path: root/config.mk
2013-09-06Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-06cam_enc_4xx: Move CONFIG_SPL_PAD_TO to a config headerMasahiro Yamada
For most boards which define CONFIG_SPL_PAD_TO, it is defined in config header files. Currently, there exists only one exception, cam_enc_4xx board. This patch moves CONFIG_SPL_PAD_TO definition from board/ait/cam_enc_4xx/config.mk to include/configs/cam_enc_4xx.h. With this modification, we can delete a glue code in the top level config.mk: ifneq ($(CONFIG_SPL_PAD_TO),) CPPFLAGS += -DCONFIG_SPL_PAD_TO=$(CONFIG_SPL_PAD_TO) endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Heiko Schocher <hs@denx.de>
2013-09-06config.mk: Delete unnecessary codeMasahiro Yamada
Currently no makefiles (board-specific config.mk) set the following variables: CONFIG_SPL_TEXT_BASE CONFIG_UBOOT_PAD_TO CONFIG_RESET_VECTOR_ADDRESS CONFIG_TPL_PAD_TO For all target boards using above macros they are set in header files (include/configs/*.h), so we do not need to set them as CPPFLAGS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-08-20TPL : introduce the TPL based on the SPLYing Zhang
Due to the nand SPL on some board(e.g. P1022DS)has a size limit, it can not be more than 4K. So, the SPL cannot initialize the DDR with the SPD code. This patch introduces TPL to enable a loader stub that is loaded by the code from the SPL. It initializes the DDR with the SPD or other operations. The TPL's size is sizeable, the maximum size is decided by the memory's size that TPL runs. It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are three stage uboot images: * spl_boot, * tpl_boot, * final uboot image Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-19SPL: Makefile: Build a separate autoconf.mk for SPLJoel Fernandes
SPL defines CONFIG_SPL_BUILD but this does not percolate to the autoconf.mk Makefile. As a result the build breaks when CONFIG_SPL_BUILD is used in the board-specific include header file. With this, there is a possibility of having a CONFIG option defined in the header file but not defined in the Makefile causing all kinds of build failure and problems. It also messes things for up, for example, when one might want to undefine options to keep the SPL small and doesn't want to be stuck with the CONFIG options used for U-boot. Lastly, this also avoids defining special CONFIG_SPL_ variables for cases where some options are required in U-boot but not in SPL. We add a spl-autoconf.mk rule that is generated for SPL with the CONFIG_SPL_BUILD flag and conditionally include it for SPL builds. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-08-02Validate dtc is new enoughStephen Warren
Subsequent patches assume that dtc supports various recent features. These are available in dtc 1.4.0. Validate that dtc is at least that version. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-07-24Licenses: introduce SPDX Unique Lincense IdentifiersWolfgang Denk
Like many other projects, U-Boot has a tradition of including big blocks of License headers in all files. This not only blows up the source code with mostly redundant information, but also makes it very difficult to generate License Clearing Reports. An additional problem is that even the same lincenses are referred to by a number of slightly varying text blocks (full, abbreviated, different indentation, line wrapping and/or white space, with obsolete address information, ...) which makes automatic processing a nightmare. To make this easier, such license headers in the source files will be replaced with a single line reference to Unique Lincense Identifiers as defined by the Linux Foundation's SPDX project [1]. For example, in a source file the full "GPL v2.0 or later" header text will be replaced by a single line: SPDX-License-Identifier: GPL-2.0+ We use the SPDX Unique Lincense Identifiers here; these are available at [2]. Note: From the legal point of view, this patch is supposed to be only a change to the textual representation of the license information, but in no way any change to the actual license terms. With this patch applied, all files will still be licensed under the same terms they were before. Note 2: The apparent difference between the old "COPYING" and the new "Licenses/gpl-2.0.txt" only results from switching to the upstream version of the license which is differently formatted; there are not any actual changes to the content. Note 3: There are some recurring questions about linense issues, such as: - Is a "All Rights Reserved" clause a problem in GPL code? - Are files without any license header a problem? - Do we need license headers at all? The following excerpt from an e-mail by Daniel B. Ravicher should help with these: | Message-ID: <4ADF8CAA.5030808@softwarefreedom.org> | Date: Wed, 21 Oct 2009 18:35:22 -0400 | From: "Daniel B. Ravicher" <ravicher@softwarefreedom.org> | To: Wolfgang Denk <wd@denx.de> | Subject: Re: GPL and license cleanup questions | | Mr. Denk, | | Wolfgang Denk wrote: | > - There are a number of files which do not include any specific | > license information at all. Is it correct to assume that these files | > are automatically covered by the "GPL v2 or later" clause as | > specified by the COPYING file in the top level directory of the | > U-Boot source tree? | | That is a very fact specific analysis and could be different across the | various files. However, if the contributor could reasonably be expected | to have known that the project was licensed GPLv2 or later at the time | she made her contribution, then a reasonably implication is that she | consented to her contributions being distributed under those terms. | | > - Do such files need any clean up, for example should we add GPL | > headers to them, or is this not needed? | | If the project as a whole is licensed under clear terms, you need not | identify those same terms in each file, although there is no harm in | doing so. | | > - There are other files, which include both a GPL license header | > _plus_ some copyright note with an "All Rights Reserved" clause. It | > has been my understanding that this is a conflict, and me must ask | > the copyright holders to remove such "All Rights Reserved" clauses. | > But then, some people claim that "All Rights Reserved" is a no-op | > nowadays. License checking tools (like OSLC) seem to indicate this is | > a problem, but then we see quite a lot of "All rights reserved" in | > BSD-licensed files in gcc and glibc. So what is the correct way to | > deal with such files? | | It is not a conflict to grant a license and also reserve all rights, as | implicit in that language is that you are reserving all "other" rights | not granted in the license. Thus, a file with "Licensed under GPL, All | Rights Reserved" would mean that it is licensed under the GPL, but no | other rights are given to copy, modify or redistribute it. | | Warm regards, | --Dan | | Daniel B. Ravicher, Legal Director | Software Freedom Law Center (SFLC) and Moglen Ravicher LLC | 1995 Broadway, 17th Fl., New York, NY 10023 | (212) 461-1902 direct (212) 580-0800 main (212) 580-0898 fax | ravicher@softwarefreedom.org www.softwarefreedom.org [1] http://spdx.org/ [2] http://spdx.org/licenses/ Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-07-19mkimage: Use board config to get CONFIG_FIT_SIGNATURE valueSimon Glass
The value of this config variable is not available to image.h on the host, since the board config is not actually included. Bring this in so that mkimage will be built with image-signing support for sandbox at least. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-28mkimage: Build signing only if board has CONFIG_FIT_SIGNATURESimon Glass
At present mkimage is set up to always build with image signing support. This means that the SSL libraries (e.g. libssl-dev) are always required. Adjust things so that mkimage can be built with and without image signing, controlled by the presence of CONFIG_FIT_SIGNATURE in the board config file. If CONFIG_FIT_SIGNATURE is not enabled, then mkimage will report a warning that signing is not supported. If the option is enabled, but libraries are not available, then a build error similar to this will be shown: lib/rsa/rsa-sign.c:26:25: fatal error: openssl/rsa.h: No such file or directory Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add RSA support for image signingSimon Glass
RSA provides a public key encryption facility which is ideal for image signing and verification. Images are signed using a private key by mkimage. Then at run-time, the images are verified using a private key. This implementation uses openssl for the host part (mkimage). To avoid bringing large libraries into the U-Boot binary, the RSA public key is encoded using a simple numeric representation in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Support tracing in config.mk when enabledSimon Glass
Use -finstrument-functions when tracing is enabled (make FTRACE=1). Tracing is not currently supported by SPL even if sufficient memory is available. When tracing is enabled, we #define FTRACE. This can be used by board config files to conditionally enable the tracing options. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-09build: Pull -DBUILD_TAG into separate ifdefMarek Vasut
Currently the base setting for CFLAGS is split in two possibilities, one with -DBUILD_TAG appended at the end and one without, the rest of CFLAGS is the same in both cases. Change this so CFLAGS are always set and the -DBUILD_TAG is appended in separate ifdef. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
2013-05-01Trigger generic board error only when buildingSimon Glass
At present the generic board error can occur when configuring U-Boot, or during distclean, but this is incorrect. The existing autoconf.mk may come from an earlier U-Boot configuration which is about to be overwritten. Make the error conditional so that it will only be triggered when we are actually building U-Boot. This avoids a problem where the system is being reconfigured to remove CONFIG_SYS_GENERIC_BOARD on an architecture that does not support it. Currently this will print an error and require the manual removal of include/autoconf.mk. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-22Makefile: Add target for combined u-boot.img & spl/u-boot.binStefan Roese
This new make target "u-boot-img-spl-at-end.bin" consists of the the real, full-blown U-Boot image and the U-Boot SPL binary directly attached to it. The full-blown U-Boot image has the mkimage header included, with its load-address and entry-point. This will be used by the upcoming lwmon5 PPC440EPx derivate board port. Signed-off-by: Stefan Roese <sr@denx.de>
2013-04-12Makefile: Move SHELL setup to config.mkBenoît Thébaudeau
make never uses the SHELL variable from the environment. Instead, it uses /bin/sh, or the value assigned to the SHELL variable by the Makefile. This makes the export of the SHELL variable useless for sub-makes (but still useful for the environment of recipes). However, we want all makes to use the same shell. This patch fixes this issue by moving the SHELL variable setup and export to the top config.mk, so that all Makefile-s including it use the same shell. Since BASH is used by default, this makes it possible to use things like 'echo -e ...' in sub-makes, which would otherwise fail e.g. with /bin/sh symlinked to /bin/dash on Ubuntu. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15__HAVE_ARCH_GENERIC_BOARD controls availabilty of generic boardSimon Glass
We are introducing a new unified board setup. Add a check to make sure that board config files do not define CONFIG_SYS_GENERIC_BOARD unless their architecture defines __HAVE_ARCH_GENERIC_BOARD __HAVE_ARCH_GENERIC_BOARD will currently not be the default setting, but we can switch this later when most architecture support generic board. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Add symbol handling for generic lists into MakefileMarek Vasut
This patch adds essential components for generation of the contents of the linker section that is used by the linker-generated array. All of the contents is held in a separate file, u-boot.lst, which is generated at runtime just before U-Boot is linked. The purpose of this code is to especially generate the appropriate boundary symbols around each subsection in the section carrying the linker-generated arrays. Obviously, the interim linker code for actual placement of the variables into the section is generated too. The generated file, u-boot.lst, is included into u-boot.lds via the linker INCLUDE directive in u-boot.lds . Adjustments are made in the Makefile and spl/Makefile so that the u-boot.lds and u-boot-spl.lds depend on their respective .lst files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-15add check infrastructure, default sparseKim Phillips
Add support for running source code checkers on u-boot source, e.g., using sparse to aid with typechecking. This comes in especially handy as SoC vendors mix and match cores and devices with different endianness, thus here we add CHECK_ENDIAN to the otherwise linux kernel default CHECKFLAGS. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-15serial: Compile drivers/serial/serial.c by defaultMarek Vasut
Compile drivers/serial/serial.c by default both into SPL and into non-SPL builds, since CONFIG_SERIAL_MULTI is now the default state. Also having common/serial.c in by default now, it's pointless to keep -DCONFIG_SERIAL_MULTI in CPPFLAGS any longer, so remove it as well. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-10-15serial: Unconditionally enable CONFIG_SERIAL_MULTIMarek Vasut
Enable CONFIG_SERIAL_MULTI for all builds of U-Boot. That includes both SPL builds and non-SPL builds, everything. To avoid poluting this patch with removal of ifdef-endif constructions containing CONFIG_SERIAL_MULTI, the CONFIG_SERIAL_MULTI is temporarily added into CPPFLAGS in config.mk . This will be again removed in following patch. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-04tools, config.mk: add binutils-versionAllen Martin
Modeled after gcc-version, add function to get binutils version. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Wolfgang Denk <wd@denx.de>
2012-08-10config: Always use GNU ldKhem Raj
This patch makes sure that we always use the GNU ld. U-Boot uses certain construct e.g. OVERLAY which are not implemented in gold therefore it always needs GNU ld for linking. It works well if default linker in toolchain is GNU ld but in some cases we can have gold to be the default linker and also ship GNU ld but not as default in such cases its called $(PREFIX)ld.bfd, with this patch we make sure that if $(PREFIX)ld.bfd exists than we use that for our ld. This way it does not matter what the default ld is. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Khem Raj <raj.khem@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-07-07Makefile: Add u-boot.spr build target (SPEAr)Stefan Roese
On x600 (SPEAr600) U-Boot is appended to U-Boot SPL. Both images are created using mkimage (crc etc), so that the ROM bootloader can check its integrity. Padding needs to be done to the SPL image (with mkimage header) and not the binary. Otherwise the resulting image which is loaded/copied by the ROM bootloader to SRAM doesn't fit. The resulting image containing both U-Boot images is called u-boot.spr. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-05-15tools, config.mk: Add gcc-version.sh, cc-version test from LinuxTom Rini
Added from Linux - commit fde7d9049e55ab85a390be7f415d74c9f62dd0f9 Signed-off-by: Tom Rini <trini@ti.com>
2012-03-26config.mk: Check for -fstack-usage supportTom Rini
Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-03-26config.mk: Make cc-option create a file under include/generatedTom Rini
Testing for -fstack-usage requires the creation of an output file, which isn't possible with /dev/null. Signed-off-by: Tom Rini <trini@ti.com>
2011-11-07config.mk: use memoization in cc-option macro to speed up compilationDaniel Schwierzeck
Apply memoization to cc-option macro by caching the results of the gcc calls. This macro is called very often so using cached results leads to faster compilation times. The old behaviour can be restored by defining the config option CONFIG_CC_OPT_CACHE_DISABLE=y. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-11-03Reduce build timesWolfgang Denk
U-Boot Makefiles contain a number of tests for compiler features etc. which so far are executed again and again. On some architectures (especially ARM) this results in a large number of calls to gcc. This patch makes sure to run such tests only once, thus largely reducing the number of "execve" system calls. Example: number of "execve" system calls for building the "P2020DS" (Power Architecture) and "qong" (ARM) boards, measured as: -> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board> -> grep execve /tmp/foo | wc -l Before: After: Reduction: ================================== P2020DS 20555 15205 -26% qong 31692 14490 -54% As a result, built times are significantly reduced, typically by 30...50%. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Albert Aribaud <albert.aribaud@free.fr> cc: Graeme Russ <graeme.russ@gmail.com> cc: Mike Frysinger <vapier@gentoo.org> Tested-by: Graeme Russ <graeme.russ@gmail.com> Tested-by: Matthias Weisser <weisserm@arcor.de> Tested-by: Sanjeev Premi <premi@ti.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Macpaul Lin <macpaul@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-26fdt: Add support for embedded device tree (CONFIG_OF_EMBED)Simon Glass
This new option allows U-Boot to embed a binary device tree into its image to allow run-time control of peripherals. This device tree is for U-Boot's own use and is not necessarily the same one as is passed to the kernel. The device tree compiler output should be placed in the $(obj) rooted tree. Since $(OBJCOPY) insists on adding the path to the generated symbol names, to ensure consistency it should be invoked from the directory where the .dtb file is located and given the input file name without the path. This commit contains my entry for the ugliest Makefile / shell interaction competition. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-22build: force migration away from $(AR)Mike Frysinger
People keep adding new code that still uses $(AR) instead of $(cmd_link_o_target), so turn it into a build time error. We still use $(AR) locally, but we don't use $(ARFLAGS). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17Adjust dependency rules to permit per-file flagsSimon Glass
The dependency rules are currently done in a shell 'for' loop. This does not permit Makefile variables to adjust preprocessor flags as is done with normal compile flags, using the CFLAGS_path/file.o syntax. This change moves the dependency generation into the Makefile itself, and permits a CPPFLAGS_path/file.o to adjust preprocessor flags on a file or directory basis. The CPPFLAGS_... variable is also folded into CFLAGS during the build. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-07-26disable security warning flags when possibleMike Frysinger
Some toolchains enable security warning flags by default, but these don't really make sense in the u-boot world. Such as forcing changes like: -printf(foo); +printf("%s", foo); So disable the flags when the compiler supports them. Linux has already merged a similar change in their build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Extend build-system for SPL frameworkDaniel Schwierzeck
Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-06-22config.mk: move LDSCRIPT processing to the top-level MakefileIlya Yanok
LDSCRIPT is used only from the top-level Makefile and only when the system is configured so we can move LDSCRIPT and CONFIG_SYS_LDSCRIPT related logic into the top level Makefile and under configured condition to avoid errors when building tools from unconfigured tree. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-03-22Introduce a new linker flag LDFLAGS_FINALHaiying Wang
commit 8aba9dceebb14144e07d19593111ee3a999c37fc Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS breaks the usage of --gc-section to build nand_spl. We still need linker option --gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes the --gc-sections to each uboot image. To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace PLATFORM_LDFLAGS in the Makefile of each nand_spl board. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2011-03-21Top config.mk: add include/config.mkJoakim Tjernlund
Seems to me that the top level config.mk should include the auto generated include/config.mk so that all Makefile's pickup those definitions. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-01-25Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGSNobuhiro Iwamatsu
Linker needs to use the proper endian/bfd flags even when doing partial linking. LDFLAGS_u-boot sets linker option which is called it when U-boot is built (u-boot final). LDFLAGS sets necessary option by partial linking (use in cmd_link_o_target). CC: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-12-17config.mk: unify duplicated flag settingMike Frysinger
Multiple rules are using the expanded AFLAGS/CFLAGS settings and some are getting so long that the rules need to be line wrapped. So unify them in one variable, use that variable in the rule, and then unwrap things. This makes the actual `make` output nicer as it doesn't have line continuations in it anymore. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-27Coding Style (white space) cleanupWolfgang Denk
2010-08-09config.mk: avoid -traditional-cpp on OS X 10.5Mike Frysinger
Simply trying to include a basic header file like stdlib.h on OS X 10.5 and then building with -traditional-cpp fails with lots of errors like: In file included from /usr/include/stdlib.h:63, from test.c:3: /usr/include/available.h:85: error: stray '#' in program /usr/include/available.h:85: error: syntax error before numeric constant /usr/include/available.h:86: error: stray '#' in program In the past, I hadn't noticed because the old logic for these flags were restricted to Darwin running on PowerPC systems while I'm running on an Intel system. But after some recent clean ups and changes, the flag was being applied to all Darwin systems and my host tools broke. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-26config.mk: use different host compiler for OS X 10.6Andreas Biessmann
Compiling tools subdirectory on Mac OS X 10.6 (Snow Leopard) complains about wrong syntax in system includes. In file included from /usr/include/stdio.h:444, from ../source/u-boot/include/compiler.h:26, from ../source/u-boot/lib/crc32.c:15: /usr/include/secure/_stdio.h:46: error: syntax error in macro parameter list This can be fixed by reverting the workaround for prior OS X releases in config.mk conditionally for OS X 10.6+. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
