Do not reset environment when using Serial Downloader. This is
problematic for some modules where we set environment variables
dynamically during boot (e.g. soc).
Make should_load_env a weak function. This allows a board to
decide whether to load the environment or not. This can be
useful when detecting recovery mode to avoid loading hostile
environments.
nand torture currently works on exactly one nand block which is specified
by giving the byteoffset to the beginning of the block.
Extend this by allowing for a second parameter specifying the byte size
to be tested.
e.g.
==> nand torture 1000000
NAND torture: device 0 offset 0x1000000 size 0x20000 (block size 0x20000)
Passed: 1, failed: 0
==> nand torture 1000000 40000
NAND torture: device 0 offset 0x1000000 size 0x40000 (block size 0x20000)
Passed: 2, failed: 0
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
[scottwood: fix usage to show size as optional, and add misssing braces]
Signed-off-by: Scott Wood <oss@buserror.net>
(cherry picked from commit 1866be7d28ce807397e4aedd93f70564ac8bebc0)
We need raw nand access to write the fcb in cmd_writebcb_mx7.
we change it to other values(sabresd dq and auto 6qp 0812 daily build)
Correct the bootargs which is printed.
It should be newbootargs rather than bootimage's bootargs.
Signed-off-by: zhang sanshan <b51434@freescale.com>
The bootargs is not set correctly.
The final bootargs consist of uboot's bootargs and bootimg's bootargs.
This patch set bootimg's bootargs as final bootargs if uboot's bootargs is not set.
And take uboot's bootargs as final bootargs if uboot's bootargs is set.
For USB boot, eg, mfgtool programming case, some laptops/pcs
may not work properly if the board do not disconnect until
linux kernel usb driver initialization process, finishes the
ROM code connection at u-boot can fix this problem, and this
was the original work flow when mfgtool flow was introduced at
u-boot.
Tested-by: Spring Zhang <b17931@freescale.com>
Tested-by: Zhang Sanshan <b51434@freescale.com>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
1. Replace the UDC driver with community's USB gadget d_dnl driver.
2. Integrate the FSL SD/SATA/NAND flash operations, since the GPT and
EFI partitions are not support by i.MX.
3. Add FDT support to community's android image.
4. Change the booti command to boota, due to the booti has been used for
ARM64 image boot.
5. Modify boota implementation to load ramdisk and fdt to their loading
addresses specified in boot.img header, while bootm won't do it for
android image.
6. Modify the android image HAB implementation. Authenticate the boot.img
on the "load_addr" for both SD and NAND.
7. Enable new configuration CONFIG_FSL_FASTBOOT for Freescale's fastboot
with relevant header file "fsl_fastboot.h". While disabling the
configuration, the community fastboot is used.
8. Use community's way to combine cmdline in boot.img and u-boot environment,
not overwrite the cmdline in boot.img
Signed-off-by: Ye.Li <B37916@freescale.com>
Fix build warning:
common/lcd.c: In function 'lcd_clear':
common/lcd.c:166:6: warning: variable 'bg_color' set but not used [-Wunused-but-set-variable]
int bg_color;
common/lcd.c: In function 'lcd_setmem':
common/lcd.c:296:2: warning: format '%d' expects argument of type 'int', but argument 2 has type 'u_long' [-Wformat=]
debug("LCD panel info: %d x %d, %d bit/pix\n", panel_info.vl_col,
common/lcd.c:296:2: warning: format '%d' expects argument of type 'int', but argument 3 has type 'u_long' [-Wformat=]
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Remove the authentication size to be a fixed size, due to
recovery.img may be much bigger than the boot.img
Add signature size to boot or recovery image size, which is
added by boot_signer in android build process
Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
(cherry picked from commit d59b24fefcd56d085c4010643ca9f6522a3cc58a)
boot.img includes kernel image, ramdisk img, dtb, and bootargs.
All are critical for android security. Protect the whole boot.img
with HAB.
(cherry picked from commit 8a49e53c5b518677b46cada5df153306161f29ac)
Add udc and fastboot support
We did not use the upstream way.
Currently use CI_UDC and USB_GAGDET of upstream can make fastboot work,
but lack of flash operation, so we still use our way.
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
LCD_MONOCHROME is removed in commit f4469f50b0367820121ef2d313517d422ed70e1d.
Add related code back to support epdc.
In this patch, also include crm_regs.h in mx6slevk.c to make epdc code
be compiled ok.
COLOR_MASK is also added from commit a7de2953f51e70754190d3516167d58d27d17219
Add SECURE BOOT in bootm
Since the zImage is used at default, add the HAB image authentication
support in bootz to authenticate zImage.
(cherry picked from commit 591100eec569dd1d54f61e9f49fe995f56a021eb)
Add sata command
This patch add the support to load/save env to the slot which
was used as the boot media by dynamic detection.
Signed-off-by: Jason Liu <r64343@freescale.com>
If boot from usb, reset environment to default value.
Auto apply mfgtools setting and boot mfgtools kernel.
Signed-off-by: Frank Li <Frank.li@freescale.com>
Add new function "arch_auxiliary_core_check_up" to check whether M4
is already up. Therefore, avoid starting M4 again when it is running.
(cherry picked from commit 54a0803b29c5ab459bedfb2c68c1e94b89866aa1)
To boot a auxiliary core in asymmetric multicore system, introduce the
new command "bootaux" to do it.
Example of boot auxliary core from 0x70000000 where stores the boot head
information that should be parsed by each core.
"bootaux 0x70000000"
(cherry picked from commit fd00c322d058e02953a336517547174edaf2c573)
Allow to boot eCos, MQX and bare-metal firmwares to boot on the
secondary Cortex-M4. The boot code is equal for all those firmware
types, the argument register will be set to 0 and the code will
jump to the specified entry point directly.
Add new identifiers for Cortex-M4 related (RT)OS eCos, MQX and
Bare-metal.
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer
alignment into account which led to failures of the following form:
ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108
This fixes the following warning (and the runtime error reporting):
../common/image-fdt.c:491:4: warning: 'fdt_ret' may be used uninitialized in this function [-Wmaybe-uninitialized]
did not work:
Colibri T30 # crc32 0x80000000 0x100
crc32 for 80000000 ... 800000ff ==> 9eb4f5ca
Colibri T30 # crc32 -v 0x80000000 0x100 c9a057b3
crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != ffffffff ** ERROR **
Colibri T30 # crc32 -v 0x80000000 0x100 9eb4f5ca
crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != 301eeead ** ERROR **
now works again:
crc32 for 80000000 ... 800000ff ==> 9eb4f5ca != c9a057b3 ** ERROR **
Allow showing custom board info from a checkboard() function being
implemented if CONFIG_CUSTOM_BOARDINFO is specified.
The ARM reference designs all use a special flash image format
that stores a footer (two versions exist) at the end of the last
erase block of the image in flash memory.
Version one of the footer is indicated by the magic number
0xA0FFFF9F at 12 bytes before the end of the flash block and
version two is indicated by the magic number 0x464F4F54 0x464C5348
(ASCII for "FLSHFOOT") in the very last 8 bytes of the erase block.
This command driver implements support for both versions of the
AFS images (the name comes from the Linux driver in drivers/mtd/afs.c)
and makes it possible to list images and load an image by name into
the memory with these commands:
afs - lists flash contents
afs load <image> - loads image to address indicated in the image
afs load <image> <addres> - loads image to a specified address
This image scheme is used on the ARM Integrator family, ARM
Versatile family, ARM RealView family (not yet supported in U-Boot)
and ARM Versatile Express family up to and including the new
Juno board for 64 bit development.
The ubi check command is expected to not fail and just check whether
a volume exist or not. Currently, when a volume does not exist, the
command fails which leads to an error:
"exit not allowed from main input shell."
Use 1 to indicate that a volume does not exist. This allows to use
ubi check in an if statement, e.g.
if ubi check rootfs; then; echo "exists"; else; echo "not there"; fi
introduce CONFIG_SPL_PANIC_ON_RAW_IMAGE.
An SPL which define this will panic() if the
image it has loaded does not have a mkimage
signature.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
With e37f1eb we now use strict_strtoul() in do_mem_mtest() and this
gives us a warning:
../include/vsprintf.h:38:5: note: expected 'long unsigned int *' but
argument is of type 'int *'
Currently, memtest will silently accept bad data. Perform error
checking on user intput.
Signed-off-by: Pavel Machek <pavel@denx.de>
The u-boot environment is redundantly stored in a NOR flash on our boards.
Redundant means that there are two places to store the environment. But only
one of the two is active. I discovered that on one board the u-boot (env_sf)
uses the environment from the second place and the Kernel (fw_printenv) uses
the environment from the first place.
To decide which is the active environment there is a byte inside the
environment. 1 means active and 0 means obsolete. But on that board both
environments had have a 1. This can happen if a power loss or reset occurs
during writing the environment. In this situation the u-boot (env_sf)
implementation uses the second environment as default. But the Kernel
(fw_printenv) implementation uses the first environment as default.
This commit corrects the default in the u-boot env_sf implementation when a
problem was detected. Now the recovery default is the same like in all other
environment implementations. E.g. fw_printenv and env_flash. This ensures that
u-boot and Kernel use the same environment.
Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
Intention behind this work was elimination of as much assembly-written
code as it is possible.
In case of ARC we already have relocation fix-up implemented in C so why
don't we use C for U-Boot copying, .bss zeroing etc.
It turned out x86 uses pretty similar approach so we re-used parts of
code in "board_f.c" initially implemented for x86.
Now assembly usage during init is limited to stack- and frame-pointer
setup before and after relocation.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
This command is only enabled by one board, complicates the NAND code,
and doesn't appear to have been functioning properly for several
years. If there are no bad blocks in the NAND region being written
nand_write_skip_bad() will take the shortcut of calling nand_write()
which bypasses the special yaffs handling. This causes invalid YAFFS
data to be written. See
http://lists.denx.de/pipermail/u-boot/2011-September/102830.html for
an example and a potential workaround.
U-Boot still retains the ability to mount and access YAFFS partitions
via CONFIG_YAFFS2.
Previously NAND writes were only verified when CONFIG_MTD_NAND_VERIFY_WRITE
was defined. On boards without this define writes could fail silently.
Boards with CONFIG_MTD_NAND_VERIFY_WRITE could prematurely report
failures which ECC could correct.
Add a verification step after all "nand write[.x]" commands to ensure the
writes were successful. The verification uses ECC for for "normal"
writes, but does not for raw and yaffs writes. Some test cases which
inject fake bad bits on a 2K page flash are below.
Test cases with CONFIG_MTD_NAND_VERIFY_WRITE defined:
Example of an ECC write which previously failed when
CONFIG_MTD_NAND_VERIFY_WRITE was defined, but now succeeds because ECC
is used during verification:
nand erase 0 0x10000
dhcp /somefile
mw.b 0x10000 0xff 0x2000
mw.b 0x10020 0xfe 1
nand write.raw 0x10000 0x800 1
mw.b 0x1000020 0x01 1
nand write 0x1000000 0x800 0x1800
Test cases without CONFIG_MTD_NAND_VERIFY_WRITE defined:
Example of an ECC write which previously silently failed:
dhcp /somefile
mw.b 0x10020 0x00 1
mw.b 0x1000020 0xff 1
Example of a raw write which previously failed silently due to stuck
data bit, but now errors out:
dhcp /somefile
mw.b 0x10020 0xfe 1
nand write.raw 0x1000000 0x800 3
Example of a raw write which previously failed silently due to stuck OOB
dhcp /somefile
mw.b 0x10810 0xfe 1
mw.b 0x1000810 0x01 1
Tested-by: Heiko Schocher <hs@denx.de>
Acked-by: Heiko Schocher <hs@denx.de>
Fix eb_cpu5282 and eb_cpu5282_internal unresolved external error.
These boards have video but don't need any ppc related
video_setmem().
Fix M53017EVB moving away embedded env to a different offset,
as in M52277EVB.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
Purpose of this change is to make it possible to re-use code currently
used on X86 solely for other architectures. For example:
* init_sequence_f_r
* board_init_f_r
Even though board_init_f_mem() has nothing to do with any particular
architecture it won't work (at least in current implementation) for X86.
This is because on X86 "gd" is an alias to function get_fs_gd_ptr(),
thus we cannot assign anything to it.
So this change separates selection of board_init_f_mem() from X86 while
keeping it disabled for X86 still.
Add an optional -bootable parameter to the part list commands to only
put the list of bootable partitions in the environment variable
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Various files are needlessly rebuilt every time due to the version and
build time changing. As version.h is not actually needed, remove the
include.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Macpaul Lin <macpaul@andestech.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Philippe Reynes <tremyfr@yahoo.fr>
Cc: Eric Jarrige <eric.jarrige@armadeus.org>
Cc: "David Müller" <d.mueller@elsoft.ch>
Cc: Phil Edworthy <phil.edworthy@renesas.com>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: Torsten Koschorrek <koschorrek@synertronixx.de>
Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
Without this patch, the IMX watchdog will not be initialized. And therefor
not active. This patch fixes this by calling hw_watchdog_init() also when
CONFIG_IMX_WATCHDOG is defined.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
README
Added support to disable the start of application by using
a environment variable autostart
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
This fixes a regression of e310b93ec1, affecting Ethernet on the Jetson
TK1, e.g.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
This commit introduces new config: CONFIG_SYS_MALLOC_CLEAR_ON_INIT.
This config is an expert option and is enabled by default.
The all amount of memory reserved for the malloc, is by default set
to zero in mem_malloc_init(). When the malloc reserved memory exceeds
few MiB, then the boot process can slow down.
So disabling this config, is an expert option to reduce the boot time,
and can be disabled by Kconfig.
Note:
After disable this option, only calloc() will return the pointer
to the zeroed memory area. Previously, without this option,
the memory pointed to untouched malloc memory region, was filled
with zeros. So it means, that code with malloc() calls should
be reexamined.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Currently the usage text for the 'ums' command looks like this:
Usage:
ums ums <USB_controller> [<devtype>] <devnum> e.g. ums 0 mmc 0
,so remove the extra 'ums' in the text.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
In case of global data structure defined as "register volatile" compiler
throws an warning about incorrect type used:
--->8---
common/board_f.c: In function "board_init_f_r":
common/board_f.c:1073:2: warning: passing argument 1 of "&board_init_r
+(sizetype)gd->reloc_off" discards "volatile" qualifier from pointer
target type [enabled by default]
(board_init_r + gd->reloc_off)(gd, gd->relocaddr);
common/board_f.c:1073:2: note: expected "struct gd_t *" but argument is
of type "volatile struct gd_t *"
--->8---
An obvious fix is manual casting to "gd_t *".
Cc: Tom Rini <trini@ti.com>
