path: root/board
2012-10-05MPC85xx: remove support for TQM85xx boardsWolfgang Denk
Due to grown code sizes the TQM85xx boards don't build any more with some older tool chains (like ELDK 4.2). As these boards have long reached EOL it seems a waste of effort trying to fix them. The vendor has agreed to drop support for them, too. So let's get rid of them. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> cc: Kim Phillips <kim.phillips@freescale.com> Acked-by: Stefan Roese <sr@denx.de>
2012-10-05sh: ap_sh4a_4a: Fixed initialization value of DDR memoryNobuhiro Iwamatsu
The wrong value was set as value of column of DDR memory for ap_sh4a_4a. 10 is the right value. This fixed this problem. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-04Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-10-04ARM: Add Altera SOCFPGA Cyclone5Dinh Nguyen
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware. Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Chin Liang See <clsee@altera.com> Signed-off-by: Pavel Machek <pavel@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tom Trini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefan Roese <sr@denx.de> ---- v8: Remove no_return attribute for reset_cpu Based on v2012.10-rc2
2012-10-04snowball: Clear UART RX FIFORamesh Chandrasekaran
Without usb-serial cable plugged at this stage, some garbage is seen in UART RX FIFO, which blocks autoboot progress. The fix makes sure to empty the RX FIFO, before we wait for user input to interrupt autoboot. Signed-off-by: Ramesh Chandrasekaran <ramesh.chandrasekaran@stericsson.com>
2012-10-04xilinx: Add new Zynq boardMichal Simek
Add support for Xilinx Zynq board. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> CC: Joe Hershberger <joe.hershberger@gmail.com>
2012-10-04ARM: Add X600 board support (SPEAr600 based)Stefan Roese
This patch adds support for the X600 SPEAr600 based board. Its also the first SPEAr600 board that uses the newly introduced SPEAr600 SPL support. Xloader is not necessary any more. By using the new "u-boot.spr" make target, one image will generated containing both, U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and the main U-Boot with mkimage header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-10-03Merge remote-tracking branch 'u-boot-marvell/master'Albert ARIBAUD
2012-10-03lsxl: also turn off fan in power down modeMichael Walle
If while booting the power switch is in OFF position, turn off the fan, too. Signed-off-by: Michael Walle <michael@walle.cc> Cc: Prafulla Wadaskar <prafulla@marvell.com>
2012-10-03arm/km: add mv88e6352 configuration for kmnusaValentin Longchamp
The kmnusa board uses a mv88e6352 switch that is connected to the main eth interface of the kirkwood. Therefore the switch must be configured so that the kirkwood's egiga eth inferface can be used. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Holger Brunck <holger.brunck@keymile.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2012-10-03kirkwood: ib62x0: Invert SATA activity LEDsSimon Baatz
The hardware design of the IB-NAS62x0 causes the SATA activity LEDs to be on when idle by default. Reverse the polarity of the activity LEDs in early init. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Cc: Luka Perkov <uboot@lukaperkov.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Luka Perkov <uboot@lukaperkov.net>
2012-10-03arm/km: use kw_sdram_size_adjust to adjust SDRAM sizeHolger Brunck
Some boards may differ only in the SDRAM size. This function allows to fix the size accordingly and we can use the same u-boot binary for both boards. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2012-10-03kirkwood: add support for Iomega iConnect boardLuka Perkov
Add support for new board iConnect from Iomega. More information about the device can be found here: http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com> Tested-by: Tim Fletcher <tim@night-shade.org.uk>
2012-10-03ARM: add support for Network Space v2 Lite and MiniSimon Guinot
This patch adds support for the LaCie boards Network Space v2 (Lite and Mini). This two boards are derived from the Network Space v2 and a lot of hardware caracteristics are shared. - CPU: Marvell 88F6192 800Mhz - SDRAM memory: 128MB DDR2 200Mhz - 1 SATA port: internal - Gigabit ethernet: PHY Marvell 88E1318 - Flash memory: SPI NOR 512KB (Macronix MX25L4005A) - i2c EEPROM: 512 bytes (24C04 type) - 2 USB2 ports (Lite only): host and host/device - 1 push button - 1 SATA LED (bi-color, blue and red) Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
2012-10-03ARM : Add support for MINI2440 (s3c2440).Gabriel Huau
Support of the MINI2440 board from FriendlyARM from an old version of u-boot : http://repo.or.cz/r/u-boot-openmoko/mini2440.git Currently, supporting only boot from NOR. Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
2012-10-03rmobile: armadillo-800eva: Change init function of SCIFA1Nobuhiro Iwamatsu
This initializes GPIO, without using PFC framework in board_early_init_f function. It is because it cannot initialize normally when PFC is used. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: armadillo-800eva Remove board_eth_initNobuhiro Iwamatsu
2012-10-03arm: rmobile: Add support for ATMARK-TECHNO Armadillo-800EVA boardHideyuki Sano
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM, Ethernet, and more. This patch supports the following functions: - 512MB DDR3-SDRAM - Serial console (SCIF) - Ethernet MAC(MII) & PHY(SMSC) Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: enable reset commandTetsuyuki Kobayashi
Do soft power on reset in U-Boot reset command. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Modify bus controller setting for CS4Tetsuyuki Kobayashi
Problem: Linux kernel hangs up when it write a file to NFS mounted directory. Solution: Modify bus controller setting for CS4, which connected smsc9221 ethernet controller. Detail: Modify CS4BCR bit[29:28] (IWW[1:0]) from 00 to 01. Modify CS4BCR bit[20:19] (IWRRD[1:0]) from 00 to 01. Modify CS4BCR bit[17:16] (IWRRS[1:0]) from 00 to 01. Modify CS4WCR bit[27:26] (WSW[1:0]) from 10 to 11 Modify CS4WCR bit[25:24] (WHW[1:0]) from 01 to 10 Modify CS4WCR bit[18:16] (WW[2:0]) from 101 to 111 Modify CS4WCR bit[13:11] (SW[2:0]) from 010 to 011 Modify CS4WCR bit[10:7] (WR[3:0]) from 1000 to 1011 Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: kzm9g: Adjust low level hardware settingTetsuyuki Kobayashi
Adjust low level hardware setting in s_init. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-03arm: rmobile: Add supoprt for KMC KZM-A9-GT boardNobuhiro Iwamatsu
The KZM-A9-GT board has Renesas R-Mobile SH73A0, 512MB DDR2-SDRAM, USB, Ethernet, and more. This patch supports the following functions: - 512MB DDR2-SDRAM - 16MB NOR Flash memory - Serial console (SCIF) - Ethernet (SMSC) - I2C Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-10-02TQM8xx: adjust linker script to grown code sizeWolfgang Denk
Some of the previous changes caused the code to grow, which causes errors like u-boot.lds:76 cannot move location counter backwards (from 4000828c to 40008000) when building with some older tool chains (like ELDK 4.2). Adjust the linker script to make fit again. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-10-01OMAP: networking support for SPLIlya Yanok
This patch adds support for networking in SPL. Some devices are capable of loading SPL via network so it makes sense to load the main U-Boot binary via network too. This patch tries to use existing network code as much as possible. Unfortunately, it depends on environment which in turn depends on other code so SPL size is increased significantly. No effort was done to decouple network code and environment so far. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-01davinci: ea20: the console is always set to the serial lineBastian Ruppert
Do not allow to overwrite it when video is enabled. Signed-off-by: Bastian Ruppert <Bastian.Ruppert@Sewerin.de> CC: Tom Rini <trini@ti.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-10-01davinci: ea20: reorganisation LCD startupBastian Ruppert
2012-10-01AP1000: Inline local 'get_device'Tom Rini
The AP1000 defines a 'get_device' function to determine what board revision we are on. Inline that checking as it conflicts with the get_device() in <part.h> and is only used once. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-30Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
2012-09-29Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-09-29Merge remote-tracking branch 'u-boot-atmel/master'Albert ARIBAUD
2012-09-27da850: Add README.da850Tom Rini
This file documents when to build for da850evm and when to build for da850_am18xxevm. It also documents how to write the u-boot.ais file to persistent storage (such as SPI), in some cases as well as how to write a recovery image. Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Prabhakar Lad <prabhakar.lad@ti.com>
2012-09-27omap-common: SPL: Add CONFIG_SPL_DISPLAY_PRINT / spl_display_print()Tom Rini
Only omap4/5 currently have a meaningful set of display text and overo had been adding a function to display nothing. Change how this works to be opt-in and only turned on for omap4/5 now. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-25Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2012-09-25Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2012-09-24mx28evk: Remove fecmxc_mii_postcall()Fabio Estevam
fecmxc_mii_postcall() is specific to the KSZ9021 PHY on m28evk and should not be used on mx28evk, which has LAN8270 instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-09-23KARO TX25: Fix NAND Flash R/W cycle timesBenoît Thébaudeau
The NAND Flash of the KARO TX25 board is a Samsung K9F1G08U0B with 25-ns R/W cycle times. However, the NFC clock for this board was set to 66.5 MHz, so using the NFC driver in symmetric mode (i.e. 1 NFC clock cycle = 1 NF R/W cycle) resulted in NF R/W cycle times of 15 ns, hence corrupted NF accesses. This patch fixes this issue by setting the NFC clock to the highest frequency complying to the 25-ns NF R/W cycle times specification, i.e. 33.25 MHz. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: John Rigby <jcrigby@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Gachet <Daniel.Gachet@hefr.ch> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-23mx51evk: Add CONFIG_REVISION_TAGBenoît Thébaudeau
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG information. If this data is not present, the kernel misconfigures the TZIC, which results in the timer interrupt handler never being called, so the kernel deadlocks while calibrating its delay. Suggested-by: Greg Topmiller <Greg.Topmiller@jdsu.com> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-09-21Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-09-21Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-09-20ColdFire: Clean up checkpatch warnings for MCF54451 and MCF54455Alison Wang
Signed-off-by: Alison Wang <b18965@freescale.com>
2012-09-20ColdFire: Clean up checkpatch warnings for MCF547x and MCF548xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF523xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF532x/MCF537x/MCF5301xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF52x2Alison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF5227xAlison Wang
2012-09-18Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxTom Rini
2012-09-18mpc8308rdb: add support for eSDHC MMC controllerIra W. Snyder
Add support for the onboard eSDHC MMC controller. The hardware on the MPC8308RDB has the following errata: - ESDHC111: manual asynchronous CMD12 is broken - DMA is broken (PIO works) Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> [added include fsl_esdhc header to prevent implicit declarations of fsl_esdhc_mmc_init() and fdt_fixup_esdhc()] Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-09-18mpc8308rdb: add support for Spansion SPI flash on header J8Ira W. Snyder
The SPI pins are routed to header J8 for testing SPI functionality. A Spansion flash has been wired up and tested on this header. This patch breaks support for the second TSEC interface, since the GPIO pin used as a chip select is pinmuxed with some of the TSEC pins. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-09-18ARM: Remove apollon boardMarek Vasut
This board is the only board that still sticks to OneNAND IPL. Remove this board, since we have SPL around for a while and OneNAND is well supported in the SPL framework. The board can be revived if necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Tom Rini <trini@ti.com>
2012-09-18IPL: Remove remains of OneNAND IPLMarek Vasut
After removing the Apollon board, remove the OneNAND IPL too. There are no users for it any more. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Minkyu Kang <promsoft@gmail.com> Cc: Tom Rini <trini@ti.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
