The older i.MX8M Mini Verdin SoMs may came with 20 MHz SPI CAN controller
oscillator, the newer SoMs always use 40 MHz oscillator. Handle both by
overriding the oscillator frequency just before booting the kernel.
These are the known variants with 20 MHz oscillator:
- 0055, V1.1A, V1.1B, V1.1C and V1.1D, use a 20MHz oscillator
- 0059, V1.1A and V1.1B, use a 20MHz oscillator
Upstream-Status: Backport [dcb1b7b6449e82a79b06e31af052628c3d58dc70]
Reviewed-by: Francesco Dolcini <francesco.dolcini@toradex.com>
Add new PID4 0090 Verdin iMX8M Mini Quad 4GB WB ET to support
the new hardware variant.
Upstream-Status: Submitted [https://lore.kernel.org/all/20240528095941.872693-1-ghidoliemanuele@gmail.com/]
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
Add new PID4 0089 Verdin iMX95 Hexa 16GB WB IT to config block handling.
Add new PID4 0088 Aquila AM69 Octa 32GB WB IT to config block handling.
Add support for SKUs with higher memory sizes.
Actual memory size is auto-detected.
Add support for MT53E512M32D1ZW-046 IT:C memory.
This 4 GB memory has 17 row bits instead of 16 and requires 380 ns of
tRFC (tRFCab) instead of 280 ns due to increased channel density to 16 Gb.
Both modifications are retro-compatible with previous memories.
Add new product id 0087 Verdin iMX8M Mini Quad 2GB IT.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20240308141801.49081-1-jpaulo.silvagoncalves@gmail.com/]
Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
This pulls in the following commits:
git log --oneline --no-merges ^HEAD lf-5.15.71-2.2.2
14b6c8f3e3b MA-20886 imx8ulp: Boot from recovery mode when pressing key
62ad7799b6c LF-7602: Device tree fixup based on compatible string
b35420da607 crypto: fsl_hash: Remove unnecessary alignment check in caam_hash()
918dbf78bbb MA-20872 Revert "MA-18775 system will hang about 3s when boot up kernel"
ed2c3cbd6ac MA-20814 add fastboot command to erase u-boot env
a6762e28bf0 LF-6627: nand drvier fixups in sdboot on ls1043ardb-pd
d23cfa09767 LFU-426: qspihdr: Coverity Issue: unchecked return value
413b08f841f MLK-25850: imx8dxl_ddr3l_evk: change the default fdt file name
e91a047f54f LF-7382: fastboot: improve emmc write speed
205680f9f4b LFU-428 imx8ulp: Add warning for CAAM non-secure state failure
f405551dcc1 LF-7369-2 clk: imx93: update LPCG control API
676831be672 LF-7369-1 clk: imx: implement a clock gate driver for i.MX93
94c5bb2eb83 MA-20507-7 trusty: fix dereference null return value
6933487b4df LFU-427 imx93: Print ELE FW version
15b1ebb00cc LFU-393 imx93: Add reset cause print
f3b75e3317d LF-7332 imx8/ahab: sha256: enable image verification using ARMv8 crypto extention
330e2634143 LFU-423: usb: cdns3: gadget: Avoid using usb_ss after null check
58ba744cbad MLK-26034 imx6: Disable LCDIF clock before jumping to kernel
ae396d343a3 LF-6627: nand drvier fixups in nandboot on ls1043ardb-pd
0a99627b60e LFU-422-2 imx8ulp_evk: Enable the GD25LX256E support
c6c06de038f LFU-422-1 mtd: spi-nor: Add GigaDevice GD25LX256E NOR flash
032fab5e127 LFU-421 imx93_evk: Add imx93 low drive mode support on 11x11 EVK
d9f477625d3 LF-7332 armv8: SHA-256 using ARMv8 Crypto Extensions
53689e4f7db MA-20667 set metadata partition of type f2fs
f824cd01955 LFU-415 net: fec_mxc: Skip recv packet process when fec is halted
4e7c44e1f33 LFU-419 arm: dts: imx8mp: fix flexspi nand reg
957bdd9c925 LFU-418 imx8ulp: upower_hal: make code cleaner
361b23b98ed Revert "MLK-25478-1 efi: add Platform-Reset-Attack variables"
e1ed0611b5e Revert "MLK-25478-2 efi: clean memory and reset MemoryOverwriteRequestControl"
4998fef38a5 Revert "MLK-25478-3 workaround: disable verify time of signer and signee."
320096439b6 MA-20738 imx8ulp: bumps CONFIG_LMB_MAX_REGIONS
c244bdfd76c LFU-417-2 imx93_evk/qsb: Enable DDR inline ECC feature
026521c7d65 LFU-417-1 ddr: imx: imx9: Add DDR inline ECC support
a555a21be69 LFU-413 imx8ulp_evk: Remove CONFIG_BOOTDELAY=0 from ND defconfig
aaead5a2b8d LFU-416 imx: cmd_dek: Fix build warning in blob_encap_dek
933a3b25fe3 LF-7234 enable CONFIG_CMD_CRC32 and CONFIG_CRC32_VERIFY
97fc905e7f7 LFU-409: imx8dxl: fix the i.MX8DXL ddr3l NAND DQS iomux setting
aa4ebb66199 LFU-414 imx8ulp: clock: Update clocks to meet max rate restrictions
63d0579f397 LFU-410 imx: ele_ahab: Add ahab_sec_fuse_prog command
266dddae454 LFU-412 configs: imx93_evk: shrink mem= for jailhouse
5703d3ae37e LFU-411 imx8ulp: Always enable MIPI_DSI power switch
32965eb52f7 LFU-392 imx8ulp: upower: replace magic number with macro
beb5e5e3303 MA-20677 imx8ulp: android: enable CONFIG_AHAB_BOOT by default
bb45dd592db LFU-408 imx93evk: config the pmic standby voltage for buck1
25e38cb4762 LFU-407-02 ddr: imx9: Change the saved ddr data base to 0x2051c000
a8fef10ab92 LFU-407-01 configs: imx93: Update spl stack & bss base address
8731024fe7e LFU-406 mx6ul/mx6ulz: Fix build break caused by RNG patch
a95afe08769 LF-7238 imx9: soc: Remove OPTEE memory from DRAM bank and MMU
19c3fdebf8d LFU-403-4 imx93_evk/qsb: Enable TMU sensor driver
e1703ec06a4 LFU-403-3 iMX93: soc: print current CPU temperature
050a94e6365 LFU-403-2 DTS: imx93: Update TMU node to sync with kernel
91e711a565c LFU-403-1 thermal: imx_tmu: Update TMU driver to support iMX93
78749666dd3 LFU-402-3 imx93_evk/qsb: Use API to set max ARM clock
401b9824f92 LFU-402-2 iMX93: clock: Add API to set max ARM core clock
e4722baa5af LFU-402-1 iMX93: soc: Get market segment and speed grading
432a4af9608 LFU-400 imx8ulp: clock: Clear dividers in PLL3DIV_PFD registers
53f06207782 LFU-399 imx8ulp: Reconfigure MRC3 for SRAM0 access
48a2221acc9 LFU-395 imx93: Add fused parts support
d8760a74793 LFU-398-7 imx93_9x9_qsb: Enable Flexspi NOR support
1f500a59670 LFU-398-6 imx93_qsb: Enable M.2 VPCIe_3V3 and deassert SD3_nRST
ba4f72198f5 LFU-398-5 DTS: imx93-9x9-qsb: Add flexspi NOR nodes and pinctrl
d9f563336f7 LFU-398-4 imx93_11x11_evk: Enable Flexspi NOR support
c56f2132d53 LFU-398-3 imx93_evk: Enable M.2 VPCIe_3V3 and deassert SD3_nRST
b6cbe6b1416 LFU-398-2 DTS: imx93-11x11-evk: Enable and update flexspi NOR
c45c4fb791b LFU-398-1 DTS: imx93: Update flexspi node in DTSi
fab973fe1df LFU-397 imx8m: clock: not configure reserved SRC register
4881ba99fa4 LFU-396-7 imx93_9x9_qsp_defconfig: support splash screen
60e0e629f99 LFU-396-6 arm: dts: add imx93 9x9 ontat panel dts
fffc330cf1a LFU-396-5 imx9: clock: add 300MHz fracn pll table
ef6a3d9cc38 LFU-396-4 video: nxp: imx: add Add i.MX93 parallel display format encoder driver
5f414738a5f LFU-396-3 video: nxp: imx_lcdifv3: support VSYNC/HSYNC active low
21eb66fe1f8 LFU-396-2 video: nxp: imx: dsi: force DISPLAY_FLAGS_HSYNC_HIGH & DISPLAY_FLAGS_VSYNC_HIGH
88132ed0b4e LFU-396-1 video: simple_panel: make backlight optional
65287dc074d LF-7055: video: imx: Add set_parent calls to LVDS initialization
167f65006fb MLK-26021 imx93: add 9x9 qsb lpddr4 board
0a6297a290e MA-20677 imx8ulp: android: enable CONFIG_AHAB_BOOT by default
8789f3ca3e4 PLATSEC-1781-2 MX6: Device tree fix-up
60555c4a445 PLATSEC-1781-1 mx6ull:Add config CONFIG_OF_SYSTEM_SETUP
48b1d6e34fd MA-20149 set fs type of android partitions
9710cc4840e LFOPTEE-177 imx93evk: enable cmd_dek command
f0721d67f03 LFOPTEE-177 imx8ulp: enable cmd_dek command
bf07f5166bf LFOPTEE-177 imx: cmd_dek: add ELE DEK Blob generation support
6de56c3f629 LFOPTEE-177 s400_api: add DEK Blob generation
drivers/crypto/fsl/fsl_hash.c
commit 41b2182af73 ("crypto: fsl_hash: Remove unnecessary
alignment check in caam_hash()")
Both NXP and TXD branch did cherry-picking that commit, but NXP
additionally removed a debug print (not present in master)
while the TDX branch did not. Resolved by doing it the NXP way.
Add new product id 0086 Verdin iMX8M Mini DualLite 2GB IT.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20240131173204.100407-1-jpaulo.silvagoncalves@gmail.com/]
ERR050805
Update lpddr4 configuration and training using updated spreadsheet and
tools from NXP using data from previous spreadsheet and verified
toward datasheet:
- MX8M_Mini_LPDDR4_RPA_v22.xlsx
- mscale_ddr_tool_v3.31_setup.exe
The most relevant update is related to errata ERR050805:
"DRAM: Controller automatic derating logic may not work when
the LPDDR4 memory temperature is above 85 °C at initialization"
Other relevant fixes:
- DRAMTMG7 register: corrected calculation of T_CKPDX parameter
(equal to tCKCKEH for LPDDR4)
- RANKCTL register: corrected calculations for ODTLon and ODTLoff
to follow the JEDEC specification
- ADDRMAP7 register: added support for 17-row devices
As per errata ERR050805:
An issue exists with the automatic derating logic of the DDR
controller that only samples the LPDDR4 MR4 register when the
Temperature Update Flag (TUF) field (MR4[7] ) is 1’b1. If the
LPDDR4 memory is initialized and starts operation above 85 °C
(MR4[2:0] > 3’b011), the MR4 Temperature Update Flag (TUF) will
not be set. The DDR Controller will therefore not automatically
adjust the memory refresh rate or de-rate memory timings based
on the LPDDR4 memory temperature. This may cause the controller
incorrectly setting the refresh period, potentially cause the
LPDDR4 memory losing data contents and lead to possible data
integrity issues above 85 °C.
Errata provides three possible workaround options, while option 2
is the most reasonable:
Disable the automatic derating logic of the DDR controller and
apply fixed x2 refresh rate (0.5x refresh). This option is
suitable for designs that are expected to boot at or above 85 °C
and memory’s MR4[2:0] (Refresh Rate) DOES NOT report the following
conditions:
3b101: 0.25x refresh, no de-rating
3b110: 0.25x refresh, with de-rating
3b111: SDRAM High temperature operating limit exceeded
[1]: https://www.nxp.com/docs/en/errata/IMX8MM_0N87W.pdf
Upstream-Status: Pending
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
The current implementation of spl_board_init() USB boot handling is
not correct, the MX8MM BootROM v1 does not support SDP load when
re-entered from U-Boot SPL, it is up to U-Boot to perform the next
stage load using its own internal CI gadget driver and SDP protocol
implementation. Drop the spl_board_init() to let SPL continue with
normal load in case the SDP support is enabled.
Upstream-Status: Backport[f687c1ef4fdf14faea16c13b1eaac5496dee39df]
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Rework the rather big array of zero length strings with 4 entries of
actual display adapter names to a array of structs which ties a pid4
to its correspondent human readable string.
Provide an accessor to get the string for a given PID4.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230718090734.20357-4-andrejs.cainikovs@toradex.com/]
actual carrier board names to a array of structs which ties a pid4
Rework the user of the information to use the accessor.
Note that check_pid8_sanity() is used for early samples of Dahlia and
the development board. Yavia isn't affected.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230718090734.20357-3-andrejs.cainikovs@toradex.com/]
Add the Yavia Carrier board name string to the known carrier
board list.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230718090734.20357-2-andrejs.cainikovs@toradex.com/]
Add new i.MX 8M Plus Quad SKU to ConfigBlock handling.
0070: Verdin iMX8M Plus Quad 8GB WB IT
This SKU is identical to 0066 but supporting Industrial Temperature range.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230515130641.26028-1-francesco@dolcini.it/]
Initialize Secure Non-Volatile Storage, aka SNVS.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230403111426.61327-3-andrejs.cainikovs@toradex.com/]
Print firmware versions during U-Boot start:
BuildInfo:
- SCFW f5623878, SECO-FW c9de51c0, IMX-MKIMAGE 0, ATF c6a19b1
- U-Boot 2022.04-00335-g65192567f81-dirty
Upstream-Status: Submitted [https://lore.kernel.org/all/20230403111426.61327-2-andrejs.cainikovs@toradex.com/]
Add USB support.
As of now, no iMX8 USB support present in mainline.
The following expression is used to construct the device tree name:
fdtfile=${soc}-colibri-${fdt_board}.dtb
- soc is set dynamically (either imx8qxp or imx8dx)
- fdt_board can be modified by the user (eval-v3, aster, iris/iris-v2)
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-9-andrejs.cainikovs@toradex.com/]
Refactor the detection of QXP vs. DX SoC into its own helper function.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-8-andrejs.cainikovs@toradex.com/]
All Colibri iMX8X variants have 2nd RGMII on SoC, so add the address
for 2nd ethernet.
Upstream-Status: Submitted [https://lore.kernel.org/all/20230303132642.15574-2-andrejs.cainikovs@toradex.com/]
change prints to show which DDR configuration (single/dual rank) is used
Waiting for internal test and validation before sending to upstream.
Deduplicate similar DDRC configurations and LPDDR4 training patterns
by patching a single configuration.
The aim is to reduce the SPL memory footprint and simplify maintenance
of lpddr4_timing.c
toward datasheet:
- MX8M_Plus_LPDDR4_RPA_v9.xlsx
- mscale_ddr_tool_v3.30.exe
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX-8M-Family-DDR-Tool-Release/ta-p/1104467
Some register values differ due to these fixes/modifications:
- corrected calculation of T_CKPDX parameter (equal to tCKCKEH for LPDDR4)
- corrected ECC related items, none of which affect normal operation
when ECC is not enabled
- corrected formula for calculation of tRTP in cell D122
Change tRFCmin (tRFCab) from 280 ns to 380 ns to be compliant with
current and futures memories.
Fixes: 2bc2f817cea7 ("board: toradex: add verdin imx8m plus support")
Add support to Verdin IMX8MP V1.1B SKU which uses
MT53E1G32D2FW-046 WT:B memory.
Compared to the 8 GB memory (MT53E2G32D4NQ-046 WT:A) used on
Verdin IMX8MP V1.0A it has 16 row addresses instead of 17.
In fact, the new memory, is a 2 GB/rank memory. The 8 GB memory is a
4 GB/rank memory.
Manually tweaking Host Interface addresses vs LPDDR4 signals mapping
it is possible to have a single configuration working with both memories:
- Old configuration: HIF bit 30 -> rank, HIF bit 29 -> Row 16
- New configuration: HIF bit 29 -> rank, HIF bit 30 -> Row 16
With this change the memory space from the host processor is contiguous
for both the configurations and the correct memory size is computed
using get_ram_size() at runtime.
Support for single rank memories still works thanks to the fact
dual ranks training fails (ddr_init->ddr_cfg_phy) toward single rank
memories.
Related-to: ELB-5021
All Apalis iMX8 variants have 2nd RGMII on SoC, so add the address
for 2nd ethernet.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20230117142911.34257-1-francesco@dolcini.it/]
Add new SoM variant to existing ones.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20230113171751.331268-3-francesco@dolcini.it/]
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20230113171751.331268-20-francesco@dolcini.it/]
Add downstream specific iMX reset implementation.
Upstream-Status: Inappropriate [other]
This code uses sc_pm_reboot() which is not mainlined yet.
Remove a duplicate of weak board_phy_config() implementation
in drivers/net/phy/phy.c.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20230113171751.331268-19-francesco@dolcini.it/]
sc_pm_setup_uart() returns int, not sc_err_t.
Upstream-Status: Submitted [https://lore.kernel.org/u-boot/20230113171751.331268-18-francesco@dolcini.it/]
(cherry picked from commit ecc0917dd4f7efd064a1b58f4f75b85478a794b3)
Update SPDX license identifier string.
While at it also update copyright period.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-11-marcel@ziswiler.com/]
Display build info with information about the version of SCFW, SECO and
TF-A (ATF).
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-5-marcel@ziswiler.com/]
U-Boot typically tears down the display controller before handing
control over to Linux. On LCD displays disabling pixel clock leads to a
fading out effect with vertical/horizontal lines. Make sure to disable
back light GPIO Apalis BKL1 before booting Linux.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-4-marcel@ziswiler.com/]
Implement PCB version and SoC variant handling which automatically loads
the correct device tree for the Linux kernel.
Upstream-Status: Submitted [https://lore.kernel.org/all/20221212000930.45505-3-marcel@ziswiler.com/]
Add the new Apalis iMX8 product variant
0067: Apalis iMX8 QuadMax 8GB Wi-Fi / BT IT
the only difference to the product
0037 Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT
is the 8gb of RAM. Toradex strategy to choose the correct RAM timing in
SCFW is by fuses in the user area telling which RAM timing to load.
This commit makes use of this information to set the correct size of
the RAM and therefore distinguish between the new 0067 and 0037 product
Upstream-Status: Backport [0da8dde6343fb91628794f9772b119bc7241c8a1]
* origin/imx_v2022.04:
Make system enter recovery mode when user pressing "sw2" when
i.MX 8ULP EVK and i.MX 8ULP EVK 9×9 board are powered on.
Signed-off-by: Maximus Sun <maximus.sun@nxp.com>
Change-Id: Ifc13c37fff4f6c7352161b6ad7d6014aeeafcc6d
update-to-5.15.52_2.1.0__toradex_imx_lf_v2022.04
* origin/ls_v2022.04:
Signed-off-by: WeiLu <w.lu@nxp.com>
change the fdt file name with rpmsg postfix as the default.
Signed-off-by: Han Xu <han.xu@nxp.com>
Reviewed-by: Ye Li <ye.li@nxp.com>
When booting from OEM closed part, due to OTPMK not programmed correctly,
CAAM is in non-secure state. Add a warning in SPL to indicate the problem
to users.
Signed-off-by: Ye Li <ye.li@nxp.com>
Disable LCDIF axi clock and pix clock CCGR before jumping to kernel
to avoid potential MUX glitch issue on CSCDR2 LCDIF_PRE_CLK_SEL mux.
