Use the new IF_ENABLED_INT() feature to avoid needing our own inline
function to handle this case. Tidy up the logic to ensure that the value
is only used when present. Update the 'expected' comment also.
This implementation is intended to be copied to other projects and
modified, to as to foster a standard means of communcating runtime
information between firmware projects.
The GPL-2 license is too restrictive for some projects, e.g. those
intended as reference implementations rather than designed for
collaborative open-source development.
Update the license to make this easier to share.
Add a few convenience functions to obtain useful information about the
bloblist.
At present we do support allocating the bloblist but the Kconfig is a bit
strange, since we still have to specify an address in that case. Partly
this is because it is a pain to have CONFIG options that disappears when
its dependency is enabled. It means that we must have #ifdefs in the code,
either in the C code or header file.
Make use of IF_ENABLED_INT() and its friend to solve that problem, so we
can separate out the location of bloblist into a choice. Put the address
and size into variables so we can log the result.
Add the options for SPL as well, so we can use CONFIG_IS_ENABLED().
Use the convenience functions to improve readability.
At present if someone adds a tag in the middle of the list it works well
enough within a U-Boot build. But if these tags are used in another
project, or with an older version of SPL, the numbers make become
inconsistent.
Use explicit tag numbers that never change, to resolve this problem.
Allocate areas for existing U-Boot tags and set up an area for use by
projects and vendors, as well as for private use. Keep tags above
0x10000 unallocated for now.
Update bloblist_tag_name() and the tests to work with this new setup.
The EC event log tag is no-longer used. The vboot handoff is now handled
by the vboot context instead.
Drop these unused tags.
Add a U_BOOT prefix to this tag since it is specific to the U-Boot
project.
Typically the bloblist is positioned at a fixed address in memory until
relocation. This is convenient when it is set up in SPL or before
relocation.
But for EFI we want to set it up only when U-Boot proper is running. Add
a way to allocate it using malloc() and update the documentation to cover
this aspect of bloblist.
Note there are no tests of this feature at present, nor any direct testing
of bloblist_init().
This can be added, e.g. by making this option controllable at runtime.
It is possible to add a blob that ends at the end of the bloblist, but at
present this is not supported. Fix it and add a regression test for this
case.
Sometimes a blob needs to expand, e.g. because it needs to hold more log
data. Add support for this. Note that the bloblist must have sufficient
spare space for this to work.
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
Add tag names for recently added types.
Fixes: d2cb7a22da0 (x86: Allow putting some tables in the bloblist)
Typically in TPL/SPL the bloblist is quite small. But U-Boot proper may
want to add a lot more to it, such as ACPI tables.
Add a way to expand the bloblist by relocating it in U-Boot proper, along
with the other relocation activities.
Some blobs need a larger alignment than the default. For example, ACPI
tables often start at a 4KB boundary. Add support for this.
Update the size of the test blob to allow these larger records.
The intention which bloblists is that each blob's data is aligned in
memory. At present it is only the headers that are aligned.
Update the code to correct this and add a little more documentation.
It is helpful to be able to see basic statistics about the bloblist and
also to list its contents. Add a 'bloblist' command to handle this.
Put the display functions in the bloblist modules rather than in the
command code itself. That allows showing a list from SPL, where commands
are not available.
Also make bloblist_first/next_blob() static as they are not used outside
this file.
It is convenient for bloblist to zero out the contents of a records when
it is added. This saves the callers having to do it.
Update the API accordingly.
Add a messing error code to bloblist_new() and tidy up the line length in
bloblist_addrec().
A common check is to see if a blob is present, create it if not and make
sure that the size is large enough. Add a function to handle this.
Drop inclusion of crc.h in common.h and use the correct header directly
instead.
With this we can drop the conflicting definition in fw_env.h and rely on
the crc.h header, which is already included.
At present there is no standard way in U-Boot to pass information from SPL
to U-Boot proper. But sometimes SPL wants to convey information to U-Boot
that U-Boot cannot easily figure out. For example, if SPL sets up SDRAM
then it might want to pass the size of SDRAM, or the location of each
bank, to U-Boot proper.
Add a new 'bloblist' feature which provides this. A bloblist is set up in
the first phase of U-Boot that runs (i.e. TPL or SPL). The location of
this info may be in SRAM or CAR (x86 cache-as-RAM) or somewhere else.
Information placed in this region is preserved (with a checksum) through
TPL and SPL and ends up in U-Boot. At this point it is copied into SDRAM
so it can be used after relocation.
Acked-by: Andreas Dannenberg <dannenberg@ti.com>
