path: root/common/altera.c
2008-04-13Altera Stratix II supporteran liberty
Adds Support for Altera's Stratix II. Within your board specific init file you will have to call 1. fpga_init (/* relocated code offset. usually => */ gd->reloc_off); 2. fpga_add (fpga_altera, (Altera_desc*)&altera_desc); Altera_desc* contines (for example): { Altera_StratixII, /* part type */ passive_serial, /* interface type */ 1, /* bytes of data part can accept */ (void *)(&funcs), /* interface function table */ 0L, /* base interface address */ 0 /* implementation specific cookie */ } funcs is the interface. It is of type altera_board_specific_func. It looks like this: altera_board_specific_func func = { pre_fn, config_fn, status_fn, done_fn, clk_fn, data_fn, abort_fn, post_fn, }; you will have to implement these functions, which is usually bit banging some gpio. Signed-off-by: Eran Liberty <liberty@extricom.com>
2008-01-09Improve configuration of FPGA subsystemMatthias Fuchs
This patch removes the FPGA subsystem configuration through the CONFIG_FPGA bitmask configuration option. See README for the new options: CONFIG_FPGA, CONFIG_FPGA_<vendor>, CONFIG_FPGA_<family> Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2006-09-18Merge with /home/stefan/git/u-boot/denxStefan Roese
2006-08-15Add FPGA Altera Cyclone 2 supportStefan Roese
Patch by Heiko Schocher, 15 Aug 2006
2005-04-07* Patch by Steven Scholz, 07 Apr 2005:wdenk
Add i2c_reg_write() and i2c_reg_write() for at91rm9200 I2C * Patch by Steven Scholz, 07 Apr 2005: Fix compiler warning in altera.c * Patch by Ladislav Michl, 06 Apr 2005: Fix voiceblue configuration.
2003-10-09* Patch by Steven Scholz, 10 Oct 2003LABEL_2003_10_09_2320wdenk
- Add support for Altera FPGA ACEX1K * Patches by Thomas Lange, 09 Oct 2003: - Endian swap ATA identity for all big endian CPUs, not just PPC - MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize args to linux - add support for dbau1x00 board (MIPS32)
2002-08-21Initial revisionwdenk
