Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of
ARM's relocate_code() useless since it moved the code handling them to crt0.S.
So, drop these parameters.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
This also fixes support for mx31pdk and tx25, which had been broken by commit
e05e5de7fae5bec79617e113916dac6631251156.
Acked-by: Scott Wood <scottwood@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Use __image_copy_end instead of __bss_start for the end of the image to
relocate. This is the same as commit 033ca72, but applied to all ARM start.S.
This is a more appropriate symbol naming for an image copy & relocate feature,
and this also saves a useless copy of data put between __image_copy_end and
__bss_start in linker scripts (e.g. relocation information, or MMU
initialization tables used only before jumping to the relocated image).
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB
pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard.
eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this
board, which satisfies the 30-ns NF R/W cycle requirement.
The omap5-uevm is the reference board name for OMAP5 soc
based platform. So rename it accordingly.
Acked-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Sricharan R <r.sricharan@ti.com>
Tested-by: Nishanth Menon <nm@ti.com>
The omap2420-h4 board is using a RAM based address as the linker
location for code. This is causing several problems when attempting
to run the latest u-boot code base on this board from flash. Update
the default linker location for code to be in NOR flash. Please note
that OMAP maps the NOR flash to address 0x08000000 by default and so
use this as the default address for the NOR flash.
Also remove legacy code that attempts to calculate where in flash the
sdata structure, that holds the memory interface configuration data,
is located. By changing the default linker location for code to flash
this is no longer necessary.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
The size of the DRAM for the omap2420-h4 board is getting setup in the
dram_init() function. However, for the current u-boot release this is
too late and needs to be done in dram_init_banksize(). Therefore, add
a dram_init_banksize() function for the omap2420-h4 board and setup the
DRAM size there.
arch/arm/include/asm/arch-am33xx/omap_gpmc.h and
arch/arm/include/asm/arch-omap3/omap_gpmc.h are almost the same, consolidate
the common parts into a new header.
Introduce a new asm/omap_gpmc.h which defines the command part and pulls in
the architecture specific one.
Cc: Tom Rini <trini@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
This is done already for am335x in
59dcf970d11ebff5d9f4bbbde79fda584e9e7ad4 and also applies for pcm051.
It powers down the IO receiver when not performing read which helps
reducing the overall power consuption in low power states
(suspend/standby).
Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
board/freescale/mx6qsabrelite/README explain a procedure to
update the SPI-NOR on the SabreLite board without Freescale
manufacturing tool but following this procedure leads to both
"sf erase" and "sf write" failing on a mx6qsabrelite board:
MX6QSABRELITE U-Boot > sf probe 1
MX6QSABRELITE U-Boot > sf erase 0 0x40000
SPI flash erase failed
MX6QSABRELITE U-Boot > sf write 0x10800000 0 0x40000
SPI flash write failed
This is because the chip-select 1 is wrong and the correct
value is 0x7300.
Since commit c1173bd0 ("sf command: allow default bus and chip selects")
the chip-select and bus arguments for the sf probe command are optional
so let's just remove it and use "sf probe" instead.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
When booting a Freescale kernel 3.0.35 on a Wandboard solo, the get_board_rev()
returns 0x62xxx, which is not a value understood by the VPU
(Video Processing Unit) library in the kernel and causes the video playback to
fail.
The expected values for get_board_rev are:
0x63xxx: For mx6quad/dual
0x61xxx: For mx6dual-lite/solo
So adjust get_board_rev() accordingly and make it as weak function, so that we
do not need to define it in every mx6 board file.
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
Maximum bus width supported by some i.MX6 boards is not 8bit like
others. In case where both host controller and card support 8bit transfers,
they agree to communicate on 8bit interface while some boards support only 4bit interface.
Due to this reason the mmc 8bit default mode fails on these boards. To rectify this,
define maximum bus width supported by these boards (4bit). If max_bus_width is not
defined, it is 0 by default and 8bit width support will be enabled in host
capabilities otherwise host capabilities are modified accordingly.
It is tested with a MMCplus card.
Signed-off-by: Abbas Raza <Abbas_Raza@mentor.com>
cc: stefano Babic <sbabic@denx.de>
cc: Andy Fleming <afleming@gmail.com>
Acked-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
The u-boot.imx binary is generated by default, so no need to pass it in the
'make' line.
Adds support for 'bmode' command which let user to choose where to
boot from; this allows U-Boot to load system from another storage
without messing with jumpers.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
This changes the code so in case an unkown value is passed it will
return as invalid.
This documents the SD card identifier so it is easier for user to spot
which card number will be used, if need.
MPLL is selected as the source clk of pwm by default
Test with command "sf probe 1:0; time sf read 40008000 0 1000".
Try with different numbers of bytes and see that sane values are obtained
Build and boot U-boot with this patch, backlight works properly.
Signed-off-by: Padmavathi Venna <padma.v@samsung.com>
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
We intended to clear the bits of CLK_SRC_TOP2 register, instead we were
writing on the reserved bits of src_core1 register. Since the default
value of clk_src_top2 register were itself zero, this typo was not
creating any big issue. But it is better to fix this error for better
readability of the code.
Signed-off-by: Hatim Ali <hatim.rv@samsung.com>
The condition for testing of PLL getting locked was incorrect. Rectify
this error in this patch.
Reported-by: Alexei Fedorov <alexie.fedorov@arm.com>
Compiling for non-dt systems gives folowing warning:
smdk5250.c: In function 'board_eth_init':
smdk5250.c:152:6: warning: unused variable 'node' [-Wunused-variable]
Declare variable 'node' only for dt enabled systems to remove this
warning.
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
drivers/spi/tegra20_sflash.c
include/fdtdec.h
lib/fdtdec.c
Since we have DT support in exynos_fb and exynos_dp drivers now,
we need not define any static structure or platform data related to
display in the board file smdk5250.c.
So, we place the already existing structures inside #ifndef CONFIG_OF_CONTROL block.
Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com>
Add DT bindings for DP supporting an eDP panel of size 2560x1600.
Add DT bindings for FIMD supporting an eDP panel of size 2560x1600.
Replaced the functionality of callbacks by using a standard set of functions.
Instead of implementing and hooking up a callback, put the same code in one of
the standard set of functions by overriding it.
This patch is tested only on SMDK5250.
For Trats and universal_c210 board, it is only compile tested.
T114 requires SD bus power-rail bringup for the SDIO card on SDMMC3.
Signed-off-by: Tom Warren <twarren@nvidia.com>
SDIO1 (the SD-card slot on Dalmore) needs to have its pads setup
before the MMC driver is added.
Took these values directly from the kernel dts files.
Dalmore has a SPI flash part attached to controller 4, so enable
controller 4 and set to 25MHz.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Add a common interface to fdt based SPI drivers. Each driver is
represented by a table entry in fdt_spi_drivers[]. If there are
multiple SPI drivers in the table, the first driver to return success
from spi_init() will be registered as the SPI driver.
Rename tegra SPI drivers to tegra20_flash and tegra20_slink in
preparation for commonization and addition of tegra114_spi.
This feature was only used for tegra20 seaboard that had a pinmux
conflict on the SPI pins. These boards were never manufactured, so
remove this support to clean up SPI driver.
Tested-by: Rao Bodapati <rao@circuitco.com>
Add TI814X EVM board directory, config file, and MAINTAINERS
entry. Enable build.
Signed-off-by: Matt Porter <mporter@ti.com>
[trini: Adapt to recent omap_hsmmc requirements, Matt re-tested]
The AM33xx emif4/ddr support closely matches what is need to support
TI814x except that TI814x has two EMIF instances. Refactor all the
emif4 helper calls and the config_ddr() init function to use an
additional instance number argument.
Eliminate AM33xx specific names to prepare for TI814x support
within AM33xx-land.
Enable DDR PHY dynamic power down bit, which enables
powering down the IO receiver when not performing read.
This also helps in reducing overall power consumption in
low power states (suspend/standby).
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com>
Add support for loading splash image from NAND
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Enable the SD controller driver for the Raspberry Pi. Enable a number
of useful MMC, partition, and filesystem-related commands. Set up the
environment to provide standard locations for loading a kernel, DTB,
etc. Provide a boot command that loads and executes boot.scr.uimg from
the SD card; this is written considering future extensibilty to USB
storage.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
The firmware running on the bcm2835 SoC's VideoCore CPU determines how
much of the system RAM is available for use by the ARM CPU. Previously,
U-Boot assumed that only 128MB was available, since this was the
smallest value configured by any public firmware. However, we can now
query the actual value at run-time from the firmware using the mbox
property protocol.
Wandboard is a development board that has two variants: one version based
on mx6 dual lite and another one based on mx6 solo.
For more details about Wandboard, please refer to: http://www.wandboard.org/
Add a memory-mapped 8GB SPI chip.
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
