path: root/common/env_ext4.c
2016-06-24common: Fix support for environment file in EXT4Andrej Rosano
Signed-off-by: Andrej Rosano <andrej@inversepath.com>
2016-03-14common: Add support for environment file in EXT4.Stuart Longland
This is an enhancement that permits storing the environment file on an EXT4 partition such as the root filesystem. It is based on the existing FAT environment file code.
