path: root/configs/M54418TWR_nand_rmii_defconfig
2020-01-10configs: add eth dm support for all ColdFire boardsAngelo Durgehello
Add dm eth config options for all involved ColdFire-based boards. Signed-off-by: Angelo Durgehello <angelo.dureghello@timesys.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04configs: remove MTD support from bcm11130 and M54418TWR defconfigsMiquel Raynal
While the right Kconfig entries were selected, because of the missing CMD_NAND symbol the raw NAND core was never compiled. Remove it from the defconfigs otherwise the build will fail. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Also do this on bcm11130_nand] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-24configs: add DM_SPI config optionAngelo Dureghello
This patch adds CONFIG_DM_SPI for all m68k boards using the cf_spi.c driver (DSPI module). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2019-05-24configs: enable use of DT for all m68k boardsAngelo Dureghello
Enable DT usage for all m68k boards. To provide a working single binary, the dts has been kept as embedded. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2018-02-13spi: Migrate CONFIG_CF_SPI to KconfigTuomas Tynkkynen
