path: root/cmd/spi.c
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-27cmd: spi: Permit setting bus frequencyMarek Vasut
The 'sspi' command hard-coded 1 MHz bus frequency for all transmissions. Allow changing that at runtime by specifying '@freq' bus frequency in Hz. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-03-25Convert CONFIG_DEFAULT_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_DEFAULT_SPI_BUS CONFIG_DEFAULT_SPI_MODE Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2016-03-27cmd: spi: check return value of strdupPeng Fan
Check return value of strdup. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com>
2016-01-25Remove the cmd_ prefix from command filesSimon Glass
Now that they are in their own directory, we can remove this prefix. This makes it easier to find a file since the prefix does not get in the way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
