path: root/common
2018-09-13common: add board specific hook for os pre-boot configGerard Salvatella
Some boards require specific configuration prior to booting the kernel. For instance, our boards require shutting down the display to avoid fading transitions before the drivers are reloaded by the kernel. This can be facilitated by adding an extra hook during the os booting process. Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-08-31MLK-12883 usb: limit USB_MAX_XFER_BLK to 256Peng Fan
For Some USB mass storage devices, such as: " - Kingston DataTraveler 2.0 001D7D06CF09B04199C7B3EA - Class: (from Interface) Mass Storage - PacketSize: 64 Configurations: 1 - Vendor: 0x0930 Product 0x6545 Version 1.16 " When `usb read 0x80000000 0 0x2000`, we met "EHCI timed out on TD - token=0x80008d80". The devices does not support scsi VPD page, we are not able to get the maximum transfer length for READ(10)/WRITE(10). So we limit this to 256 blocks as READ(6). Signed-off-by: Peng Fan <peng.fan@nxp.com> (cherry picked from commit df0052575b2bc9d66ae73584768e1a457ed5d914)
2017-04-05common: spl: don't optimize away version stringColibri-iMX7_LXDE-Image_2.7b2-20170410Colibri-iMX6_LXDE-Image_2.7b2-20170410Colibri-VF_LXDE-Image_2.7b2-20170410Colibri-T30_LXDE-Image_2.7b2-20170410Colibri-T20_LXDE-Image_2.7b2-20170410Apalis-iMX6_LXDE-Image_2.7b2-20170410Apalis-TK1_LXDE-Image_2.7b2-20170410Apalis-T30_LXDE-Image_2.7b2-20170410Max Krummenacher
With CONFIG_SPL_SILENT_CONSOLE the 'U-Boot SPL...' version string is no longer linked into the SPL binary. Factor out the version string and make sure that it is not optimize away by lto. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-03-30common: apalis/colibri imx6: spl: add config to silence console outputMax Krummenacher
This adds a Kconfig SPL_SILENCE_CONSOLE which allows to suppress any console output which in the normal program flow is printed in the SPL. Error messages and the likes will still be printed. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-03-30common: spl: add config to suppress console outputMax Krummenacher
This adds a Kconfig DISABLE_CONSOLE_IN_SPL which allows to suppress any console output in the SPL. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-18spl: add serial download protocol (SDP) supportStefan Agner
Add USB serial download protocol support to SPL. If the SoC started in recovery mode the SPL will immediately switch to SDP and wait for further downloads/commands from the host side. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-01-11board_r: workaround deleted output line and garbage charsColibri_iMX7_LinuxImageV2.7Beta1_20170112Colibri_iMX6_LinuxImageV2.7Beta1_20170112Colibri_VF_LinuxImageV2.7Beta1_20170112Colibri_T30_LinuxImageV2.7Beta1_20170112Colibri_T20_LinuxImageV2.7Beta1_20170112Apalis_iMX6_LinuxImageV2.7Beta1_20170112Apalis_TK1_LinuxImageV2.7Beta1_20170112Apalis_T30_LinuxImageV2.7Beta1_20170112Max Krummenacher
When booting we see: DRAM: 256 MiB <strange characters>FSL_SDHC: 0, FSL_SDHC: 1 auto-detected panel vga-rgb The should be: DRAM: 256 MiB PMIC: device id: 0x10, revision id: 0x11, programmed MMC: FSL_SDHC: 0, FSL_SDHC: 1 auto-detected panel vga-rgb This seems to be caused by the call to initr_serial which in our configuration goes into drivers/serial/serial-uclass.c serial_initialize(). Printing an empty line helps. The empty line gets deleted and no strange characters appear. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-01-11common: fdt_support: Add support for setting usable memorySanchayan Maity
Add support for setting the linux,usable-memory in the memory node of device tree. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-11spl: add USB Gadget config optionStefan Agner
Introduce USB Gadget config option. This allows to combine Makefile entries for SPL_USBETH_SUPPORT and SPL_DFU_SUPPORT. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Ravi Babu <ravibabu@ti.com> (cherry picked from commit e94793c844a40606252f2e3f6428063e057b3fd2)
2017-01-11spl: dfu: move DFU Kconfig to SPL KconfigStefan Agner
The DFU Kconfig menu entries should be part of the SPL Kconfig file. Also avoid using the top level Makefile by moving the config dependent build artifacts to the driver/ and driver/usb/gadget/ Makfiles. With that, DFU can be built again in SPL if CONFIG_SPL_DFU_SUPPORT is enabled. Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now") Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Lukasz Majewski <l.majewski@samsung.com> (cherry picked from commit 5991703e88f320767d9390d64a6a9bd62560696b)
2017-01-11spl: add RAM boot device only if it is actually definedStefan Agner
Some devices (e.g. dra7xx) support loading to RAM using DFU without having direct boot from RAM support. Make sure the linker list does not contain BOOT_DEVICE_RAM if CONFIG_SPL_RAM_DEVICE is not enabled. Fixes: 98136b2f26fa ("spl: Convert spl_ram_load_image() to use linker list") Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> (cherry picked from commit 34ee947ac3be7a79b89fa8bb690379651cc9598a)
2017-01-11spl: mmc: fix switch statementMax Krummenacher
If CONFIG_SPL_LIBCOMMON_SUPPORT is not defined there is a lone case statement at the end of the switch leading to a compile error. Remove the offending case statement. | common/spl/spl_mmc.c:339:7: error: label at end of compound statement Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Marek Vasut <marex@denx.de> (cherry picked from commit c8d7647f639813cff08a4a7de62db815829ec72b)
2017-01-11generic-board: make show_board_info a weak functionMarcel Ziswiler
Make show_board_info() a weak function which allows for custom board specific implementations thereof. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit f7637cc01414b9c87b6b0f861f34d83c19bfaaaf)
2017-01-11Revert "generic-board: allow showing custom board info"Marcel Ziswiler
Drop CONFIG_CUSTOM_BOARDINFO as it is not Kconfig compliant and anyway not really used anywhere plus the upcoming weak show_board_info() approach seems much superior. This reverts commit a9ad18c9d5fe2554753b0f9a52adfd5ebce61147. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 62e7a5c5f85c8dd37500571da9607ef68203af12)
2016-11-05image: Protect against overflow in unknown_msg()Simon Glass
Coverity complains that this can overflow. If we later increase the size of one of the strings in the table, it could happen. Adjust the code to protect against this. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Coverity (CID: 150964)
2016-11-03cmd: dfu: Add error handling for board_usb_initMichal Simek
board_usb_init() can failed and error should be handled properly. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-10-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: common/Kconfig configs/dms-ba16_defconfig
2016-10-26config: Move CONFIG_DEFAULT_FDT_FILE to defconfigsJagan Teki
- Add DEFAULT_FDT_FILE kconfig entry - Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Michael Trimarchi <michael@amarulasolutions.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-23Convert CONFIG_SYS_STDIO_DEREGISTER to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Re-sync] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONSOLE_PRE_CONSOLE_BUFFER options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-17watchdog: Fix Watchdog Reset while in U-Boot PromptAndreas J. Reichel
Hardware: CM-FX6 Module from Compulab This patch fixes unwanted watchdog resets while the user enters a command at the U-Boot prompt. As found on the CM-FX6 board from Compulab, when having enabled the watchdog, a missing WATCHDOG_RESET call in common/console.c causes this and alike boards to reset when the watchdog's timeout has elapsed while waiting at the U-Boot prompt. Despite the user could press several keys within the watchdog timeout limit, the while loop in cli_readline.c, line 261, does only call WATCHDOG_RESET if first == 1, which gets set to 0 in the 1st loop iteration. This leads to a watchdog timeout no matter if the user presses keys or not. Although, this affects other boards as well as it touches common/console.c, the macro WATCHDOG_RESET expands to {} if watchdog support isn't configured. Hence, there's no harm caused and no need to surround it by #ifdef in this case. * Symptom: U-Boot resets after watchdog times out when in commandline prompt and watchdog is enabled. * Reasoning: When U-Boot shows the commandline prompt, the following function call stack is executed while waiting for a keypress: common/main.c: main_loop => common/cli.c: cli_loop() => common/cli_hush.c: parse_file_outer => parse_stream_outer => parse_stream => b_getch(i) => i->get(i) => file_get => get_user_input => cmdedit_read_input => uboot_cli_readline => common/cli_readline.c: cli_readline => cli_readline_into_buffer => cread_line => getcmd_getch (== getc) => common/console.c: fgetc => console_tstc common/console.c: (with CONFIG_CONSOLE_MUX is set) - in console_tstc line 181: If dev->tstc(dev) returns 0, the global tstcdev variable doesn't get set. This is the case if no character is in the serial buffer. - in fgetc(int file), line 297: Program flow keeps looping because tstcdev does not get set. Therefore WATCHDOG_RESET is not called, as mx_serial_tstc from drivers/serial/serial_mxc.c does not call it. * Solution: Add WATCHDOG_RESET into the loop of console_tstc. Note: Macro expands to {} if not configured, so no #ifdef is needed. * Comment: Signed-off-by: Christian Storm <christian.storm@tngtech.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Andreas J. Reichel <Andreas.Reichel@tngtech.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-15spl: move SYS_OS_BASE to KconfigHeiko Schocher
Move SYS_OS_BASE to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Also migrate a4m2k] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-10-13libfdt: Sync fdt_for_each_subnode() with upstreamSimon Glass
The signature for this macro has changed. Bring in the upstream version and adjust U-Boot's usages to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Update to drivers/power/pmic/palmas.c: Signed-off-by: Keerthy <j-keerthy@ti.com> Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-13cmd/fdt: add possibilty to have 'extrasize' on fdt resizeHannes Schmelzer
Sometimes devicetree nodes and or properties are added out of the u-boot console, maybe through some script or manual interaction. The devicetree as loaded or embedded is quite small, so the devicetree has to be resized to take up those new nodes/properties. In original the devicetree was only extended by effective 4 * add_mem_rsv. With this commit we can add an argument to the "fdt resize" command, which takes the extrasize to be added. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-12Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2016-10-11board_f: Drop the extra fdtdec_prepare_fdt()Simon Glass
This is already called earlier, from fdtdec_setup(), so drop this unnecessary call from the init sequence. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-11dm: stdio: Allow lazy probing of video devicesSimon Glass
At present all video devices are probed on start-up. It would be better to probe a device only when it is needed. This can happen if it is referenced in the stdout environment variable, for example. Add support for this by searching for a suitable device when needed, probing it, and finding the stdio device it creates. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-08Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-10-08spl: saveenv: adding saveenv support in SPLB, Ravi
By default saveenv option is not supported for SPL. This patch enable the support for save environment variable for SPL build. Enable save environment support in SPL after setenv. By default the saveenv option is not provided in SPL, but some boards need this support in 'Falcon' boot, where SPL need to boot from different images based on environment variable set by OS. For example OS may set "reboot_image" environment variable to "recovery" inorder to boot recovery image by SPL. The SPL read "reboot_image" and act accordingly and change the reboot_image to default mode using setenv and save the environemnt. Signed-off-by: Ravi Babu <ravibabu@ti.com> Reviewed-by: Simon Glass <sig@chromium.org> change in v1: - dropped SUPPORT, use CONFIG_SPL_SAVEENV - updates the comments in mmc_private.h
2016-10-07common/console.c: ensure GD_FLG_SILENT is set or clearedChris Packham
When CONFIG_SILENT_CONSOLE is defined and the default environment has silent=1 it is not possible for a user to make the console un-silent if the environment is not available when console_init_f() is called (for example because the environment is in SPI). Add a new helper function console_update_silent() and call it from both console_init_f() and console_init_r(). Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-10-06spl: Make spl_boot_list a local variableSimon Glass
There is no need for this to be in the BSS region. By moving it we can delay use of BSS in SPL. This is useful for machines where the BSS region is not in writeable space. On 64-bit x86, SPL runs from SPI flash and it is easier to eliminate BSS use than link SPL to run with BSS at a particular cache-as-RAM (CAR) address. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Update spl_load_simple_fit() to take an spl_image paramSimon Glass
Upda the SPL FIT code to use the spl_image parameter. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Update fat functions to take an spl_image parameterSimon Glass
Update the fat loader to avoid using the spl_image global variable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Update ext functions to take an spl_image parameterSimon Glass
Update the ext loader to avoid using the spl_image global variable. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Pass spl_image as a parameter to load_image() methodsSimon Glass
Rather than having a global variable, pass the spl_image as a parameter. This avoids BSS use, and makes it clearer what the function is actually doing. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_board_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. Update existing users. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_net_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. We need two variants - one for BOOT_DEVICE_CPGMAC and one for BOOT_DEVICE_USBETH. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_spi_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. Also set up the sunxi function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: spi: Move the generic SPI loader into common/splSimon Glass
All the other SPL loaders are in this directory, so move the SPI one in there too. There are two board-specific SPI loaders (fsl and sunxi). These remain in the drivers/mtd/spi directory, since they do not contain generic code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06spl: Convert spl_sata_load_image() to use linker listSimon Glass
Add a linker list declaration for this method and remove the explicit switch() code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
