* 'master' of /home/wd/git/u-boot/custodians:
common/cmd_pxe.c: Fix GCC 4.6 build warnings
AVR32: fix timer_init() function
The switch to strict_strtoul() was not done correctly - this fixes
the compile error when CONFIG_CMD_TFTPPUT is active.
There appears to very little use of strict_strtoul() in commands, so
it might be easier to switch to simple_strtoul(). If not, we should
decide the best way to use strict_strtoul(). For now I have added a
friendly message which will of course increase code size.
Fix:
cmd_pxe.c: In function 'parse_pxefile_top':
cmd_pxe.c:941:5: warning: 'err' may be used uninitialized in this
function [-Wuninitialized]
cmd_pxe.c:921:6: note: 'err' was declared here
Cc: Jason Hobbs <jason.hobbs@calxeda.com>
Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
do_env_import() missed the final '\0' terminator when calculating the
size of an environment data block. This led to an erroneous 'bad CRC,
import failed' message for a checksum protected environment (-c.)
Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
In 9792987721c7980453fe6447c3fa6593b44f8458 Stefan describes a usecase
where the previous behavior of leaving wMaxPacketSize be unaligned
caused fatal problems. The initial fix for this problem was incomplete
however as it showed another cases of non-aligned access that previously
worked implicitly. This switches to making sure that all access of
wMaxPacketSize are done via (get|put)_unaligned.
In order to maintain a level of readability to the code in some cases
we now use a variable for the value of wMaxPacketSize and in others, a
macro.
Cc: Remy Bohmer <linux@bohmer.net>
OpenRISC:
Tested-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Beagleboard xM, Pandaboard run-tested, s5p_goni build-tested.
We already flush the kernel image after we've loaded it to ensure
visiblity to the other cores. We need to do the same thing for the
ramdisk and device tree images. In AMP boot scenarios we might not be
HW cache coherent with the secondary core that we are loading and
setting the ramdisk and device tree up for. Thus we need to ensure
we've flushed the regions of memory utilized by ramdisk and device tree
so the loadding and any modifications (from decompression or fdt updates)
are made visible to the secondary cores.
* 'master' of git://git.denx.de/u-boot-usb:
USB: efikamx: Enable USB on EfikaMX and EfikaSB
USB: Add generic ULPI layer and a viewport
USB: EHCI: Allow EHCI post-powerup configuration in board files
USB: mx51evk: add end enable USB host support on port 1
USB: mx53loco: add end enable USB host support on port 1
USB: MX5: Add MX5 usb post-init callback
USB: MX5: Abstract out mx51 USB pixmux configuration
USB: MX5: add generic USB EHCI support for mx51 and mx53
USB: MX5: add helper functions to enable USB clocks
usb:gadget:s5p Enable the USB Gadget framework at GONI
usb:gadget:s5p USB Device Controller (UDC) implementation
ehci: speed up initialization
usb: add help for missing start subcommand
cosmetic: remove excess whitespace from usb command help
usb: align usb_endpoint_descriptor to 16-bit boundary
usbtty: init endpoints prior to startup events
pxa: convert pxa27x_udc to use read and write functions
pxa: activate the first usb host port on pxa27x by default
pxa: fix usb host register mismatch
ehci-fsl: correct size of ehci caplength
USB: Add usb_event_poll() to get keyboards working with EHCI
USB: gadaget: add Marvell controller support
USB: Fix complaints about strict aliasing in OHCI-HCD
USB: Drop dead code from usb_kbd.c
USB: Rework usb_kbd.c
USB: Add functionality to poll the USB keyboard via control EP
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
* Support dynamic allocation of devices
* Passing data via usb device privptr
* Reorder functions to avoid forward declarations
* Introduce generic polling mechanism to fix musb and ehci-hcd breakage
due to using "extern new;" to access keyboard driver data!
This allows the keyboard to avoid requests via Interrupt Endpoint altogether and
run all requests via Control Endpoint. This uses the Get_Report request.
Rebased on current code.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Using mmap to allocate memory from the OS for RAM simulation we can use
u-boot own malloc implementation.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
This patch adds support for console output before the console is inited.
The main purpose of this is to deal with a very early panic() which would
otherwise cause a silent hang.
A new board_pre_console_putc() function is added to the board API. If
provided by the board it will be called in the event of console output
before the console is ready. This function should turn on all UARTs and
spray the character out if it possibly can.
The feature is controlled by a new CONFIG_PRE_CONSOLE_PUTC option.
Acked-by: Graeme Russ <graeme.russ@gmail.com>
During the rebase of commit 00b7d6e "USB: Squash checkpatch warnings
in usb_kbd.c" I missed a brace, resulting in a number of build errors.
Fix these.
Cc: Mike Frysinger <vapier@gentoo.org>
Rebased to current code.
* 'master' of git://git.denx.de/u-boot-arm:
davinci: Remove unwanted memsize.c from hawkboard's nand spl build
devkit8000: Move CONFIG_SYS_TEXT_BASE out of bss
da850evm: pass board revision info to kernel
arch/arm/include/asm/arch-omap5/clocks.h: Fix GCC 4.2 warnings
arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix GCC 4.6 warnings
arch/arm/cpu/armv7/omap-common/spl.c: Fix GCC 4.2 warnings
MX35: flea3: changes due to hardware revision B
MX: serial_mxc: cleanup removing nasty #ifdef
M28: Fix OB1 bug in GPIO driver
MXS: Add static annotations to dma driver
apbh_dma: return error value on timeout
Efika: Configure additional regulators for HDMI output
mx5: Correct a warning in clock.c
MC13892: Add REGMODE0 bits definitions
mx51evk: Configure the pins as GPIOs prior to using gpio_get_value
mx53smd: Configure the pins as GPIOs prior to using gpio_get_value
mx53evk: Configure the pins as GPIOs prior to using gpio_get_value
mx53ard: Configure the pins as GPIOs prior to using gpio_get_value
mx53loco: Configure the pins as GPIOs prior to using gpio_get_value
OMAP3: Add SPL_BOARD_INIT hook
AM3517 CraneBoard: Add SPL support
AM3517: Add SPL support
OMAP3: Add SPL support to omap3_evm
OMAP3: Add SPL support to Beagleboard
OMAP3 SPL: Add identify_nand_chip function
OMAP3 SPL: Rework memory initalization and devkit8000 support
OMAP3: Suffix all Micron memory timing parts with their speed
OMAP3: Add optimal SDRC autorefresh control values
omap3: mem: Add MCFG helper macro
OMAP3: Remove get_mem_type prototype
OMAP3: Change mem_ok to clear again after reading back
OMAP3: Add a helper function to set timings in SDRC
OMAP3: Update SDRC dram_init to always call make_cs1_contiguous()
omap3: mem: Comment enable_gpmc_cs_config more
ARM: davici_emac: Fix condition for number of phy detects
arm: printf() is not available in some SPL configurations
arm, davinci: add support for am1808 based enbw_cmc board
arm, davinci: move misc function in arch tree
arm, board/davinci/common/misc.c: Codingstyle cleanup
arm, davinci, da850: add uart1 tx rx pinmux config
arm, davinci: move davinci_rtc struct to hardware.h
arm, davinci: Remove duplication of pinmux configuration code
arm, hawkboard: Use the pinmux configurations defined in the arch tree
arm, da850evm: Use the pinmux configurations defined in the arch tree
arm, da850: Add pinmux configurations to the arch tree
arm, da850evm: Do pinmux configuration for EMAC together with other pinmuxes
arm, hawkboard: Remove obsolete struct pinmux_config i2c_pins
arm, davinci: Move pinmux functions from board to arch tree
arm, arm926ejs: always do cpu critical inits
omap_gpmc: use SOFTECC in SPL if it's enabled
nand_spl_simple: add support for software ECC
AM3517: move AM3517 specific mux defines to generic header
AM35xx: add EMAC support
davinci_emac: hardcode 100Mbps for AM35xx and RMII
davinci_emac: fix for running with dcache enabled
arm926ejs: add noop implementation for dcache ops
davinci_emac: conditionally compile specific PHY support
davinci_emac: use internal addresses in buffer descriptors
davinci_emac: move arch-independent defines to separate header
BeagleBoard: config: Really switch to ttyO2
ARM: davinci_dm6467Tevm: Fix build breakage
ARM: OMAP: Remove STACKSIZE for IRQ and FIQ if unused
ARM: OMAP3: Remove unused define SDRC_R_C_B
ARM: OMAP3: Remove unused define CONFIG_OMAP3430
omap4: fix IO setting
omap4+: streamline CONFIG_SYS_TEXT_BASE and other SDRAM addresses
omap4460: add ES1.1 identification
omap4: emif: fix error in driver
omap: remove I2C from SPL
omap4460: fix TPS initialization
omap: fix cache line size for omap3/omap4 boards
omap4: ttyO2 instead of ttyS2 in default bootargs
omap: Improve PLL parameter calculation tool
start.S: remove omap3 specific code from start.S
armv7: setup vector
armv7: include armv7/cpu.c in SPL build
armv7: disable L2 cache in cleanup_before_linux()
arm, arm926ejs: Fix clear bss loop for zero length bss
PXA: Move colibri_pxa270 to board/toradex/
PXA: Flip colibri_pxa27x to pxa-common.h
PXA: Introduce common configuration header for PXA
PXA: Rename pxa_dram_init to pxa2xx_dram_init
PXA: Squash extern pxa_dram_init()
PXA: Export cpu_is_ and pxa_dram_init functions
PXA: Cleanup Colibri PXA270
PXA: Replace timer driver
PXA: Add cpuinfo display for PXA2xx
PXA: Separate PXA2xx CPU init
PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]X
PXA: Unify vpac270 environment size
PXA: Enable command line editing for vpac270
PXA: Adapt Voipac PXA270 to OneNAND SPL
PXA: Drop Voipac PXA270 OneNAND IPL
PXA: Fixup PXA25x boards after start.S update
PXA: Re-add the Dcache locking as RAM for pxa250
PXA: Rework start.S to be closer to other ARMs
PXA: Drop XM250 board
PXA: Drop PLEB2 board
PXA: Drop CRADLE board
PXA: Drop CERF250 board
Fix regression in SMDK6400
nand: Add common functions to linux/mtd/nand.h
Ethernut 5 board support
net: Armada100: Fix compilation warnings
ARM: remove duplicated code for LaCie boards
ARM: add support for LaCie 2Big Network v2
mvsata: fix ide_preinit for missing disks
netspace_v2: Read Ethernet MAC address from EEPROM
omap3evm: Add support for EFI partitions
part_efi: Fix compile errors
It is fine to use __maybe_unused instead of #ifdef, but we also need one
for print_eth() since not all boards have Ethernet. This fixes this
warning:
cmd_bdinfo.c:39:13: warning: 'print_eth' defined but not used [-Wunused-function]
The spi.h include is no longer included in exports.h, so must be included
here.
This fixes these errors:
In file included from exports.c:41:0:
/home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h: In function 'jumptable_init':
/home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:27:1: error: 'spi_init' undeclared (first use in this function)
/home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:27:1: note: each undeclared identifier is reported only once for each function it appears in
/home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:28:1: error: 'spi_setup_slave' undeclared (first use in this function)
/home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:29:1: error: 'spi_free_slave' undeclared (first use in this function)
/home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:30:1: error: 'spi_claim_bus' undeclared (first use in this function)
/home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:31:1: error: 'spi_release_bus' undeclared (first use in this function)
/home/sjg/trunk/src/third_party/u-boot/files/include/_exports.h:32:1: error: 'spi_xfer' undeclared (first use in this function)
This reverts commit 5c45a22b9203351a32aec4600514341b91175542.
It causes a lot of "incompatible pointer type" warnings for a large
number of Ethernet drivers, which are not really worth fixing
especially as this patch was only supposed to help the old,
deprecated miiphy API. Instead of adding more efforts to a lost case
we rather revert it.
The command gets an arbitrary number of arguments (up to 30), which
are interpreted as byte values and are feed into the TPM device after
proper initialization. Then the return value and data of the TPM
driver is examined.
TPM commands are described in the TCG specification.
For instance, the following sequence is the 'TPM Startup' command, it
is processed by the TPM and a response is generated:
boot > tpm 0x0 0xc1 0x0 0x0 0x0 0xc 0x0 0x0 0x0 0x99 0x0 0x1
Found TPM SLB9635 TT 1.2 by Infineon
Got TPM response:
00 c4 00 00 00 0a 00 00 00 00
If the command is corrupted (fed one byte short), an error is reported:
generic_lpc_tpm.c:311 unexpected TPM status 0xff000888
generic_lpc_tpm.c:516 failed sending data to TPM
tpm command failed
boot >
Change-Id: I3f3c5bfec8b852e208c4e99ba37b0f2b875140b0
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
CC: Wolfgang Denk <wd@denx.de>
If no default label is specified, but a situation arises where the
default label should be used, treat the first label specified as the
default label.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Cc: Ricardo Salveti de Araujo <ricardo.salveti@linaro.org>
If we move the local funcs to the top of the file, and use the
__maybe_unused define, we can drop a lot of ugly ifdef logic and
duplicated prototypes.
This patch is added for PHY whose register offset value exceeds 0xFF and
cannot be used with "unsigned char" datatype in miiphy_read, miiphy_write
and miiphy_register functions. Datatype of register offset is changed to
unsigned short instead of unsigned char so that offset value greater then
0xFF can be used.
Signed-off-by: Chandan Nath <chandan.nath@ti.com>
Signed-off-by: Thomas Weber <weber@corscience.de>
Fix:
menu.c: In function 'menu_item_print':
menu.c:91: warning: passing argument 1 of 'putc' makes integer from
pointer without a cast
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Heiko Schocher <hs@denx.de>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
We want to move everything to phylib, and we definitely don't want
new drivers using the miiphy infrastructure.
Signed-off-by: Andy Fleming <afleming@freescale.com>
* 'sr@denx.de' of git://git.denx.de/u-boot-staging:
image: Don't detect XIP images as overlapping.
image: Implement IH_TYPE_KERNEL_NOLOAD
bootm_load_os() detects when it writes the decompressed image over
the top of the compressed image. If this happens, the original image
is corrupted. When the original image is a multi-component legacy image,
or a (potentially multi-component) FIT image, this implies that other
components may be corrupted. In turn, this means that booting is unlikely
to be successful.
However, in the case of no image compresssion coupled with an image with
load address equal to where the image is already located (e.g. an XIP
kernel, or IH_TYPE_KERNEL_ANYLOAD), there has been no copy and hence no
corruption, no matter whether it's a single-component legacy image, a
multi-component legacy image, or a FIT image. In this case, disable the
overlap detection, and allow boot to continue.
Without this change, when booting a single-component legacy image that
contains an IH_TYPE_KERNEL_ANYLOAD, bootm_load_os() would have returned
BOOTM_ERR_OVERLAP, but the caller ignores this, and boot continues and
succeeds. Now, the false error is no longer even returned.
Without this change, when booting a FIT image that contains an
BOOTM_ERR_OVERLAP, which would then cause the caller to reset the board.
Now, the false error is no longer returned, and boot succeeds.
The legacy uImage format includes an absolute load and entry-point
address. When bootm operates on a kernel uImage in memory that isn't
loaded at the address in the image's load address, U-Boot will copy
the image to its address in the header.
Some kernel images can actually be loaded and used at any arbitrary
address. An example is an ARM Linux kernel zImage file. To represent
this capability, IH_TYPE_KERNEL_NOLOAD is implemented, which operates
just like IH_TYPE_KERNEL, except that the load address header is
ignored, and U-Boot does not copy the image to its load address, but
rather uses it in-place.
This is useful when sharing a single (uImage-wrapped) zImage across
multiple boards with different memory layouts; in this case, a specific
load address need not be picked when creating the uImage, but instead
is selected by the board-specific U-Boot environment used to load and
boot that image.
v2: Rename from IH_TYPE_KERNEL_ANYLOAD to IH_TYPE_KERNEL_NOLOAD.
Planned future ports requires more granularity for some options
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
common/menu.c used printf() in a number of places to print user
provided, constant strings (like the "title" string). printf() is
dangerous here for example in case the user unwittingly embeds some
'%' caracters that printf() would interpret as formatting and then
pick up random arguments. Use puts() instead.
We also omit the trailing ':' in the title line - if a user wants
this, he can provide it as part of the title string.
cmd_nvedit.c: In function 'do_env_grep':
cmd_nvedit.c:182:3: warning: suggest parentheses around assignment used as truth value
* 'hs@denx.de' of git://git.denx.de/u-boot-staging:
drivers/net/dnet.c: Fix GCC 4.6 warnings
board/xaeniax/flash.c: Fix GCC 4.6 warnings
net/bootp.c: Fix GCC 4.6 warning
common/cmd_bootm.c: Fix GCC 4.6 warnings
board/mx1ads/mx1ads.c: Fix GCC 4.6 warning
board/mx1ads/syncflash.c: Fix GCC 4.6 warnings
board/lubbock/flash.c: Fix GCC 4.6 warnings
drivers/net/cs8900.c: Fix GCC 4.6 warning
arch/arm/cpu/arm926ejs/omap/cpuinfo.c: Fix GCC 4.6 warnings
drivers/net/lan91c96.c: Fix GCC 4.6 warning
board/ronetix/pm9263/pm9263.c: Fix GCC 4.6 warning
drivers/mtd/onenand/samsung.c: Fix GCC 4.6 warning
drivers/usb/musb/musb_hcd.c: Fix GCC 4.6 warning
Fix:
cmd_bootm.c: In function 'bootm_load_os':
cmd_bootm.c:315:7: warning: unused variable 'unc_len'
[-Wunused-variable]
Cleanup the env_common.c checkpatch warnings, errors and coding style.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cleanup the env_nand.c checkpatch warnings, errors and coding style.
Cleanup the env_flash.c checkpatch warnings, errors and coding style.
Cleanup the env_sf.c checkpatch warnings, errors and coding style.
Cleanup the env_eeprom.c checkpatch warnings, errors and coding style.
Cleanup the env_embedded.c checkpatch warnings, errors and coding style.
There is one error left though:
ERROR: Macros with multiple statements should be enclosed in a do - while loop
#79: FILE: u-boot/common/env_embedded.c:79:
+#define GEN_ABS(name, value) \
+ asm(".globl " GEN_SYMNAME(name)); \
+ GEN_SET_VALUE(name, value)
total: 1 errors, 0 warnings, 213 lines checked
We cannot enclose that statement in a do - while loop,
because these are a global assembly declarations.
Cleanup the env_mmc.c checkpatch warnings, errors and coding style.
Simplify env_relocate_spec() function implementation.
Also mark internal functions as static.
Cleanup the env_nvram.c checkpatch warnings, errors and coding style.
There are 2 wanring left about the extern used in c file:
WARNING: externs should be avoided in .c files
#53: FILE: env_nvram.c:53:
+extern void *nvram_read(void *dest, const long src, size_t count);
#54: FILE: env_nvram.c:54:
+extern void nvram_write(long dest, const void *src, size_t count);
total: 0 errors, 2 warnings, 138 lines checked
There is no common nvram header file to use instead of the externs.
Cleanup the env_onenand.c checkpatch warnings, errors and coding style.
Cleanup the env_dataflash.c checkpatch warnings, errors
and coding style.
Cleanup the env_mgdisk.c checkpatch warnings, errors
and coding style.
