path: root/board/xilinx/ppc405-generic
2016-01-27ppc: xilinx_ppc405_generic: Remove uncalled functionsRicardo Ribalda Delgado
board_pre_init was not called because CONFIG_BOARD_EARLY_INIT_F was not set. Remove unused function. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx_ppc405_generic: Remove weak attributesRicardo Ribalda Delgado
Now that the specific boards have been removed there is no need to maintain the weak functions. Fix also CamelCase to make checkpatch happy Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx-ppc4xx: Port to DM serialRicardo Ribalda Delgado
xilinx_uartlite has been ported to DM, this patch makes the xilinx-ppc405-generic and the xilinx-ppc440-generic boards use the new DM driver. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx-ppc4xx-generic: Update xparameters.hRicardo Ribalda Delgado
-Remove UART address (It is now part of the dts). -Include dummy ns16550 clock -Fix address to last test Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: pp405-generic: Simplify MakefileRicardo Ribalda Delgado
As a result of the specific board removal, the Makefiles can be simplified. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27mailaddr: Update mail addressRicardo Ribalda Delgado
The old mail address will stop working soon. Update it all the files Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2014-03-07xilinx: delete meaningless .gitignore filesMasahiro Yamada
config.tmp is never generated Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-01Makefile: convert makefiles to Kbuild style and delete grep switchMasahiro Yamada
We have converted all makefiles needed to build $(LIBS). Until this commit we used to grep switch so that U-Boot style and Kbuild style makefiles coexist. But we do not need any more. Goint forward, use always Kbuild style Makefile when adding a new Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-01-11xilinx-ppc4xx-generic: Fix Makefile to work with MAKEALLRicardo Ribalda Delgado
config.mk only mkdirs $(obj), but we have objects shared with other boards located on other dirs. This patch mkdirs the needed dirs for the xlnx-generic boards. Signed-off-by: Stefan Roese <sr@denx.de>
2010-12-17xilinx-ppc4xx-generic: Use common u-boot.ldsRicardo Ribalda Delgado
Use common ppc4xx linker script for xilinx ppc440 and ppc405 related boards. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-23unify HOST_CFLAGS and HOSTCFLAGSMike Frysinger
The top build system sets up HOSTCFLAGS a bit and exports it, but other places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the values stay in sync. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-12-14Fix new found CFG_Jean-Christophe PLAGNIOL-VILLARD
Also fix some minor typos. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-24ppc4xx: Generic architecture for xilinx ppc405(v3)Ricardo Ribalda Delgado
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx ppc440 boards, this patch presents a common architecture for all the xilinx ppc405 boards. Any custom xilinx ppc405 board can be added very easily with no code duplicity. This patch also adds a simple generic board, that can be used on almost any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h This patch is prepared to work with the latest version of EDK (10.1) Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
