path: root/board
2008-12-15Add support for AT91SAM9G20-EK Board2008.10-at91-200812151807Justin Waters
This adds support for the AT91SAM9G20-EK board in the mainline U-Boot. Signed-off-by: Justin Waters <justin.waters@timesys.com>
2008-12-15Add support for the AT91RM9200-EK BoardJustin Waters
The AT91RM9200-EK board is very similar to the AT91RM9200-DK board. This adds support for it against the mainline u-boot. Signed-off-by: Justin Waters <justin.waters@timesys.com>
2008-10-1785xx: Fix compile warningKumar Gala
mpc8536ds.c: In function 'is_sata_supported': mpc8536ds.c:614: warning: unused variable 'devdisr' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-15Fix compiler warning in lib_ppc/board.cHeiko Schocher
Fix compiler warning introduced by commit 0f8cbc18 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-14Do not init SATA when disabled on 8536DS.Jason Jin
SGMII and SATA share the serdes on MPC8536 CPU, When SATA disabled and the driver still try to access the SATA registers, the cpu will hangup. This patch try to fix this by reading the serdes status before the SATA initialize. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-14fsl_diu: fix alignment error that caused malloc corruptionNikita V. Youshchenko
When aligning malloc()ed screen_base, invalid offset was added. This not only caused misaligned result (which did not cause hardware misbehaviour), but - worse - caused screen_base + smem_len to be out of malloc()ed space, which in turn caused breakage of futher malloc()/free() operation. This patch fixes screen_base alignment. Also this patch makes memset() that cleans framebuffer to be executed on first initialization of diu, not only on re-initialization. It looks correct to clean the framebuffer instead of displaying random garbage; I believe that was disabled only because that memset caused breakage of malloc/free described above - which no longer happens with the fix described above. Signed-off-by: Nikita V. Youshchenko <yoush@debian.org>
2008-10-13ARM DaVinci: Remove redundant setting of GD_FLG_RELOC for sffsdr board.Hugo Villeneuve
This is no longer necessary now that the GD_FLG_RELOC flag is set for all ARM boards. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2008-10-13Merge branch 'master' of /home/stefan/git/u-boot/u-bootStefan Roese
2008-10-12Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2008-10-10ppc4xx: Fix USB 2.0 phy reset sequenceMatthias Fuchs
This patch fixes USB 2.0 communication issues on some DU440 boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-10ppc4xx: Add strapping mode for 667MHz CPU frequency on DU440 boardMatthias Fuchs
2008-10-10ppc4xx: Fix DU440 GPIO configurationMatthias Fuchs
2008-10-08FSL: Fix get_cpu_board_revision() return value.Rafal Czubak
get_cpu_board_revision() returned board revision based on information stored in global static struct eeprom. It should instead use one from local struct board_eeprom, to which the data is actually read from EEPROM. The bug led to system hang after printing L1 cache information on U-Boot startup. The problem was observed on MPC8555CDS system and possibly affects other Freescale MPC85xx boards using CFG_I2C_EEPROM_CCID. The change has been successfully tested on MPC8555CDS system. Signed-off-by: Rafal Czubak <rcz@semihalf.com>
2008-09-24mpc83xx: spd_sdram: fix ddr sdram base address assignment bugAnton Vorontsov
The spd_dram code shifts the base address, then masks 20 bits, but forgets to shift the base address back. Fix this by just masking the base address correctly. Found this bug while trying to relocate a DDR memory at the base != 0. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-09-22ppc4xx: Canyonlands: Remove unnecessary FDT warning upon DTB fixupStefan Roese
Depending on the configuration jumper "SATA SELECT", U-Boot disabled either one PCIe node or the SATA node in the device tree blob. This patch removes the unnecessary and even confusing warning, when the node is not found at all. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-22socrates: fix crash after relocationAnatolij Gustschin
Currently U-Boot crashes after relocation to RAM. Changing the CPO value of the DDR SDRAM TIMING_CFG_2 register to READ_LAT + 1 (to the value it was before conversion of socrates to new DDR code) fixes the problem. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-19sh: Fix compile warningNobuhiro Iwamatsu
2008-09-19sh: rsk7203: Add support pkt_data_pull and pkt_data_push functionNobuhiro Iwamatsu
Add function of smc911x, pkt_data_pull and pkt_data_push. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-09-17Coding style cleanup; update CHANEGLOGWolfgang Denk
2008-09-16TQM8xx: Fix CFI flash driver support for all TQM8xx based boardsWolfgang Denk
After switching to using the CFI flash driver, the correct remapping of the flash banks was forgotten. Also, some boards were not adapted, and the old legacy flash driver was not removed yet. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-09-1385xx: socrates: autoprobe Lime chipu-boot@bugs.denx.de
This patch is an attempt to implement autoprobing for the Lime presence on the bus. Configure GPCM for Lime CS2 and try to access chip ID registers. Second read atempt delivers register values if the chip is present. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-13sh: Fix compile error for r2dplusNobuhiro Iwamatsu
netdev.h was not include by r2dplus. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
2008-09-13Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-09-12Merge branch 'Makefile-next' of git://git.denx.de/u-boot-armWolfgang Denk
2008-09-12Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2008-09-12ppc4xx: Fix SDRAM inititialization of multiple 405 based board portsStefan Roese
This patch fixes a problem introdiced with patch bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by initdram()]. The boards affected are: - PCI405 - PPChameleonEVB - quad100hd - taihu - zeus Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-12ppc4xx: Add .gitignore file to xilinx-ppc440 boardsRicardo Ribalda Delgado
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-12ppc4xx: Fix in-tree build for ppc440-generic boardsRicardo Ribalda Delgado
2008-09-12Fix MACH_TYPE for the AT91RM9200DK board.Claudio Scordino
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-09-10delta, zylonite: Update nand_oobinfo to nand_ecclayout.Scott Wood
This is part of the switch to newer upstream MTD code. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-09-10muas3001: update BR4 settingsHeiko Schocher
Also set up the port pins for using I2C. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-09-10muas3001: added 64MB SDRAM autodetection.Heiko Schocher
2008-09-09Merge branch 'master' of ssh://10.10.0.7/home/wd/git/u-boot/masterWolfgang Denk
2008-09-09add board_eth_init() for sh7785lcr boardYoshihiro Shimoda
Fix the problem that cannot work RTL8169 on sh7785lcr board. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
2008-09-09trab: fix build problem after change to use do_div()Wolfgang Denk
We must link with libgeneric now. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09ppc4xx: ppc440-generic-ALL: Fix out of tree build v2Ricardo Ribalda Delgado
This patch solves the problems compiling ml507, v5fx30teval and ppc440-generic out of tree. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
2008-09-09Update i386 code (sc520_cdp)Graeme Russ
Attempt to bring i386 / sc520 inline with master Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-09-0985xx: socrates: Enable Lime support.Anatolij Gustschin
This patch adds Lime GDC support together with support for the PWM backlight control through the w83782d chip. The reset pin of the latter is attached to GPIO, so we need to reset it in early_board_init_r. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-09-0985xx: Socrates: Major code update.Detlev Zundel
- Update the local bus ranges in the FDT for Linux for the various devices connected to the local bus via chip-select. - Set the LCRR_DBYP bit in the LCRR for local bus frequencies lower than 66 MHz and uses I/O accessor functions consequently. - UPM data update. - Update of default environment and configuration. Use I2C multibus as we do have two I2C buses. Also enable sdram and ext2 commands. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-09-09Update Freescale 85xx boards to sys_eeprom.cTimur Tabi
The new sys_eeprom.c supports both the old CCID EEPROM format and the new NXID format, and so it obsoletes board/freescale/common/cds_eeprom.c. Freescale 86xx boards already use sys_eeprom.c, so this patch migrates the remaining Freescale 85xx boards to use it as well. cds_eeprom.c is deleted. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-09-09stxxtc: remove empty CONFIG_SHOW_ACTIVITY functionsWolfgang Denk
