@toradex.com>
In upstream Linux the GPMI NAND node of i.MX 6UL/6ULL uses
"fsl,imx6q-gpmi-nand" as compatible string. Add both to make
sure U-Boot fixups the MTD partitions for downstream and upstream
kernels.
Add handling for the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT
Use the correct compatible string for the i.MX6ULL GPMI device
tree node to make sure MTD partition passing to the Linux kernel
works.
In case USB serial downloader has been used to load U-Boot start the
serial download protocol (SDP) emulation. This allows to download
complete images such as Toradex Easy Installer over USB SDP as well.
This code uses the boot ROM provided boot information to reliably
detect USB serial downloader.
Setup all UARTs in DTE mode, so that when Linux does the pinmuxing
the data direction is already correct and no two outputs are working
against each other.
Make sure that with the switch also the UARTs' RI and DCD interrupts
are masked.
The resulting U-Boot boots at least from serial downloader mode.
