headers first instead of always reading the whole images.
(featuring a NEC NL6448BC33-54. 10.4", 640x480 TFT display).
Fix NEC display names (it's 6440 [for 640x480], not 6640).
to exit Unlock Bypass Mode); adjust timings for flash, SRAM and CPLD
recent tools
* Add checksum verification to 'imls' command
* Add bd_info fields needed for 4xx Linux I2C driver
* Patch by Martin Krause, 4 Nov. 2003:
Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap)
* Print used network interface when CONFIG_NET_MULTI is set
Add low boot support for MPC5200
* Fix problem with dual PCMCIA support (NSCU)
* Fix MPC5200 I2C initialization function
* Patch by Kyle Harris, 30 Oct 2003:
Fix build errors for ixdp425 board
* Patch by David M. Horn, 29 Oct 2003:
Fixes to build under CYGWIN
* Get IceCube MGT5100 working (again)
* Fix problems in memory test on some boards (which was not
non-destructive as intended)
* Patch by Gary Jennejohn, 28 Oct 2003:
Change fs/fat/fat.c to put I/O buffers in BSS instead on the stack
to prevent stack overflow on ARM systems
small patch for mpc85xx
* Fix small problem in MPC5200 I2C driver
* Fix FCC3 support on ATC board
* TRAB auto-update: image type patch by Martin Krause, 17 Oct 2003
header on image type as encoded in the header
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
- Add support for Altera FPGA ACEX1K
* Patches by Thomas Lange, 09 Oct 2003:
- Endian swap ATA identity for all big endian CPUs, not just PPC
- MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize
args to linux
- add support for dbau1x00 board (MIPS32)
- fix cmd_ide.c for non ppc boards (read/write functions did not
add ATA base address)
- fix for shannon board
- #ifdef CONFIG_IDE_8xx_DIRECT some otherwise unused code
* Patch by Sangmoon Kim, 07 Oct 2003:
add support for debris board
Fixes for TRAB board
- /board/trab/rs485.c: correct baudrate
- /board/trab/cmd_trab.c: bug fix for problem with timer overflow in
udelay(); fix some timing problems with adc controller
- /board/trab/trab_fkt.c: add new commands: gain, eeprom and power;
modify commands: touch and buzzer
* Disable CONFIG_SUPPORT_VFAT when used with CONFIG_AUTO_UPDATE
(quick & dirty workaround for rogue pointer problem in get_vfatname());
Use direct function calls for auto_update instead of hush commands
- add support for Altera Nios-32 CPU
- add support for Nios Cyclone Development Kit (DK-1C20)
* Patch by Steven Scholz, 29 Sep 2003:
- A second parameter for bootm overwrites the load address for
"Standalone Application" images.
- bootm sets environment variable "filesize" to the resulting
(uncompressed) data length for "Standalone Application" images
when autostart is set to "no". Now you can do something like
if bootm $fpgadata $some_free_ram ; then
fpga load 0 $some_free_ram $filesize
fi
* Patch by Denis Peter, 25 Sept 2003:
add support for the MIP405 Rev. C board
add support for Zephyr Engineering ZPC.1900 board
* Patch by Anders Larsen, 23 Sep 2003:
add CMD_PORTIO to CFG_CMD_NONSTD (commands in question are only
implemented for the x86 architecture)
* Make fatload set filesize environment variable
fix potential buffer overlow problem
* enable basic / medium / high-end configurations for PPChameleonEVB
board; fix NAND code
* enable TFTP client code to specify to the server the desired
timeout value (see RFC-2349)
Cleanup for submitted patches.
- Fixes for MPC8266 default config
- Allow eth_loopback_test() on 8260 to use a subset of the FCC's
- fix spelling errors
- set GD_FLG_DEVINIT flag only after device function pointers
are valid
- Allow CFG_ALT_MEMTEST on systems where address zero isn't
writeable
- enable 3.rd UART (ST-UART) on PXA(XScale) CPUs
- trigger watchdog while waiting in serial driver
Minor cleanup of comments
- add description for missing CFG_CMD_* entries in the README file
- sacsng tweaks:
include/configs/sacsng.h:
+ Support extra bootp options like: 2nd DNS and send hostname
+ Enabling ping and irq command
+ Adding defines for a bunch of misc configrabled options
(patches for these options will be coming)
+ Adding watchdog support, but it isn't enabled yet.
board/sacsng/sacsng.c:
+ Suppressing unneeded output when the quiet environment
is non-zero.
+ show_boot_progress() now accepts any negative number as a
failure code.
+ show_boot_progress() flashes the error code 5 times, and
then resets the board to retry the boot from the top
* Patch by Gleb Natapov, 14 Sep 2003:
enable watchdog support for all MPC824x boards that have a watchdog
various changes to VCMA9 board specific files
* Add I2C support for MGT5100 / MPC5200
Changed default memory option on MPC8266ADS to NOT be Page Based
Interleave, since this doesn't work very well with the standard
16MB DIMM
* Patch by George G. Davis, 12 Sep 2003:
fix Makefile settings for sk98 driver
add burn-in tests for TRAB board
* Enable instruction cache on MPC5200 board
- allow for longer timeouts for USB mass storage devices
* Patch by Denis Peter, 11 Sep 2003:
- fix USB data pointer assignment for bulk only transfer.
- prevent to display erased directories in FAT filesystem.
* Change output format for NAND flash - make it look like for other
memory, too
add FAT support for IDE, SCSI and USB
* Patches by Gleb Natapov, 2 Sep 2003:
- cleanup of POST code for unsupported architectures
- MPC824x locks way0 of data cache for use as initial RAM;
this patch unlocks it after relocation to RAM and invalidates
the locked entries.
* Patch by Gleb Natapov, 30 Aug 2003:
new I2C driver for mpc107 bridge. Now works from flash.
* Patch by Dave Ellis, 11 Aug 2003:
- JFFS2: fix typo in common/cmd_jffs2.c
- JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option
- JFFS2: remove node version 0 warning
- JFFS2: accept JFFS2 PADDING nodes
- SXNI855T: add AM29LV800 support
- SXNI855T: move environment from EEPROM to flash
- SXNI855T: boot from JFFS2 in NOR or NAND flash
* Patch by Bill Hargen, 11 Aug 2003:
fixes for I2C on MPC8240
- fix i2c_write routine
- fix iprobe command
- eliminates use of global variables, plus dead code, cleanup.
(tested with USB memory sticks only)
* Avoid flicker on TRAB's VFD
* Add PCI support for SL8245 board
* Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB)
or 1 x AM29LV652 (two LV065 in one chip = 16 MB);
Run IPB at 133 Mhz; adjust the MII clock frequency accordingly
* Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz)
to allow for more accurate baudrate settings
(error now 0.7% at 115 kbps, instead of 3.5% before)
* Patch by Andreas Mohr, 4 Sep 2003:
Fix a lot of spelling errors
* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
According to the MPC8260 User's Manual, PCI_MODE signal should be
reflected in SCCR register, and local bus pins configuration is taken
from HRCW and appears in SIUMCR. For some reason it does not work
this way, so the only possibility to detect if the board is
configured in PCI mode is to check the BCSR. This patch sets SCCR and
SIUMCR according to the BCSR.
