path: root/common/memsize.c
2016-02-10Revert "common/memsize.c: Simplify RAM size detection"Hans de Goede
This commit breaks bootup on sunxi boards, the get stuck when running the main u-boot binary at: CPU: Allwinner H3 (SUN8I) I2C: ready DRAM: This reverts commit 8e7cba048baae68ee0916a8f52b4304277328d5e. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-02-08common/memsize.c: Simplify RAM size detectionEddy Petrișor
The case of memory of size 0 is not that different from a memory of any other size, so we remove the duplicate code and treat the small differences when it is the case. Signed-off-by: Eddy Petrișor <eddy.petrisor@gmail.com>
2015-01-14common/memsize.c: Coding style cleanupWolfgang Denk
Prepare code to make later modifications checkpatch-clean. Signed-off-by: Wolfgang Denk <wd@denx.de>
2014-02-21common: Add get_effective_memsize() to memsize.cYork Sun
This function has been around for powerpc. It is used for systems with memory more than CONFIG_MAX_MEM_MAPPED. In case of non-contiguous memory, this feature can limit U-boot to one block without going over the limit. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-09-21Revert "memsize: Fix for bug in memory sizing code"Tom Rini
After further investigation this change is not correct and results in get_ram_size returning incorrectly large values. Reported first by Gerlando Falauto. This reverts commit b8496cced856ff411f1eb2e4eff20f5abe7080b0. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-18memsize: Fix for bug in memory sizing codeIwo Mergler
The original memory sizing code in get_ram_size clobbers the word at the base address, but forgets to restore it. Signed-off-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com>
2011-07-17Remove volatile qualifier in get_ram_size() callsAlbert ARIBAUD
Checkpatch.pl complains about the volatile qualifier in calls to get_ram_size(). Remove this qualifier in the prototype and in the calls where it is useless, and leave it only in the function body where it is needed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2006-11-06Sequential accesses to non-existent memory must be synchronized,Wolfgang Denk
at least on G2 cores. This fixes get_ram_size() problems on MPC5200 Rev. B boards.
