path: root/board/xilinx
2016-10-19arm: Provide common PSCI based reset handlerAlexander Graf
Most armv8 systems have PSCI support enabled in EL3, either through ARM Trusted Firmware or other firmware. On these systems, we do not need to implement system reset manually, but can instead rely on higher level firmware to deal with it. The exclude list seems excessive right now, but NXP is working on providing an in-tree PSCI implementation, so that all NXP systems can eventually use PSCI as well. Signed-off-by: Alexander Graf <agraf@suse.de> [agraf: fix meson] Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-18arm: Disable HVC PSCI calls by defaultAlexander Graf
All systems that are running on armv8 are running bare metal with firmware that implements PSCI running in EL3. That means we don't really need to expose the hypercall variants of them. This patch leaves the code in, but makes the code explicit enough to have the compiler optimize it out. With this we don't need to worry about hvc vs smc calling convention when calling psci helper functions. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-22ARM64: zynqmp: Add support for chip ID detectionMichal Simek
Chip ID needs to be known for loading bitstream because U-Boot checks ID from bitstream header in BIT format. BIN format is completely unchecked. The chipid is get from ATF via SMC. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22ARM64: zynqmp: Add support for DFU from SPLMichal Simek
SPL needs to have bigger stack size because of USB. Simple malloc needs to be disabled because dfu code requires different allocation functions. There is no space in OCM that's why random place in DDR is used. BOOTD must be disabled because it is causing compilation error. All variables are disabled and used only variables valid for DFU because they are simple huge. Including automatic variables added by CONFIG_ENV_VARS_UBOOT_CONFIG. Hardcode addresses for u-boot, atf, kernel and dtb just for SPL DFU code. Enable SPL DFU for zcu100. Create new usb_dfu_spl variable just to run Linux kernel loaded in SPL. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22ARM64: zynqmp: Fix usb_gadget_handle_interrupt routineMichal Simek
Function is defined in g_dnl.h and have different parameter then it is used. This patch fixes it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22ARM64: zynqmp: Wire up both USBs available on ZynqMPMichal Simek
The second USB wasn't enabled. This patch fixes it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-08-02ARM64: zynqmp: Wire up PSCI resetMichal Simek
Using PSCI to reset the system. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Add support for standard distro boot commandsMichal Simek
Nand and QSPI are not defined now but this will be extended. Based on selected bootmode boot_targets are rewritten. Patch also contains detection if variables are saved. If yes don't rewrite boot_targets variable. Also move variable setup to the end of file because SCSI needs to be defined before others macros are using it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2016-06-06microblaze: Move MSR instruction selection to KconfigMichal Simek
Select MSR instructions via Kconfig instead of xparameters.h. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Add option to pass cpu version numberMichal Simek
Toolchain can use some flags by default based on cpu version. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06microblaze: Select compilation flags via KconfigMichal Simek
Remove autogenerated config.mk and select CPU options via Kconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-24ARM: zynq: Simplify zynq configurationMichal Simek
Extending Kconfig for adding new platform is a lot of work for nothing. Setting SYS_CONFIG_NAME directly in Kconfig and remove all dependencies on TARGET_ZYNQ_* options including SPL. As a side-effect it also remove custom init folder for ps7_init_gpl.* files. Folder is chosen based on device-tree file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-24ARM64: zynqmp: Add SPL support supportMichal Simek
Support RAM and MMC boot mode in SPL also with SPL_FIT images. In MMC boot mode two boot options are available: 1) Boot flow with ATF(EL3) and full U-Boot(EL2): aarch64-linux-gnu-objcopy -O binary bl31.elf bl31.bin mkimage -A arm64 -O linux -T kernel -C none -a 0xfffe5000 -e 0xfffe5000 -d bl31.bin atf.ub cp spl/boot.bin <sdcard fat partition> cp atf.ub <sdcard fat partition> cp u-boot.bin <sdcard fat partition> 2) Boot flow with full U-Boot(EL3): cp spl/boot.bin <sdcard> cp u-boot*.img <sdcard> 3) emmc boot mode dd if=/dev/zero of=sd.img bs=1024 count=1024 parted sd.img mktable msdos parted sd.img mkpart p fat32 0% 100% kpartx -a sd.img mkfs.vfat /dev/mapper/loop0p1 mount /dev/mapper/loop0p1 /mnt/ cp spl/boot.bin /mnt cp u-boot.img /mnt cp u-boot.bin /mnt cp atf.ub /mnt umount /dev/mapper/loop0p1 kpartx -d sd.img cp sd.img /tftpboot/ and program it via u-boot tftpb 10000 sd.img mmcinfo mmc write 10000 0 $filesize mmc rescan mmc part ls mmc 0 psu_init() function contains low level SoC setup generated for every HW design by Xilinx design tools. xil_io.h is only supporting file to fix all dependencies from tools. The same solution was used on Xilinx Zynq. The patch also change CONFIG_SYS_INIT_SP_ADDR to the end of OCM which stays at the same location all the time. Bootrom expects starting address to be at 0xfffc0000 that's why this address is SPL_TEXT_BASE. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-24ARM64: zynqmp: Add support for reading MAC from eepromMichal Simek
Add support for on board eeprom with programmed MAC for using in u-boot to have uniq address for every board. Most of the time uniq MAC address is on a label on the board. If address is not programmed use these command to program it. On zcu102: ZynqMP> mm.b 0 00000000: 00 ? 00 00000001: a0 ? 0a 00000002: 35 ? 35 00000003: 02 ? 02 00000004: 00 ? ef 00000005: 00 ? 67 00000006: 00 ? q i2c dev 5 i2c write 0 54 20 6 i2c md 54 20 Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Remove netdev.h from board fileMichal Simek
Including netdev.h is causing compilation warning: + int fecmxc_register_mii_postcall(struct eth_device *dev, int (*cb)(int)); + ^ w+In file included from ../board/xilinx/zynqmp/zynqmp.c:9:0: w+../include/netdev.h:204:41: warning: ‘struct eth_device’ declared inside parameter list [enabled by default] w+../include/netdev.h:204:41: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default] This patch removes it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM64: zynqmp: Make DDR detection code work on 32bit systemMichal Simek
Define u64 types to be usable on 32bit system because of 64bit address and size cells and 32bit shifts in the code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-13ARM: zynq: Support systems with more memory banksMichal Simek
This is example how to change u-boot to support more memory banks read from DT. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04block: Add support for Ceva sataMichal Simek
Initial Ceva Sata init code. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-04ARM64: zynqmp: Simplify MAINTAINERS file to support more boardsMichal Simek
Handle all Xilinx ZynqMP boards with one fragment. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04ARM64: zynqmp: Read RAM information from DTMichal Simek
Read information about memory from DT. This patch simplify life with synchronization between DT and board files. dram_init() only needs maximum RAM size below 4GB that's why please sort banks in memory node. dram_init_banksize() copies memory setup to bi_dram[]. This will avoid reading information from DT twice. Memory test start/end were changed to DDR location to let memtest still compiled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04microblaze: Remove !OF_CONTROL code for timer and interruptMichal Simek
OF_CONTROL is enabled by default that's why this is dead code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04ARM: zynq: Fix default ps7_init_gpl.c/h for ZYBOMichal Simek
There is incorrect setting for USB which didn't work with origin ps7_init_gpl.X files. Use default setting for Digilent Zybo projects with HDMI in PL. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04net: gem: Allow to set the MAC from an EEPROMJoe Hershberger
Provide board specific option how to read MAC address from ROM. Do it in generic way to be reusable by differnet boards. If this is not enough board specific functions can be created. Signed-off-by: Joe Hershberger <joe.hershberger@gmail.com> # driver part Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-02-22ARM: zynq: Read memory size setting from DTMichal Simek
OF_CONTROL is setup by default and memory reading is done via DT. Remove all config files with memory references. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx-ppc440-generic: Wire LL_TEMAC driverRicardo Ribalda Delgado
If the xparameters file contains a LL_TEMAC definition compile its driver and the net commands. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx_ppc440_generic: Remove uncalled functionsRicardo Ribalda Delgado
board_pre_init was not called because CONFIG_BOARD_EARLY_INIT_F was not set. Remove unused function. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx_ppc405_generic: Remove uncalled functionsRicardo Ribalda Delgado
2016-01-27ppc: xilinx_ppc440_generic: Remove weak attributesRicardo Ribalda Delgado
Now that the specific boards have been removed there is no need to maintain the weak functions. Fix also CamelCase to make checkpatch happy Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: xilinx_ppc405_generic: Remove weak attributesRicardo Ribalda Delgado
2016-01-27ppc: xilinx-ppc4xx: Port to DM serialRicardo Ribalda Delgado
xilinx_uartlite has been ported to DM, this patch makes the xilinx-ppc405-generic and the xilinx-ppc440-generic boards use the new DM driver. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: zynqmp: Line up checkboard messageMichal Simek
Use space instead of tab in checkboard print to aligned it with others boards. Reported-by: David Glessner <david.glessner@rockwellcollins.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Moritz Fischer <moritz.fischer@ettus.com>
2016-01-27ARM64: zynqmp: Remove unneeded timer_init functionMichal Simek
Empty weak function is used instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Fix bootmode SD_MODE1Michal Simek
When only sdhci1 IP is enabled and SD_MODE1 bootmode is selected U-Boot using sdboot1 variable which refers to mmc dev 1. But this device doesn't exist because only one controller is available. This patch fix logic around sdboot mode with using sdbootdev internal variable. Reported-by: Chris Kohn <ckohn@xilinx.com> Acked-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Differentiate EMMC boot modeMichal Simek
Show also EMMC bootmode if selected. There is difference compare to SD bootmode. Use the same bootcommand till better boot command is created. Reported-by: Sai Pavan Boddu <saipava@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Show information about bootmodeMichal Simek
Showing information about bootmode is very useful to make sure that correct bootmode is selected. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Add support for SD1 boot modeMichal Simek
SD1 boot mode is using different bootmode values. Add support for this mode used on DC1. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Modify the SD and QSPI bootmode valuesSiva Durga Prasad Paladugu
Modify the SD bootmode value to 0x3 as per latest spec. Also add new boot mode QSPI 32 bit boot mode Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM64: zynqmp: Use the same U-Boot version with/without ATFMichal Simek
Remove SECURE_IOU option which is not needed. U-Boot itself can detect which EL level it is on and based on that use do platform setup. It also simplify usage because one Kconfig entry is gone. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Fix board_init calling sequenceMichal Simek
board_init() is in final elf file but it is not called at all. Use board_init_late() instead and call gpio_init() from it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Read information about RAM from DTMichal Simek
Do not setup ram start/size in board file. Read it from DT instead. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27microblaze: Remove systemace from board fileMichal Simek
Systemace is ancient IP which is not tested. Remove it from default configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27net: emaclite: Move emaclite to KconfigMichal Simek
Add PHYLIB and MII dependencies and enable it by default for Microblaze. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: emaclite: Move driver to DMMichal Simek
Move driver to DM. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-27net: axi_emac: Move driver to DMMichal Simek
2016-01-27microblaze: Remove unused I2C macrosMichal Simek
There is no i2c driver in the current u-boot. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27serial: uartlite: Add uartlite to KconfigMichal Simek
- Move config option out of board file. - Remove uartlite address from config file Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
2016-01-27ppc: xilinx-ppc4xx-generic: Update xparameters.hRicardo Ribalda Delgado
-Remove UART address (It is now part of the dts). -Include dummy ns16550 clock -Fix address to last test Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: pp440-generic: Simplify MakefileRicardo Ribalda Delgado
As a result of the specific board removal, the Makefiles can be simplified. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ppc: pp405-generic: Simplify MakefileRicardo Ribalda Delgado
2016-01-27mailaddr: Update mail addressRicardo Ribalda Delgado
The old mail address will stop working soon. Update it all the files Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Michal Simek <michal.simek@xilinx.com>
