T20 uses different addresses for its EHCI controllers which I missed.
Fix this.
Use device tree to set MAC address of the Ethernet chip.
Use device tree to set MTD partitions of the NAND chip.
(cherry picked from commit 0a9606863b0e7b8edfad02467a4e63c6c68025ee)
Migrate Colibri T20 to U-Boot 2016.11.
(cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
Add our support email address as well as our developer website as
official maintenance point of contacts:
Toradex ARM Support <support.arm@toradex.com>
http://developer.toradex.com/software/linux/linux-software
(cherry picked from commit c675aa26ad6a4a25d09c1079dda61ef24abd3770)
The config block support currently uses the ft_board_setup function
to patch the device tree with config block information. However, this
does not allow to patch the device tree with board specific information.
Rename the common setup function to ft_common_board_setup and use the
call it from the board files directly.
(cherry picked from commit 37fa41256bd756f3652e7479b976982092a4f9bc)
With our common code in place actually make use of it across all our
modules.
(cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
There are currently many places that define the list of all Tegra GPIOs;
the DT binding header and custom Tegra-specific header file gpio.h. Fix
the redundancy by replacing everything with the DT binding header file.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This option refers only to the tegra20 video driver, so name it as such
to avoid confusion with tegra124.
Also move this option to Kconfig.
Acked-by: Anatolij Gustschin <agust@denx.de>
Make sure SODIMM pin 87 nRESET_OUT is released properly by explicitly
setting its pin mux function to GMI. This solves some issues with e.g.
USB not being fully operational on carrier boards with USB hubs
connected to reset if U-Boot got loaded via recovery mode aka rcm.
The Colibri T20's PMIC enters a sleep mode on low supply voltage < 3.0V
±2.5% (2.92...3.08V). Rising the main supply voltage again does not
bring it back to regular operation. Not even a full reset does bring
the module back. A full power cycle was required to reboot the system.
A long positive pulse on the PMICs resume pin also reboots the system
but this pin is only accessible as a test point on the module.
This patch configures the PMIC through I2C to not enter this sleep mode
plus force it to normal state upon sleep request exit should this ever
happen.
Add LCD display support defaulting to VESA VGA resolution. Different
resolutions configurable via device tree.
Allow detecting whether or not U-Boot was launched through the
recovery mode of the resp. NVIDIA SoC.
Make use of a board specific arch_misc_init() and enable the same via
CONFIG_ARCH_MISC_INIT configuration option.
All the Tegra boards borrow the files from board/nvidia/common/
directory, i.e., board/nvidia/common/* are not vendor-common files,
but SoC-common files.
Move NVIDIA common files to arch/arm/mach-tegra/ to clean up
Makefiles.
As arch/arm/mach-tegra/board.c already exists, this commit renames
board/nvidia/common/board.c to arch/arm/mach-tegra/board2.c,
expecting they will be consolidated as a second step.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Tom Warren <twarren@nvidia.com>
Pingroup ATC seems to come out of reset with config set to NAND, so we
need to explicitly configure some other function to this group in order
to avoid clashing settings.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Fix ASIX USB to Ethernet chip reset.
In accordance with our other modules supported by U-Boot and as agreed
upon for Apalis/Colibri T30 get rid of the carrier board in the board/
configuration/device-tree naming.
While at it also bring the prompt more in line with our other products.
