* Add MPC8220 boards to MAKEALL script
* Add EEPROM and RTC support for HMI1001 board
* Patch by Detlev Zundel, 20 Jun 2005:
Fix initialization of low active GPIO pins on inka4x0 board
* Disable "date" and "sntp" commands on TQM866M which has no RTC
Add support for Funkwerk VoVPN gateway module.
add support for the OpenGear CM4008 board
Code cleanup (especially Sorcery / Alaska / Yukon serial driver).
* Add support for MPC8247 based "IDS8247" board.
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and
CONFIG_JFFS2_LZARI are added. Both are undefined by default.
sections on PPChameleon board; other boards might use this, too.
Update for P3G4
Fix problems in cmd_universe.c
PM520 boards.
Fix PHY address for canmb board.
Cleanup.
Make PCI target address spaces on PMC405 and CPCI405 boards
configurable via environment variables
Updates for OCOTEA board:
- Changed U-Boot size from 512kByte to 256kByte
- Fixed flash driver to support boot from soldered user flash
- Added README for switch from PIBS firmware to U-Boot
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200
- moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
- update the pxa-regs.h file for PXA27x chips
- add PXA27x based ADSVIX board
- add support for MMC on PXA27x processors
* Patch by Andrew E. Mileski, 28 Nov 2004:
Fix PPC4xx SPD SDRAM detection bug
* Patch by Hiroshi Ito, 26 Nov 2004:
Fix logic of "test -z" and "test -n" commands
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards
- introduce two new configuration options instead:
CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
add udelay support for the mcf5282 cpu
* Patch by Tolunay Orkun, 16 November 2004:
fix incorrect onboard Xilinx CPLD base address
- Add low-boot option for MPC8260ADS board (if lowboot is selected,
the jumper for the HRCW source should select flash. If lowboot is
not selected, the jumper for the HRCW source should select the
BCSR.
- change default load base address to 0x00400000
Add support for Analogue & Micro Rattler boards.
Tested on Rattler8248.
* Patch by Andre Renaud, 08 Nov 2004:
Fix watchdog support in common/lcd.c
* Patch by Marc Leeman, 05 Nov 2003:
Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU
bug only affects the XPC8245 processors
- Add support for MicroSys CPU87 board
- Add support for MicroSys PM854 board
- Add support for HIDDEN_DRAGON board
- fix endianess problem in driver/rtl1839.c
* Patch by Allen Curtis, 21 Oct 2004:
support multiple serial ports
- create SoC specific directories include/asm-arm/arch-imx and
include/asm-arm/arch-s3c24x0
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL
- rename memsetup into lowlevel_init (function name and source files)
enable SNTP support in some boards.
Add automatic HW detection for CMC_PU2 and CMC_BASIC
Remove duplicated code by merging memsetup.S files for
at91rm9200 boards into one cpu/at91rm9200/lowlevel.S
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
- Change the name of the Ethernet driver: MOTO ENET -> ENET
- Reformat boot messages
- Enable redundant environment
- Replace the -O2 optimization flag with -mno-string
Restore copyright statements in OHCI drivers.
* Add support for TQM8540 board
NC650: changed NAND flash addressing to using UPMB
"brightness" environment variable.
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c).
* Enable USB and IDE support for INKA4x0 board
* Patch by Andrew Dyer, 28 February 2005:
fix ext2load passing an incorrect pointer to get_partition_info()
resulting in load failure for devices other than 0
* Add reset code for Coral-P on INKA4x0 board
* Patch by Martin Krause, 28 Jun 2004:
Update for TRAB board.
* Fix some missing "volatile"s in MPC5xxx FEC driver
* Add USB and PCI support for INKA4x0 board
Add standalone application to change SMC91C111 MAC addresses,
see examples/README.smc91111_eeprom
* Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004:
Fix Flash support for ARM Integrator CP.
* Patch by Richard Woodruff, 10 Jan 2005:
Update support for OMAP2420 (ARM11) and H4 board:
o clean up and add new types to H4 memory probe code.
o fix to work with internal boot.
o added PRCM config III operation.
o fix marginal flash timings.
o add revison ATAG usage.
o enable voltage scaling at power chip.
o fix compile error for i2c.
* Fix network problem (error when receiving multiple ARP packets)
